accept函数为例
系统调用中参数从用户态向内核态的传递是通过寄存器完成的,eax表示系统调用,ebx表示第一个参数,ecx表示第二个参数,edx表示第三个参数(主要针对socke.S)
(glibc函数库)sysdepsunissysvlinuxaccept.S
#define socket accept //将socket定义为accept
#define _socket _libc_accept
#define NARGS 3 //系统调用的个数
#include < socket.S > //这几个套接字函数的通用实现
#include < sysdep.h >
#include < sys/socketcall.h >
#define P(a, b) P2(a, b)
#define P2(a, b) a##b
.text
/* The socket-oriented system calls are handled unusally in Linux.
They are all gated through the single `socketcall' system call number.
`socketcall' takes two arguments: the first is the subcode, specifying
which socket function is being called; and the second is a pointer to
the arguments to the specific function.
The .S files for the other calls just #define socket and #include this. */
.globl P(__,socket)
ENTRY (P(__,socket))
/* Save registers. */
movl %ebx, %edx
movl $SYS_ify(socketcall), %eax/* System call number in %eax. */
//展开$SYS_iff()宏
/* Use ## so `socket' is a separate token that might be #define'd. */
movl $P(SOCKOP_,socket), %ebx/* Subcode is first arg to syscall. */
lea 4(%esp), %ecx/* Address of args is 2nd arg. */
/* Do the system call trap. */
int $0x80
/* Restore registers. */
movl %edx, %ebx
/* %eax is < 0 if there was an error. */
cmpl $-125, %eax
jae syscall_error
/* Successful; return the syscall's value. */
ret
PSEUDO_END (P(__,socket))
c
weak_alias (P(__,socket), socket)
重点看:
movl $SYS_ify(socketcall), %eax /* System call number in %eax. */
展开SYS_iff()宏 (glibc函数库: sysdepsunixsysdep.h)
#ifdef __STDC__
#define SYS_ify(syscall_name) SYS_##syscall_name
#else
#define SYS_ify(syscall_name) SYS_/**/syscall_name
#endif
预处理后为:
movl $SYS_socketcall,%eax
//将系统调用号放入eax中,但是对于网络套接字所有的接口函数而言,他们的共同入口函数是sys_socketcall
//在内核中,总入口函数sys_socketcall的系统调用号为_NR_socketcall,定义在include/linux/unistd.h
#define __NR_socketcall102
//在glib函数库中,有如下的预定义
#define SYS_socketcall _NR_socketcall
所以:
//将sys_socketcall函数对应的系统调用号赋予eax寄存器,从而使套接字系统调用进入到正常的入口函数中
这样套接字系统调用进入到正确的函数中了。
那么第一个参数是识别系统调用的具体函数的,这个参数在socket.S(glibc库)中:
//预处理后:
movl $SOCKOP_accept,%ebx//这就完成了第一个参数的传递
关于SOCKOP_accept:
查看(glibc库:sysdepsunixsysvlinuxsocketcall.h)
#ifndef _SYS_SOCKETCALL_H
#define _SYS_SOCKETCALL_H 1
/* Define unique numbers for the operations permitted on socket. Linux
uses a single system call for all these functions. The relevant code
file is /usr/include/linux/net.h.
We cannot use a enum here because the values are used in assembler
code. */
#define SOCKOP_socket 1
#define SOCKOP_bind 2
#define SOCKOP_connect 3
#define SOCKOP_listen 4
//可以看到SOCKOP_accept对应的值为5
#define SOCKOP_accept 5
#define SOCKOP_getsockname 6
#define SOCKOP_getpeername 7
#define SOCKOP_socketpair 8
#define SOCKOP_send 9
#define SOCKOP_recv 10
#define SOCKOP_sendto 11
#define SOCKOP_recvfrom 12
#define SOCKOP_shutdown 13
#define SOCKOP_setsockopt 14
#define SOCKOP_getsockopt 15
#define SOCKOP_sendmsg 16
#define SOCKOP_recvmsg 17
#endif /* _SYS_SOCKETCALL_H */
在linux内核(include/linux/net.h):
code. */
//这与glibc库中的SOCKOP_accept对应的值相同
第二个参数
在socket.S中:以指针的方式设置了sys_socketcall的第二个参数
lea 4(%esp), %ecx /* Address of args is 2nd arg. */
设置完以上的系统调用号还有参数后进入软中断:int $0x80,进入了内核态进行处理
_system_call:
pushl %eax # save orig_eax
SAVE_ALL
movl $-ENOSYS,EAX(%esp)
cmpl $(NR_syscalls),%eax
jae ret_from_sys_call
/*对应上面,未调用软中断之前,eax寄存器中被初始化为系统调用号,即_NR_socketcall,
这个调用号别用于在_sys_call_table数组中进行函数指针的寻址,将对应的函数地址对eax寄存器赋值 */
movl _sys_call_table(,%eax,4),%eax
testl %eax,%eax
je ret_from_sys_call
movl _current,%ebx
andl $~CF_MASK,EFLAGS(%esp) # clear carry - assume no errors
movl $0,errno(%ebx)
movl %db6,%edx
movl %edx,dbgreg6(%ebx) # save current hardware debugging status
testb $0x20,flags(%ebx) # PF_TRACESYS
jne 1f
/*上面给eax复制后,这里进行调用该函数,到这为止,accept系统调用将请求传递给了sys_socketcall,
然后将socket.S中设置的参数传递给sock_accept函数,就完成了应用层接口函数accept到BSD socket层函数的请求传递工作
call *%eax
movl %eax,EAX(%esp) # save the return value
movl errno(%ebx),%edx
negl %edx
movl %edx,EAX(%esp)
orl $(CF_MASK),EFLAGS(%esp) # set carry to indicate error
jmp ret_from_sys_call
