| 属性 | 参数值 |
| 型号 | MAX17498BATE+CER |
| 制造商 | Maxim Integrated |
| Mfr | Maxim Integrated |
| 系列 | - |
| 包装 | Tube |
| 零件状态 | Active |
| 输出 Isolation | Either |
| 内部开关 | Yes |
| Voltage - Breakdown | - |
| Topology | Boost, Flyback |
| Voltage - Start Up | - |
| 电压 - 供电 (Vcc/Vdd) | 4.5V ~ 36V |
| Duty Cycle | 92% |
| 频率 - Switching | 500kHz |
| 功率 (Watts) | - |
| 故障保护 | Current Limiting, Over Voltage |
| Control 特性 | EN, 功率 Good, Soft Start |
| 工作温度 | -40°C ~ 125°C (TJ) |
| 封装/外壳 | 16-WFQFN Exposed Pad |
| 供应商器件封装 | 16-TQFN (3x3) |
| 安装类型 | Surface Mount |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
