Banana Pi BPI-Leaf-S3创客教育板采用乐鑫ESP32-S3方案设计,支持Arduino
开发板
香蕉派 BPI-Leaf系列是为物联网设计的低功耗微控制器,支持创客教育和STEAM教育的一款开发板。
BPI-Leaf-S3采用乐鑫ESP32-S3芯片设计,采用Xtensa®32位LX7双核处理器,主频最高可达240 MHz。支持2.4 GHz Wi-Fi和蓝牙®LE双模无线通信,外设兼容低功耗硬件设计,深度睡眠模式下功耗仅为10uA。主控制器支持USB和外接3.7V锂电池两种供电方式,可实现自动电源开关功能。
关键特性:
1. 乐鑫ESP32-S3,Xtensa® 32 bit LX7
2. 拓展 PSRAM , FLASH
3. 超低功耗 10uA
4. 2.4G WIFI无线 ,蓝牙Bluetooth 5 ,Bluetooth mesh网络
5. GPIO , ADC , TOUCH , PWM , I2C , SPI , RMT , I2S , UART , LCD,CAMERA ,USB , JTAG
6. 1* 4pin I2C 连接
7. 1 * USB Type-C接口
8. 1 * 2pin 电池接口
9. 1 * Neopixel LED
硬件接口框架:
开发板
硬件规格:
BPI-Leaf-S3 Spec
SoCESP32-S3,Xtensa® dual-core 32-bit LX7 microprocessor
Clock Frequency240MHz MAX
Ambient Temperature-40℃~+85℃
Internal ROM384 KB
Internal SRAM320 KB
External FLASH ROM8MB
External PSRAM8MB
WIFIIEEE 802.11 b/g/n ,2.4Ghz,150Mbps
BluetoothBluetooth 5 ,Bluetooth mesh
GPIOBPI-Leaf-S3 has led out 36 available gpios
ADC2 × 12-bit SAR ADCs, up to 20 channels
Touch Sensor14
SPI4
I2C2
I2S2
LCD1 × LCD interface (8-bit ~16-bit parallel RGB, I8080 and MOTO6800)
CAMERA1 × DVP 8-bit ~16-bit camera interface
UART3
PWM8 channels 14 bits
MCPWM2
USB1 × full-speed USB OTG,female Type-C socket
USB Serial/JTAG controller1,CDC-ACM ,JTAG
Temperature sensor1,range of –20 °C to 110 °C
SD/MMC1 × SDIO host controller with 2 slots,SD 3.0,SD 3.01,SDIO 3.0,CE-ATA 1.1,MMC 4.41,eMMC 4.5,eMMC 4.51
TWAI® controller1 ,compatible with ISO 11898-1 (CAN Specification 2.0)
General DMA controller (GDMA)5 transmit channels and 5 receive channels
RMT4 TX channels,4RX channels.Eight channels share a 384 x 32-bit RAM
Pulse Count Controller4 independent pulse counters (units).Each unit consists of two independent channels
Timers4 × 54-bit general-purpose timers.1 × 52-bit system timer.3 × watchdog timers
External crystal oscillator40Mhz
RTC and Low­Power ManagementPower Management Unit (PMU) + Ultra-­Low-­Power Coprocessor(ULP)
Deep-sleep consumption current10uA
Operating Voltage3.3V
Input Voltage3.3V~5.5V
Maximum discharge current2A@3.3V LDO
USB chargeSupport
Maximum charging current500mA
Neopixel LED1
