Linux诊断系统故障命令dmesg详解
嵌入式技术
1420人已加入
前言
本文讲解诊断系统故障命令dmesg
命令简介
dmesg 命令用于显示系统开机信息,可用于诊断系统故障。
内核会将系统开机信息存储在ring buffer中,可以使用dmesg命令来查看,开机信息保存在/var/log/dmesg文件中。
用法
查看帮助
dmesg -h
Usage:
dmesg [options]
Display or control the kernel ring buffer.
Options:
-C, --clear                 clear the kernel ring buffer
-c, --read-clear            read and clear all messages
-D, --console-off           disable printing messages to console
-E, --console-on            enable printing messages to console
-F, --file            use the file instead of the kernel log buffer
-f, --facility        restrict output to defined facilities
-H, --human                 human readable output
-k, --kernel                display kernel messages
-L, --color[=]        colorize messages (auto, always or never)
                               colors are enabled by default
-l, --level           restrict output to defined levels
-n, --console-level set level of messages printed to console
-P, --nopager               do not pipe output into a pager
-p, --force-prefix          force timestamp output on each line of multi-line messages
-r, --raw                   print the raw message buffer
-S, --syslog                force to use syslog(2) rather than /dev/kmsg
-s, --buffer-size     buffer size to query the kernel ring buffer
-u, --userspace             display userspace messages
-w, --follow                wait for new messages
-x, --decode                decode facility and level to readable string
-d, --show-delta            show time delta between printed messages
-e, --reltime               show local time and time delta in readable format
-T, --ctime                 show human-readable timestamp (may be inaccurate!)
-t, --notime                don't show any timestamp with messages
     --time-format   show timestamp using the given format:
                               [delta|reltime|ctime|notime|iso]
Suspending/resume will make ctime and iso timestamps inaccurate.
-h, --help                  display this help
-V, --version               display version
Supported log facilities:
    kern - kernel messages
    user - random user-level messages
    mail - mail system
  daemon - system daemons
    auth - security/authorization messages
  syslog - messages generated internally by syslogd
     lpr - line printer subsystem
    news - network news subsystem
Supported log levels (priorities):
   emerg - system is unusable
   alert - action must be taken immediately
    crit - critical conditions
     err - error conditions
    warn - warning conditions
  notice - normal but significant condition
    info - informational
   debug - debug-level messages
For more details see dmesg(1).
命令语法
dmesg [options]
选项说明
-c  #显示信息后,清除ring buffer中的内容
-s<缓冲区大小>  #默认值为8196,刚好等于ring buffer的大小
-n  #设置记录信息的层级
-D  #禁用打印消息到控制台
-E  #启用打印消息到控制台
-h  #打印帮助文本并退出
-k  #打印内核消息
-n  #设置将消息记录到控制台的级别
-r  #打印原始消息缓冲区
-s  #使用多少大小的缓冲区来查询内核环缓冲区。默认情况下为16392-T  #打印人类可读时间戳
-t  #不打印内核的时间戳
-u  #打印用户空间消息
-V  #输出版本信息并退出-
x  #将设施和级别(优先级)编号解码为可读的前缀
应用举例
在openwrt上查看开机信息
dmesg
[    0.000000] Linux version 5.4.143 (*******) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc        0535800)) #0 Tue Aug 31 2208 2021
[    0.000000] Board has DDR2
[    0.000000] Analog PMU set to hw control
[    0.000000] Digital PMU set to hw control
[    0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[    0.000000] printk: bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[    0.000000] MIPS: machine is Jotale JS76x8 (32M)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] On node 0 totalpages: 32768
[    0.000000]   Normal zone: 288 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32480
[    0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[   11.641746] usbcore: registered new interface driver cdc_subset
[   11.689505] PPP generic driver version 2.4.2
[   11.703356] usbcore: registered new interface driver qmi_wwan
[   11.730537] rndis_host 1-1:1.0 eth1: register 'rndis_host' at usb-101c0000.ehci-1, RNDIS device, ac:4        bb9e5
[   11.741397] usbcore: registered new interface driver rndis_host
[   11.789009] kmodloader: done loading kernel modules from /etc/modules.d/*
[   11.855712] urngd: v1.0.2 started.
[   12.515084] random: crng init done
[   12.518593] random: 1 urandom warning(s) missed due to ratelimiting
[   19.978363] rt3050-esw 10110000.esw: link changed 0x00
[   22.202128] br-lan: port 1(eth0.1) entered blocking state
[   22.207696] br-lan: port 1(eth0.1) entered disabled state
[   22.213547] device eth0.1 entered promiscuous mode
[   22.218473] device eth0 entered promiscuous mode
[   22.255696] br-lan: port 1(eth0.1) entered blocking state
[   22.261264] br-lan: port 1(eth0.1) entered forwarding state
[   23.004559] rt3050-esw 10110000.esw: link changed 0x01
这样打印信息不方便查找关键信息
查看前25行开机信息
dmesg | head -n 25
[    0.000000] Linux version 5.4.143 (fan@FAN-THINK-PC) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Tue Aug 31 2208 2021
查看后25行开机信息
dmesg | tail -n 25
[   11.352236] GACT probability on
[   11.361732] Mirror/redirect action on
[   11.395872] u32 classifier
[   11.398710]     input device check on
[   11.402442]     Actions configured
[   11.463279] usbcore: registered new interface driver cdc_wdm
[   11.613359] xt_time: kernel timezone is -0000
[   11.626466] usbcore: registered new interface driver cdc_ether
[   11.730537] rndis_host 1-1:1.0 eth1: register 'rndis_host' at usb-101c0000.ehci-1, RNDIS device, acb3eb:e5
查看与内存相关的开机信息
dmesg | grep -i memory
[    0.000000] Memory: 122688K/131072K available (4436K kernel code, 192K rwdata, 1016K rodata, 1192K init, 193K bss, 8384K reserved, 0K cma-reserved)
[    0.526438] Freeing unused kernel memory: 1192K
[    0.531064] This architecture does not have kernel memory protection.
查看与USB相关的开机信息
dmesg | grep -i usb
[    1.884358] usbcore: registered new interface driver usbfs
[    1.890096] usbcore: registered new interface driver hub
[    1.895617] usbcore: registered new device driver usb
[    1.907868] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.939711] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    1.946525] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    1.957713] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    1.984466] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    1.991901] hub 1-0 USB hub found
[    4.628468] usb 1-1: new high-speed USB device number 2 using ehci-platform
  审核编辑:汤梓红
