投稿 | 基于IAR搭建RA MCU 串口打印
RA MCU 生态工作室致力于构建一个完善的 RA 生态,这将会是一个好玩有趣的开放社区,也提供各种RA相关问题的解决方法。
1.概述
    通过RASC创建一个串口工程,具体配置如下,用户可以根据自己定义来配置串口相关的基本参数。
2.创建工程
    STEP1:RASC创建工程
mcu
    STEP2:选芯片型号跟IDE类型
mcu
    STEP3:选择芯片型号
mcu
    STEP4:选择无操作系统
mcu
   STEP5:勾选确认工程
mcu
   STEP6:配置串口号跟IO口
mcu
   STEP7:添加串口驱动
mcu
  STEP8:配置串口
mcu
  STEP9:配置串口基本属性
mcu
  STEP10:生成工程
mcu
3.代码
  STEP11:打开工程
mcu
    STEP12:添加代码
mcu
    STEP13:具体代码如下
void hal_entry( void )
    /* TODO: add your own code here */
    fsp_err_t err = R_SCI_UART_Open( &g_uart9_ctrl, &g_uart9_cfg );
    assert( FSP_SUCCESS == err );
    while ( true )
        printf( "Hello RA MCU \r\n" );
#if BSP_TZ_SECURE_BUILD
    /* Enter non-secure code */
    R_BSP_NonSecureEnter();
#endif
 STEP14:添加头文件跟串口回调函数
mcu
    STEP15:具体代码如下
#include "hal_data.h"
#include "stdio.h"
FSP_CPP_HEADER
void R_BSP_WarmStart( bsp_warm_start_event_t event );
FSP_CPP_FOOTER
uint8_t g_transfer_complete = 0;
void g_uart9_cb( uart_callback_args_t* p_args )
    /* Handle the UART event */
    switch ( p_args->event )
        /* Received a character */
        case UART_EVENT_RX_CHAR:
            break;
        /* Receive complete */
        case UART_EVENT_RX_COMPLETE:
            break;
        /* Transmit complete */
        case UART_EVENT_TX_COMPLETE:
            g_transfer_complete = 1;
            break;
        default:
    STEP16:添加打印接口重定向代码,具体如下
 * Copyright 1998-2017 IAR Systems AB.
 * This is a template implementation of the "__write" function used by
 * the standard library.  Replace it with a system-specific
 * implementation.
 * The "__write" function should output "size" number of bytes from
 * "buffer" in some application-specific way.  It should return the
 * number of characters written, or _LLIO_ERROR on failure.
 * If "buffer" is zero then __write should perform flushing of
 * internal buffers, if any.  In this case "handle" can be -1 to
 * indicate that all handles should be flushed.
 * The template implementation below assumes that the application
 * provides the function "MyLowLevelPutchar".  It should return the
 * character written, or -1 on failure.
#include
#pragma module_name = "?__write"
int MyLowLevelPutchar(int x)
  R_SCI_UART_Write(&g_uart9_ctrl, (uint8_t *)&x, 1);
  while(g_transfer_complete == 0);
  return x;
 * If the __write implementation uses internal buffering, uncomment
 * the following line to ensure that we are called with "buffer" as 0
 * (i.e. flush) when the application terminates.
size_t __write(int handle, const unsigned char * buffer, size_t size)
  /* Remove the #if #endif pair to enable the implementation */
#if 1
  size_t nChars = 0;
  if (buffer == 0)
     * This means that we should flush internal buffers.  Since we
     * don't we just return.  (Remember, "handle" == -1 means that all
     * handles should be flushed.)
    return 0;
  /* This template only writes to "standard out" and "standard err",
   * for all other file handles it returns failure. */
  if (handle != _LLIO_STDOUT && handle != _LLIO_STDERR)
    return _LLIO_ERROR;
  for (/* Empty */; size != 0; --size)
    if (MyLowLevelPutchar(*buffer++) < 0)
      return _LLIO_ERROR;
    ++nChars;
  return nChars;
#else
  /* Always return error code when implementation is disabled. */
  return _LLIO_ERROR;
#endif
4.工程配置
    STEP17:工程配置
mcu
    STEP18:弹出如下窗口
mcu
5.结果
    STEP19:接上串口工具,打印如下
mcu
投稿:欣瑞利科技@Moxair
  • 相关推荐
  • 热点推荐
  • mcu
