秒验 REST API 手机号码置换接口
功能说明
  • 提交客户端获取到的token、opToken等数据,验证后返回手机号码
调用地址
  • POST https://identify-verify.dutils.com/auth/auth/sdkClientFreeLogin
请求头
  • Content-Type :application/json
  • appkey:xxxxxxxxxx
入参说明
字段类型说明必传
appkeyStringapp标识Y
tokenString客户端的tokenY
opTokenString客户端返回的运营商tokenY
operatorString客户端返回的运营商,CMCC:中国移动通信, CUCC:中国联通通讯, CTCC:中国电信Y
signString签名(MD5(所有参数使用key的正序,通过a=b&b=c+appSecret组成))Y
timestamplong当前时间戳(毫秒)Y
md5StringAPK的md5签名,例:e4caa1a08ba0570b5c1290b1a0bc9252N
加密示例
  • 参数
"appkey" - > "2f2d7j9wf8a40"
"opToken" - > "f630dwff2f8f209c60a6449cf971ad50b3e83f4620a1536252457229836325"
"operator" - > "CUCC"
"token" - > "0: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"
"timestamp" - > 1655190952281
"appSecret" - > "9abee316611wd9ff607feb9f2c496338"
  • 排序结果
appkey=2f2d7j9wf8a40&opToken=f630dwff2f8f209c60a6449cf971ad50b3e83f4620a1536252457229836325&operator=CUCC×tamp=1655190952281&token=0: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
  • 拼接appSecret
appkey=2f2d7j9wf8a40&opToken=f630dwff2f8f209c60a6449cf971ad50b3e83f4620a1536252457229836325&operator=CUCC×tamp=1655190952281&token=0: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9abee316611wd9ff607feb9f2c496338
  • 计算MD5结果
sign - > 3f1991b27b1c86a32e661eabdd3d1f5a
请求示例
curl --location --request POST 'http://identify.verify.mob.com/auth/auth/sdkClientFreeLogin'
--header 'Content-Type: application/json'
--data-raw '{"token":"0: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","opToken":"a53c2dc92083cb1375218a0f1dd35e0050bb26e40ba0a1536204920384995379", "appkey": "2f2d7a68f8a40", "operator": "CUCC",  "sign": "576ec00ac6ad80a2d0a92872d748e82b", "timestamp": 1655094782181}'
响应示例
请求成功
    "error": null,
    "res": "ZfukzNuB5oKbxBKxK9MoYFzr1IDZ0Z/i+xLYyq/JCAmi24DPYHdGeUqxE6OjQuP3VY1c76CyfoU=",
    "seqid": "456484936150429696",
    "status": 200
请求失败
    "status": 4119342,
    "res": null,
    "error": "签名错误",
    "seqid": "null"
  • 响应参数
keydescription
error返回码描述
res加密后的JSON串,含有返回的手机号,需进行DES解密
seqid流水号,请求出错时可能为空
status返回码
数据解密
返回体中的res数据需要使用appSecet解密
解密方式
DES/CBC/PKCS5Padding
偏移量 00000000
使用base64转码
字段说明
    "isValid":1,
    "phone": "13888888888""valid":"true"
字段类型必传说明
isValidintegerY验证状态,1:成功, 2:失败
phonestringY返回手机号
validbooleanY验证状态 true 成功 false:失败
示例代码
Java
import java.security.Key;
import java.security.spec.AlgorithmParameterSpec;
import javax.crypto.Cipher;
import javax.crypto.SecretKey;
import javax.crypto.SecretKeyFactory;
import javax.crypto.spec.DESKeySpec;
import javax.crypto.spec.IvParameterSpec;
public class DES {
    public static final String ALGORITHM = "DES";
    public static final String PADDING = "DES/CBC/PKCS5Padding";
    private static final byte[] DEFAULT_INITIALIZATION_VECTOR = ("00000000".getBytes());
    private String padding = PADDING;
    private AlgorithmParameterSpec paramSpec;
    public DES(String padding, byte[] initializationVectorBytes) {
        this.padding = padding;
        this.paramSpec = new IvParameterSpec(initializationVectorBytes);
    public byte[] decodeBytes(byte[] data, byte[] key) throws Exception {
        Key secretKey = getKey(key);
        Cipher cipher = Cipher.getInstance(padding);
        cipher.init(Cipher.DECRYPT_MODE, secretKey, paramSpec);
        return cipher.doFinal(data);
    private static Key getKey(byte[] key) throws Exception {
        DESKeySpec dks = new DESKeySpec(key);
        SecretKeyFactory keyFactory = SecretKeyFactory.getInstance(ALGORITHM);
        SecretKey secretKey = keyFactory.generateSecret(dks);
        return secretKey;
    public static byte[] decode(byte[] data, byte[] key) throws Exception {
        return decode(data, key, DEFAULT_INITIALIZATION_VECTOR);
    public static byte[] decode(byte[] data, byte[] key, byte[] ivBytes) throws Exception {
        DES des = new DES(PADDING, ivBytes);
        return des.decodeBytes(data, key);
import java.util.Base64;
public abstract class Base64Utils {
    public Base64Utils() {
    public static byte[] decode(byte[] src) {
        return src.length == 0 ? src : Base64.getDecoder().decode(src);
返回码
错误码说明
5119104解密失败
5119105服务错误
4119301数据校验失败
4119302数据不存在
5119302数据不存在
4119303数据已经存在
5119303数据已经存在
4119310token未找到
5119310token未找到
4119311token非法
4119330App没有初始化
4119331AppSecret错误
5119341余额不足
5119501未知的运营商类型
5119511AppKey每分钟验证次数超过限制
5119513未审核的包名每天验证数量超过限制
4119521包名没有配置
5119531AppKey在黑名单中
5119546[免密登录][APP每分钟]超限
5119507免密登录失败
5119509免密获取TOKEN失败
4119342签名错误
4119343timestamp错误
5119601未设置价格
