USB鼠标驱动程序上机实验
上机实验
韦老师的 USB 鼠标驱动,只实现了检测鼠标左键、右键、中键的【按下弹起】功能,没有实现复杂功能,可以做 demo 学习参考。使用完整 USB 鼠标功能请使用 Linux 内核自带的 driver,如文章开头目录。
/* 参考: drivershidusbhidusbmouse.c */
#include < linux/kernel.h >
#include < linux/slab.h >
#include < linux/module.h >
#include < linux/init.h >
#include < linux/usb.h >
#include < linux/input.h >
#include < linux/hid.h >
struct usb_mouse_as_key_desc {
    struct usb_device *dev;
    struct usb_interface *intf;
    const struct usb_device_id *id;
    int pipe, maxp;
    int bInterval;
    void *data_buffer;
    dma_addr_t data_dma;
    struct urb *urb;
/* 1. 构造 usb_driver
 * 1.1 id_table : 能支持哪些设备
 * 1.2 probe : 记录某些信息, 分配/设置/注册 input_dev, 也许"分配/填充/提交 URB"
static struct usb_device_id usb_mouse_as_key_id_table [] = {
 { USB_INTERFACE_INFO(USB_INTERFACE_CLASS_HID, USB_INTERFACE_SUBCLASS_BOOT,
  USB_INTERFACE_PROTOCOL_MOUSE), .driver_info = (kernel_ulong_t)"it is a mouse", },
 { } /* Terminating entry */
static void usb_mouse_as_key_irq(struct urb *urb)
 struct input_dev *dev = urb- >context;
 struct usb_mouse_as_key_desc *desc = input_get_drvdata(dev);
 signed char *data = desc- >data_buffer;
 int status;
 //printk("%s %s %d, urb- >status = %dn", __FILE__, __FUNCTION__, __LINE__, urb- >status);
 switch (urb- >status) {
 case 0:   /* success */
  break;
 case -ECONNRESET: /* unlink */
 case -ENOENT:
 case -ESHUTDOWN:
  return;
 /* -EPIPE:  should clear the halt */
 default:  /* error */
  goto resubmit;
 //printk("data[1] = 0x%xn", data[1]);
 input_report_key(dev, KEY_L, data[1] & 0x01);
 input_report_key(dev, KEY_S, data[1] & 0x02);
 input_report_key(dev, KEY_ENTER, data[1] & 0x04);
 input_sync(dev);
resubmit:
 status = usb_submit_urb (urb, GFP_ATOMIC);
  //printk("%s %s %d, status = %dn", __FILE__, __FUNCTION__, __LINE__, status);
static int usb_mouse_as_key_open(struct input_dev *dev)
    struct urb *urb;
    int err;
    printk("%s %s %dn", __FILE__, __FUNCTION__, __LINE__);
    /* 分配/填充/提交 URB */
    urb = usb_alloc_urb(0, GFP_KERNEL);
    desc- >urb = urb;
    usb_fill_int_urb(urb,
         desc- >dev,
         desc- >pipe,
         desc- >data_buffer,
         (desc- >maxp > 8 ? 8 : desc- >maxp),
         usb_mouse_as_key_irq,
         dev,
         desc- >bInterval);
    urb- >transfer_dma = desc- >data_dma;
    urb- >transfer_flags |= URB_NO_TRANSFER_DMA_MAP;
    err = usb_submit_urb (urb, GFP_ATOMIC);
    printk("%s %s %d, err = %dn", __FILE__, __FUNCTION__, __LINE__, err);
    return err;
static void usb_mouse_as_key_close(struct input_dev *dev)
    /* 取消/释放 URB */
    usb_kill_urb(desc- >urb);
    usb_free_urb(desc- >urb);
static int usb_mouse_as_key_probe(struct usb_interface *intf, const struct usb_device_id *id)
 struct usb_device *dev = interface_to_usbdev(intf);
 struct input_dev *input_dev;
 struct usb_mouse_as_key_desc *desc;
 int error;
 struct usb_host_interface *interface;
 struct usb_endpoint_descriptor *endpoint;
 int pipe, maxp;
 /* 1. 记录设备信息:  intf */
 interface = intf- >cur_altsetting;
 if (interface- >desc.bNumEndpoints != 1)
  return -ENODEV;
 endpoint = &interface- >endpoint[0].desc;
 if (!usb_endpoint_is_int_in(endpoint))
  return -ENODEV;
 pipe = usb_rcvintpipe(dev, endpoint- >bEndpointAddress);
 maxp = usb_maxpacket(dev, pipe, usb_pipeout(pipe));
 desc = kmalloc(sizeof(struct usb_mouse_as_key_desc), GFP_KERNEL);
 desc- >dev  = dev;
 desc- >intf = intf;
 desc- >id   = id;
 desc- >pipe = pipe;
 desc- >maxp = maxp;
 desc- >bInterval = endpoint- >bInterval;
 desc- >data_buffer = usb_alloc_coherent(dev, maxp, GFP_ATOMIC, &desc- >data_dma);
 printk("%s %s %d, desc- >data_buffer = 0x%xn", __FILE__, __FUNCTION__, __LINE__, desc- >data_buffer);
 /* 2. 分配/设置/注册input_dev
  * 2.1 能产生哪类事件
  * 2.2 能产生这类事件里哪些些事件: L/S/ENTER
  * 2.3 设置函数, 比如open
  * 2.4 在open函数里: 分配/填充/提交 URB
  * 2.5 URB的回调函数: 解析数据, 上报input_event
 input_dev = devm_input_allocate_device(&intf- >dev);
 input_set_drvdata(input_dev, desc);
 /* set 1: which type event ? */
 __set_bit(EV_KEY, input_dev- >evbit);
 /* set 2: which event ? */
 __set_bit(KEY_L, input_dev- >keybit);
 __set_bit(KEY_S, input_dev- >keybit);
 __set_bit(KEY_ENTER, input_dev- >keybit);
 /* set 3: open */
 input_dev- >open  = usb_mouse_as_key_open;
 input_dev- >close = usb_mouse_as_key_close;
 error = input_register_device(input_dev);
 usb_set_intfdata(intf, input_dev);
 return 0;
static void usb_mouse_as_key_disconnect(struct usb_interface *intf)
 struct input_dev *input_dev = usb_get_intfdata (intf);
    struct usb_mouse_as_key_desc *desc = input_get_drvdata(input_dev);
    usb_free_coherent(desc- >dev, desc- >maxp, desc- >data_buffer, desc- >data_dma);
    kfree(desc);
    input_unregister_device(input_dev);
    usb_set_intfdata(intf, NULL);
static struct usb_driver usb_mouse_as_key_driver = {
 .name  = "usbmouse_as_key",
 .probe  = usb_mouse_as_key_probe,
 .disconnect = usb_mouse_as_key_disconnect,
 .id_table = usb_mouse_as_key_id_table,
/* 入口函数  / 出口函数 */
// module_usb_driver(usb_mouse_as_key_driver);
static int __init usb_mouse_as_key__init(void)
 return usb_register(&usb_mouse_as_key_driver);
static void __exit usb_mouse_as_key__init_exit(void)
 usb_deregister(&usb_mouse_as_key_driver);
module_init(usb_mouse_as_key__init);
module_exit(usb_mouse_as_key__init_exit);
MODULE_LICENSE("GPL");
测试:
# 把 USB 鼠标查到开发板上
# 先看看原来有哪些设备节点
ls /dev/input/event*
# 安装驱动程序
insmod usbmouse_as_key.ko
# 再看看新得到了哪个设备节点
# 执行命令, 假设 event4 是新节点
hexdump /dev/input/event4
# 点击鼠标按键即可观察输出信息
# 第 2 种测试方法: 执行以下命令,按鼠标左键、右键,再按中键就有输出"ls"
cat /dev/tty0
# 第 3 种测试方法: 执行以下命令(注意"< "号前后没有空格),就可以使用鼠标按键在控制台输入字符
exec 0< /dev/tty0
