一文详解Flip Chip制程工艺
制造/封装
541人已加入
Kingbond Training Course
Flip Chip conductive method - connect to Substrate/PCB
1.Metal bump 金属凸块-C4 process(IBM)
2. Tape-Automated bonding 卷带接合-ACF process
3. Anisotropic conductive adhesives
异方向性导电胶 -ACP process
4.Polymer bump 高分子凸块 - C4 process
5.Stud bump. 打线成球 - ACP process(Matsushita)
C4: controlled collapse chip connection
ACF: anisotropic conductive film
ACP(ACA): anisotropic conductive Adhesive paste
Various flip chip technologies
工艺制程
PS: WIT ( Wire interconnect technology)
TAB(Tape- automated bonding)
工艺制程
SBB Process
工艺制程
C4: Controlled Collapse Chip Connection Process
工艺制程
ACP: Anisotropic Conductive Paste Process
工艺制程
ACF: Anisotropic Conductive Film Process
工艺制程
工艺制程
Wafer Bump
工艺制程
Metal bump method
工艺制程
1. 蒸镀 Evaporation
2. 溅镀 Sputter
3. 电镀 Electroplating
4. 印刷 Printed solder paste bump
5. 锡球焊接 Solder ball bumping or Stud bump bonding (SBB)
6.无电镀镍 Electroless nickel technologies
Material of solder bump
工艺制程
1.95Sn/5Pb,97Sn/3Pb 高温锡铅合金
2. 63Sn/37Pb 低温锡铅合金
3. Ni 镍
4. Au 金
5.Cu 铜
Wafer bump (Printed method) Process:Wafer clean
工艺制程
Silicon Wafer arrives with an aluminum based final metal pad and die passivation. Wafer can be probed prior to bumping.
Wafer Bump (Printed method) Process: Sputter UBM
工艺制程
The Under Bump Metallurgy is added by FCT through sputtered layers of Al,Ni-V,&Cu
Wafer Bump (Evaporation method)
UBM consist 3 layer:
1. Adhesion layer : Ti,Cr,TiW 提供铝垫(Al pad)与护层(Passivation layer)有较强之黏着性
2. Wetting layer:Ni,Cu,Mo,Pt 高温回焊时锡球可完全沾附而成球
3. Protective layer:Au 保护 Ni,Cu等免于被氧化.
Process:Photo-resist
工艺制程
Apply photoresist, Pattern and develop
Process: Etch UBM
工艺制程
Etch to form UBM cap
Process: Print solder paste & reflow
工艺制程
Deposit solder paste and reflow to form bump
Process: Inspection
工艺制程
Sample measure bump height, bump shear and bump resistance.
The typical size of a bump before reflow :
1. Evaporative bumps are 125 mils in diameter and 100 mils high.
2. Plated bumps are 125 - 175 mils in diameter and 25 -100 mils high.
工艺制程
工艺制程
工艺制程
工艺制程
上芯片流程Flip Chip flow
工艺制程
上芯片流程Flip Chip flow
工艺制程
工艺制程
Why do you need to underfill
填胶制程  Under-fill
1. 毛细作用型 Capillary type):
利用毛细力造成胶材之流动.
2. 异方向导电胶(Anisotropic conductive adhesive):
低温制程,分膏状(paste)和膜状(film)
3. 前置型(Pre-applied type):
小尺寸芯片(<6mm),点胶(Die attachment)后再回焊(Reflow)
制程与材料之限制:
1. 加强快速填胶与固化能力
2. 提升其界面之黏着力
3. 较低的吸水率
4. 提升低锡铅球间距内的流动性
5. 加强可重工性(rework)
工艺制程
工艺制程
Polymide passivation Evaporative solder bumping process
UBM:Cr/Cr-Cu/Cu/Au
工艺制程
工艺制程
编辑:黄飞
