VICOR电源模块BCM系列和VTM系列产品替代
VICOR产品旗下BCM系列和VTM系列产品,具备空间紧凑,效率高的特点,
BCM系列产品选型如下:
Vicor 型号 输入电压 输出电压 功率 工作电流 规格
BCM6123x60E10A5yzz 36 – 60V 6 – 10V 1500W 150A ChiP Digital / Analog
BCM6123x60E15A3yzz 9 – 15V 1950W 130A 150A ChiP Digital / Analog
BCM3814x60E10A5yzz 6 – 10V 1500W 150A   VIA Digital
BCM3814x60E15A3yzz 9 – 15V 1950W 130A   VIA Digital
BCM48Bx030x210A00 38 – 55V 2.4 – 3.4V 210W 70A Full Analog
VI Chip
BCM48Bx040y200B00 3.2 – 4.6V 200W 50A
BCM48Bx060y240A00 4.75 – 6.87V 240W 40A
BCM48Bx080y240A00 6.34 – 9.16V 30A
BCM48Bx096y240A00 7.6 – 11.0V 25A
BCM48Bx120y300A00 9.5 – 13.8V 300W 25A
BCM48Bx160y240A00 12.7 – 18.3V 240W 15A
BCM48Bx240y300A00 19 – 27.5V 300W 12A
BCM48Bx320y300A00 25.3 – 36.7V 9A
BCM48Bx480y300A00 38.0 – 55V 6A
BCM48Bx120y120B00 9.5 – 13.75V 120W 11.3A   Half VI Chip
Vicor 型号 输入电压(V) 输出电压 功率 工作电流(A) 规格
VTM48EF012T130A00 26 – 55 0.65 – 1.37   130 32.5 x 22 x 6.73mm - Full
VTM48EF015T115A00 26 – 55 0.81 – 1.71   115 32.5 x 22 x 6.73mm - Full
VTM48EH015T050A00 26 – 55 0.81 – 1.72   50 22 x 16.5 x 6.73mm - Half
VTM48EF020T080A00 26 – 55 1.08 – 2.29   80 32.5 x 22 x 6.73mm - Full
VTM48EF030T070A00 26 – 55 1.63 – 3.44   70 32.5 x 22 x 6.73mm - Full
VTM48EF040T050B00 26 – 55 2.17 – 4.58   50 32.5 x 22 x 6.73mm - Full
VTM48EF040T050B0R 26 – 55 2.17 – 4.58   50 32.5 x 22 x 6.73mm - Full
VTM48EH040T025B00 26 – 55 2.17 – 4.58   25 22 x 16.5 x 6.73mm - Half
VTM48EF060T040A00 26 – 55 3.25 – 6.88   40 32.5 x 22 x 6.73mm - Full
VTM48EF080T030A00 26 – 55 4.33 – 9.17   30 32.5 x 22 x 6.73mm - Full
VTM48EF096T025A00 32 – 55 6.40 – 11.00   25 32.5 x 22 x 6.73mm - Full
VTM48EF120T025A00 26 – 55 6.50 – 13.75   25 32.5 x 22 x 6.73mm - Full
VTM48EF120T025A0R 26 – 55 6.50 – 13.75   25 32.5 x 22 x 6.73mm - Full
VTM48EH120T010B00 26 – 55 6.50 – 13.75   10 22 x 16.5 x 6.73mm - Half
VTM48EF160T015A00 26 – 55 8.67 – 18.33   15 32.5 x 22 x 6.73mm - Full
VTM48EF240T012A00 26 – 53 14.00 – 26.50   12 32.5 x 22 x 6.73mm - Full
VTM48EF320T009A00 26 – 55 17.33 – 36.67   9 32.5 x 22 x 6.73mm - Full
VTM48EF480T006A00 26 – 55 26.00 – 55.00   6 32.5 x 22 x 6.73mm - Full
VICOR这2个系列的电源模块被推荐应用于紧凑空间的产品项目,可以提供大电流和大功率,但由于较多的客户反馈目前交期和价格很不理想。
这里给市场推荐的台达旗下Cyntec的M block 电源模块产品MPN541382-PV
这颗电源模块参数如下:
Model Name Input Output Peak Eff Others
MPN541382-PV 40~60V 25A 10~15V 80A 98.1% Open frame
10~15V 90A 40~60v 20A
可以支持正负2中接线方式,提供高达1000w负载功率,而封装体积仅2.8*17.3*7.7mm 。
Cnytec成立于1991年,主要研发、生产和销售高精度和高密度模块、传感器和应用领域功能模块。产品主要包含集成化电感、功率模块和高精度电阻器。普遍采用于移动设备、通信基站、机械设备等。
深圳市立维创展科技授权代理Cyntec全线产品,致力为客户提供高品质、高质量、价格公正的电源产品。目前,立维创展存有大批量Cyntec电源库存,例如型号:MUN12AD03-SEC,MUN3CAD03-SE等。产品原装原厂,质量保证,并为中国大陆市场提供技术支持,欢迎咨询。
审核编辑 黄宇
评论(0)
发评论
jf_06866573 2024-03-16
0 回复 举报
威克品牌有做吗?求渠道合作谢谢 收起回复
0 回复 举报
求渠道合作 收起回复
