MEID/ESN号段ESN Manufacturer’s (MFR) Codes (ESN 厂家代码段) 主要适用于CDMA类的产品Mobile Equipment IDentifier(MEID)是全球唯一的56bit移动终端标识号需要向美国申请。标识号会被输入终端里,无法修改。可用来对移动式设备进行身份识别和跟踪。由于ESN号段是有限的资源,于2002年已耗尽,可能还有少量回收利用的号段,所以制定了56位的MEID号段,用来取代32位的ESN号段。形象的说,MAC/OUI码、MEID/ESN和IMEI号就如同我们身份证上的身份证号码,具有全球唯一性是相关产品必可少的号码,如果忽略使用或不使用MEID号会造成手机根本无法正常工作。而IMEI号在国内也叫TAC码是GSM技术的机身串号最终都是需要向英国申请。
号段类型:
常见四类号码的差别
资料信息:
企业信息方面,姓名、职位、公司、地址、城市、省份、邮编、国家、电话、邮件;产品信息方面,品名、型号、频段、制式、功能;
注意事项:
以上填写企业资料
必须
是企业域名邮箱,并且不能填写Info和Support等企业公用邮箱;
时间周期:
1~2wkds(你没有看错是一到两个工作日完成,是目前业内最为快捷的申请服务商,当然这个也受美国假期的影响)
附上MIED号关于定价的原文Fee Structure for Mobile Equipment Identifier (MEID) Manufacturer’s ID Code AssignmentsMEID Administrator (see below) is the ONLY Global Administrator for MEID Code AssignmentsSinglemode Hexadecimal (base 16) MEID
Each singlemode segmented hexadecimal (base 16) MEID Manufacturer’s ID Code block assigned iscapable of producing 1,048,576 units [“A1” block] or 65,536 units [“A2” block]. It may be used for one ormultiple models [without limitation] based on manufacturer and operator requirements.- The administrative fee for each
“A1”
singlemode segmented block of 1,048,576 is $8,500 USD.- The administrative fee for each
“A2”
singlemode segmented block of 65,536 is $1,200 USD.- The administrative fee for each singlemode test block of 2,048 units [for testing use only] is $300 USD.For larger manufacturers, there is also an “A0” singlemode FULL hexadecimal (base 16) MEIDManufacturer’s ID Code block assigned capable of producing 16,777,216 units [= 16 x 1,048,576].It may also be used for one or multiple models based on manufacturer and operator requirements.- The administrative fee for each
“A0”
FULL singlemode block [16,777,216] is $119,900 USD.
Multimode Decimal (base 10) MEID
Each multimode IMEI/MEID decimal (base 10) MEID Manufacturer’s ID Code block assigned is capable ofproducing 1,000,000 units for CDMA – GSM – W-CDMA – TD-SCDMA – LTE use.From mid-May 2015, the global IMEI database can only accept only one (1) Model Name per block of1,000,000. Each unique Model Name requires a separate IMEI/MEID Manufacturer’s ID Code block toensure proper global interoperability.- The administrative fee for each
“99”
multimode block of 1,000,000 is $4,499 USD.- The administrative fee for each multimode test block of 2,000 units [for testing use only] is $300 USD.
