PESD24VL1BA供应商,现货直供
PESD24VL1BA是客户咨询比较多的一款常用料号,热销TVS二极管型号之一,可见市场对于PESD24VL1BA的需求量是非常大的。关于PESD24VL1BA这个物料,客户更多咨询的是其参数、价格、样品、交期等方面的信息。接下来,TVS二极管厂家东沃电子倾心为您科普有关PESD24VL1BA的知识,看完您就明白了!
E
TVS二极管PESD24VL1BA详解
The PESD24VL1BA is designed to replace multilayer varistors in portable applications such as cell phones, notebook computers and PDA’s, using monolithic sili-con technology to provide fast response time and ultra low ESD clamping voltage, making this device an ideal solution for protecting sensitive semiconductor components from damage. The PESD24VL1BA complies with the IEC 61000-4-2(ESD) standard with ±15kV air and ±8kV contact discharge. The PESD24VL1BA is assembled into a lead-free SOD-323 package and will protect one unidirectional line. These devices will fit on the same PCB pad area as an 0805 MLV device.
TVS二极管PESD24VL1BA特性
·420W peak pulse power (8/20μs)
·Protects one data or power line
·Ultra low leakage: nA level
·Operating voltage: 24V
·Ultra low clamping voltage
·Complies with following standards: IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV
IEC61000-4-5 (Lightning) 9A (8/20ns)
·RoHS Compliant
·Lead Finish: Matte Tin
E
TVS二极管PESD24VL1BA参数
1)峰值脉冲功率Peak pulse power (tp = 8/20μs): 420W
2)峰值脉冲电流Peak pulse current (tp = 8/20μs): 9A
3)工作电压Reverse Stand-off Voltage: 24V
4)击穿电压Reverse Breakdown Voltage (Min.): 26V
5)漏电流Reverse Leakage Current: 0.5uA
6)钳位电压Clamping Voltage ( IPP=9A tp=8/20us ): 40V
7)电容Junction Capacitance (VR=0V, f = 1MHz Between I/O pins): 30pF
8)丝印标识Device Marking Code: 24B
9)封装Package: SOD-323
关于TVS二极管PESD24VL1BA就介绍到这儿了,想了解PESD24VL1BA价格、交期、样品等方面的信息,可直接咨询东沃电子!
E
  • 相关推荐
  • 热点推荐
  • E
