MACOM电容器直流浮动/射频旁路安装
1.3w人已加入
MACOM安装电容器设计用作MIC和FET的瞬态保护。因为电容器基材是硅,MACOM电容器直流浮动/射频旁路安装提供与待安装器件的热配对或机械配对。标准化产品提供更多的规格和电容值。MACOM设计灵活性使MACOM可以根据特殊客户要求提供更多的规格和电容选择。
深圳立维创展科技是MACOM的代理商,产品提供MACOM可变增益放大器,功率放大器,低噪声放大器,线性放大器,混合放大器,  FTTx放大器,分频放大器,放大器增益模块,有源分离器,功分压器,倍频器,混合混频器,混频器,上变频器,数字衰减器,数字移相器,功率测试仪。压控衰减器等半导体,进口,质量保证,欢迎咨询。
Part Number Description
SP5 Mounting Capacitors
SP39 Mounting Capacitors
SP48 Mounting Capacitors
SP38 Mounting Capacitors
SP7 Mounting Capacitors
SP80 Mounting Capacitors
SP52 Mounting Capacitors
SP49 Mounting Capacitors
SP111 Mounting Capacitors
SP12 Mounting Capacitors
SP44 Mounting Capacitors
SP29 Mounting Capacitors
SP6 Mounting Capacitors
SP14 Mounting Capacitors
SP1 Mounting Capacitors
SP64 Mounting Capacitors
SP89 Mounting Capacitors
SP2 Mounting Capacitors
SP84 Mounting Capacitors
SP51 Mounting Capacitors
SP88 Mounting Capacitors
SP20 Mounting Capacitors
SP22 Mounting Capacitors
SP87 Mounting Capacitors
SP120 Mounting Capacitors
SP37 Mounting Capacitors
SP68 Mounting Capacitors
SP81 Mounting Capacitors
SP55 Mounting Capacitors
SP40 Mounting Capacitors
SP104 Mounting Capacitors
SP77 Mounting Capacitors
SP34 Mounting Capacitors
审核编辑 黄宇
