RT-Thread vsnprintf来替代rt_vsnprintf来打印浮点
前言
有童鞋说在gcc下,vsnprintf来替代rt_vsnprintf来打印浮点会引发死机
经过实际验证,没有发现死机
但并不建议直接用vsnprintf来替代rt_vsnprintf,打印浮点多半用于调试,可以独立成一个专门的打印函数
vsnprintf只是用于把浮点格式化到字符串,只要字符串长度不溢出,理论上不会造成死机
如果发现死机,需要确认打印的环境,如中断中,尤其在串口输出的情况下
测试例程
RT-Thread Studio arm-none-eabi-gcc 环境:未发现死机现象
Keil MDK5 环境:未发现死机现象
cygwin gcc 环境:未发现死机现象
可以正常的用于浮点数的调试打印
Copyright (c) 2006-2018, RT-Thread Development Team
SPDX-License-Identifier: Apache-2.0
Change Logs:
Date Author Notes
2018-11-06 SummerGift change to new framework
#include
#include
#include
#include "drv_gpio.h"
defined the LED0 pin: PA5 /
#define LED0_PIN GET_PIN(A, 5)
#include
#define DBG_BUFF_MAX_LEN 256
debug print : support float double */
int dbg_printf(const char fmt, ...)
va_list args;
static char rt_log_buf[DBG_BUFF_MAX_LEN] = { 0 };
va_start(args, fmt);
int length = vsnprintf(rt_log_buf, sizeof(rt_log_buf) - 1, fmt, args);
rt_kputs(rt_log_buf);
return length;
int main(void)
double a = 334455.00123345;
double b = 667788.14234234;
dbg_printf("double a = %lfrn", a);
int count = 1;
set LED0 pin mode to output */
rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT);
while (count++)
rt_pin_write(LED0_PIN, PIN_HIGH);
dbg_printf("double a + b = %lfrn", a+b+count);
rt_thread_mdelay(1000);
rt_pin_write(LED0_PIN, PIN_LOW);
rt_thread_mdelay(2000);
return RT_EOK;
cygwin的测试
/ vsnprintf example /
include
include
/ debug print : support float double /
int dbg_printf(const char *fmt, …)
va_list args;
printf("%srn", rt_log_buf);
return length;
int main ()
double a = 123453.0001444;
dbg_printf(“%lf”, a);
return 0;
## 输出效果
```c
msh >
- RT -     Thread Operating System
 / |      4.1.0 build Feb  3 2022 21:11:28
 2006 - 2022 Copyright by RT-Thread team
double a + b = 1002245.143576
msh >double a + b = 1002246.143576
double a + b = 1002247.143576
double a + b = 1002248.143576
double a + b = 1002249.143576
double a + b = 1002250.143576
double a + b = 1002251.143576
double a + b = 1002252.143576
double a + b = 1002253.143576
double a + b = 1002254.143576
double a + b = 1002255.143576
double a + b = 1002256.143576
double a + b = 1002257.143576
double a + b = 1002258.143576
double a + b = 1002259.143576
double a + b = 1002260.143576
double a + b = 1002261.143576
cygwin的打印:
$ ./a.exe
123453.000144
小结
rt_kprintf,采用不依赖标准C库的方式,主要目的是为了减少ROM(Flash)的占用
如果实际中需要浮点打印(如打印到串口、打印到文件),可以基于vsnprintf编写一个简单的全功能格式打印函数
RT-Thread ulog可以开启浮点支持,开启后使用:vsnprintf
