#include < errno.h >
#include < signal.h >
#include < stdio.h >
#include < stdlib.h >
#include < string.h >
#include < libusb-1.0/libusb.h >
int main(int argc, char **argv)
int err;
libusb_device *dev, **devs;
int num_devices;
int endpoint;
int interface_num;
int found = 0;
int transferred;
int count = 0;
unsigned char buffer[16];
struct libusb_config_descriptor *config_desc;
struct libusb_device_handle *dev_handle = NULL;
/* libusb_init */
err = libusb_init(NULL);
if (err < 0) {
fprintf(stderr, "failed to initialise libusb %d - %sn", err, libusb_strerror(err));
exit(1);
/* get device list */
if ((num_devices = libusb_get_device_list(NULL, &devs)) < 0) {
fprintf(stderr, "libusb_get_device_list() failedn");
libusb_exit(NULL);
exit(1);
fprintf(stdout, "libusb_get_device_list() okn");
/* for each device, get config descriptor */
for (int i = 0; i < num_devices; i++) {
dev = devs[i];
/* parse interface descriptor, find usb mouse */
err = libusb_get_config_descriptor(dev, 0, &config_desc);
if (err) {
fprintf(stderr, "could not get configuration descriptorn");
continue;
fprintf(stdout, "libusb_get_config_descriptor() okn");
for (int interface = 0; interface < config_desc- >bNumInterfaces; interface++) {
const struct libusb_interface_descriptor *intf_desc = &config_desc- >interface[interface].altsetting[0];
interface_num = intf_desc- >bInterfaceNumber;
if (intf_desc- >bInterfaceClass != 3 || intf_desc- >bInterfaceProtocol != 2)
continue;
else
/* 找到了USB鼠标 */
fprintf(stdout, "find usb mouse okn");
for (int ep = 0; ep < intf_desc- >bNumEndpoints; ep++)
if ((intf_desc- >endpoint[ep].bmAttributes & 3) == LIBUSB_TRANSFER_TYPE_INTERRUPT ||
(intf_desc- >endpoint[ep].bEndpointAddress & 0x80) == LIBUSB_ENDPOINT_IN) {
/* 找到了输入的中断端点 */
fprintf(stdout, "find in int endpointn");
endpoint = intf_desc- >endpoint[ep].bEndpointAddress;
found = 1;
break;
if (found)
break;
libusb_free_config_descriptor(config_desc);
if (found)
break;
if (!found)
/* free device list */
libusb_free_device_list(devs, 1);
libusb_exit(NULL);
exit(1);
if (found)
/* libusb_open */
err = libusb_open(dev, &dev_handle);
if (err)
fprintf(stderr, "failed to open usb mousen");
exit(1);
fprintf(stdout, "libusb_open okn");
/* claim interface */
libusb_set_auto_detach_kernel_driver(dev_handle, 1);
err = libusb_claim_interface(dev_handle, interface_num);
if (err)
fprintf(stderr, "failed to libusb_claim_interfacen");
exit(1);
fprintf(stdout, "libusb_claim_interface okn");
/* libusb_interrupt_transfer */
while (1)
err = libusb_interrupt_transfer(dev_handle, endpoint, buffer, 16, &transferred, 5000);
if (!err) {
/* parser data */
printf("%04d datas: ", count++);
for (int i = 0; i < transferred; i++)
printf("%02x ", buffer[i]);
printf("n");
} else if (err == LIBUSB_ERROR_TIMEOUT){
fprintf(stderr, "libusb_interrupt_transfer timoutn");
} else {
fprintf(stderr, "libusb_interrupt_transfer err : %dn", err);
//exit(1);
/* libusb_close */
libusb_release_interface(dev_handle, interface_num);
libusb_close(dev_handle);
libusb_exit(NULL);
// 1. 安装开发包
$ sudo apt install libusb-1.0-0-dev
// 2. 修改源码,包含libusb.h 头文件时用如下代码
// 3. 编译程序指定库
gcc -o readmouse readmouse.c -lusb-1.0
sudo apt-get install libtool
unzip libusb-1.0.26.zip
cd libusb-1.0.26
./autogen.sh
./configure --host=arm-buildroot-linux-gnueabihf --prefix=$PWD/tmp
make
make install
ls tmp/
include lib
libusb-1.0.26/tmp/lib$ cp * -rfd /home/book/100ask_imx6ull-sdk/ToolChain/arm-buildroot-linux-gnueabihf_sdk-buildroot/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/
libusb-1.0.26/tmp/include$ cp libusb-1.0 -rf /home/book/100ask_imx6ull-sdk/ToolChain/arm-buildroot-linux-gnueabihf_sdk-buildroot/arm-buildroot-linux-gnueabihf/sysroot/usr/include/
arm-buildroot-linux-gnueabihf-gcc -o readmouse.c -lusb-1.0
./readmouse
