Benchmark的目的是通过对所提供的基准测试,用于验证和确定目标系统的性能规模和计算能力;测试内存带宽与性能指标;测试文件系统(I/O)性能指标;测试网络带宽与性能指标;测试高性能计算机整体性能指标等。
目前云平台上已经移植了三项Benchmark测试:Stream、UnixBench、CoreMark-PRO。更多测试项目和体系建设正在进行,并正在招聘实习生,欢迎参与(可加微信iYuta-R2进一步沟通了解)。本文先介绍已经完成的三项测试的结果,如果您对结果有相关什么疑问和指正,也可以通过文末的联系方式找到我们。
1. Stream
Stream 基准测试是一个简单的综合基准测试程序,用于测量可持续内存带宽(以 MB/s 为单位)以及简单向量内核的相应计算速率。测试结果如下【仅供参考】:
64 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables 9401556.0 lps (10.0 s, 7 samples)
Double-Precision Whetstone 2875.1 MWIPS (10.0 s, 7 samples)
Execl Throughput 719.1 lps (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks 211569.9 KBps (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks 56404.6 KBps (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks 595552.5 KBps (30.0 s, 2 samples)
Pipe Throughput 306839.8 lps (10.0 s, 7 samples)
Pipe-based Context Switching 19074.8 lps (10.0 s, 7 samples)
Process Creation 1912.9 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 2549.0 lpm (60.0 s, 2 samples)
Shell Scripts (8 concurrent) 2104.7 lpm (60.0 s, 2 samples)
System Call Overhead 583954.0 lps (10.0 s, 7 samples)
System Benchmarks Index Values BASELINE RESULT INDEX
Dhrystone 2 using register variables 116700.0 9401556.0 805.6
Double-Precision Whetstone 55.0 2875.1 522.8
Execl Throughput 43.0 719.1 167.2
File Copy 1024 bufsize 2000 maxblocks 3960.0 211569.9 534.3
File Copy 256 bufsize 500 maxblocks 1655.0 56404.6 340.8
File Copy 4096 bufsize 8000 maxblocks 5800.0 595552.5 1026.8
Pipe Throughput 12440.0 306839.8 246.7
Pipe-based Context Switching 4000.0 19074.8 47.7
Process Creation 126.0 1912.9 151.8
Shell Scripts (1 concurrent) 42.4 2549.0 601.2
Shell Scripts (8 concurrent) 6.0 2104.7 3507.9
System Call Overhead 15000.0 583954.0 389.3
System Benchmarks Index Score 404.7
Benchmark Run: Tue Jul 18 2023 09:45:31 - 10:14:27
64 CPUs in system; running 64 parallel copies of tests
Dhrystone 2 using register variables 599089659.4 lps (10.0 s, 7 samples)
Double-Precision Whetstone 183186.6 MWIPS (10.0 s, 7 samples)
Execl Throughput 13700.6 lps (29.5 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks 10622116.4 KBps (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks 3444789.4 KBps (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks 10962548.9 KBps (30.0 s, 2 samples)
Pipe Throughput 20175106.5 lps (10.0 s, 7 samples)
Pipe-based Context Switching 2975086.8 lps (10.0 s, 7 samples)
Process Creation 10684.1 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 59032.5 lpm (60.0 s, 2 samples)
Shell Scripts (8 concurrent) 7481.0 lpm (60.2 s, 2 samples)
System Call Overhead 37161452.1 lps (10.0 s, 7 samples)
Dhrystone 2 using register variables 116700.0 599089659.4 51335.9
Double-Precision Whetstone 55.0 183186.6 33306.7
Execl Throughput 43.0 13700.6 3186.2
File Copy 1024 bufsize 2000 maxblocks 3960.0 10622116.4 26823.5
File Copy 256 bufsize 500 maxblocks 1655.0 3444789.4 20814.4
File Copy 4096 bufsize 8000 maxblocks 5800.0 10962548.9 18900.9
Pipe Throughput 12440.0 20175106.5 16217.9
Pipe-based Context Switching 4000.0 2975086.8 7437.7
Process Creation 126.0 10684.1 847.9
Shell Scripts (1 concurrent) 42.4 59032.5 13922.8
Shell Scripts (8 concurrent) 6.0 7481.0 12468.4
System Call Overhead 15000.0 37161452.1 24774.3
System Benchmarks Index Score 13089.1
3. CoreMark-PROCoreMark-PRO 是一款全面、先进的处理器基准测试,可与经过市场验证的行业标准 EEMBC CoreMark 基准测试配合使用并对其进行增强。CoreMark 强调 CPU 管道,而 CoreMark-PRO 测试整个处理器,增加对多核技术、整数和浮点工作负载组合以及利用更大内存子系统的数据集的全面支持。EEMBC CoreMark 和 CoreMark-PRO 共同提供了涵盖从低端微控制器到高性能计算处理器的标准基准。EEMBC CoreMark-PRO 基准测试包含五种流行的整数工作负载和四种流行的浮点工作负载。
WORKLOAD RESULTS TABLE
MultiCore SingleCore
Workload Name (iter/s) (iter/s) Scaling
384.62 85.47 4.50
core 36.32 0.59 61.56
1333.33 71.23 18.72
24.17 2.39 10.11
nnet_test 180.79 3.15 57.39
40.51 14.93 2.71
1838.24 186.53 9.85
1523.81 64.10 23.77
376.47 47.62 7.91
MARK RESULTS TABLE
Mark Name MultiCore SingleCore Scaling
28467.36 2105.08 13.52
正文完
快速使用指南链接:https://www.kdocs.cn/l/cmnYcyFIlVRx
欢迎关注我们,参与进来共建RISC-V软件生态~加入我们的讨论群后,可以向管理员申请免费的64核RISC-V服务器SUDO权限试用账号。
1. 加入微信讨论群:加iYuta-R2为好友后可拉入群。
2. 加入QQ讨论群:906962594(RVBoards·Only RISC-V)扫描二维码加群
原文标题:64核RSIC-V高性能处理器公共测试云平台 · Benchmark体系建设一期
文章出处:【微信公众号:澎峰科技PerfXLab】欢迎添加关注!文章转载请注明出处。
