RK3568适配RK628 RGB to HDMI
RK628是一款多功能视频桥接芯片,支持多种显示接口的转换。本文基于RK3568平台,分享使用RK628桥接芯片实现RGB信号转换为HDMI输出的适配过程
芯片
 IDO-SOM3568-V2采用 Rockchip 新一代 64 位处理器 RK3568(四核A55, 主频高达 2.0GHz, 22nm 工艺),集成双核心架构 GPU 以及高效能 NPU;最大支持 8GB 内存;内置独立的 NPU,32Bit位宽LPDDR4/LPDDR4x,频率最高可达1600MHz,支持全链路ECC ,支持Android 11,Ubuntu , Debian,OpenHamoney,麒麟OS等多种系统。
产品规格书:IDO-SOM3568-V2(金手指) 产品手册
芯片
硬件连接
RK628与RK3568的硬件连接,主要有以下几点:
24MHz时钟:给RK628提供时钟信号;
I2C:用于RK3568与RK628之间的控制通信;
I2S:用于音频信号传输;
RGB:给RK628显示信号源;
其它GPIO:控制供电和复位。
添加驱动
本文调试使用的是RK的rk628-for-all v21驱动。将驱动补丁文件添加至 kernel/drivers/misc/rk628/ 目录。
在原有的驱动文件中添加
kernel/drivers/misc/Kconfig
source "drivers/misc/rk628/Kconfig"
kernel/drivers/misc/Makefile
obj-y += rk628/
添加设备树配置
dts配置分显示和音频两部分,显示部分在i2c中添加rk628节点,并将其与rgb绑定;音频部分使用i2s通信,新增一路simple-audio-card。
  rk628_hdmi_sound: rk628-hdmi-sound {
    compatible = "simple-audio-card";
    simple-audio-card,format = "i2s";
    simple-audio-card,name = "rk628-hdmi-sound";
    status = "okay";
    simple-audio-card,cpu {
      sound-dai = <&i2s1_8ch>;
    simple-audio-card,codec {
      sound-dai = <&rk628>;
&i2s1_8ch {
  status = "okay";
  rockchip,clk-trcm = <1>;
  pinctrl-names = "default";
  pinctrl-0 = <&i2s1m1_sclktx
         &i2s1m1_lrcktx
         &i2s1m1_sdo0>;
&i2c1 {
  status = "okay";
  clock-frequency = <400000>;
  rk628: rk628@50 {
    compatible = "rockchip,rk628";
    reg = <0x50>;
    interrupt-parent = <&gpio1>;
    interrupts = ;
    enable-gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>;
    reset-gpios = <&gpio3 RK_PC4 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&refclk_pins>;
    assigned-clocks = <&pmucru CLK_WIFI>;
    assigned-clock-rates = <24000000>;
    clock-names = "soc_24M";
    #sound-dai-cells = <0>;
    rk628,rgb-in;
    rk628,hdmi-out;
    mode-sync-pol=<0>;
    status = "okay";
    port {
      rgb_in_hdmi: endpoint {
        remote-endpoint = <&rgb_out_hdmi>;
&rgb {
  status = "okay";
  ports {
    port@1 {
      reg = <1>;
      rgb_out_hdmi: endpoint {
        remote-endpoint = <&rgb_in_hdmi>;
&rgb_in_vp2 {
  status = "okay";
&route_rgb {
  status = "okay";
  connect = <&vp2_out_rgb>;
&pinctrl {
  refclk {
    /omit-if-no-ref/
    refclk_pins: refclk-pins {
      rockchip,pins =
        /* refclk_ou */
        <0 RK_PA0 1 &pcfg_pull_none>;
运行测试
修改驱动编译,更新内核后;插入HDMI显示器,正常的情况下可以成功显示
查看显示参数
cat /sys/kernel/debug/dri/0/summary
芯片
声卡注册情况如下,可通过播放音乐来测试HDMI是否有声音输出
芯片
问题排查
确认供电和复位时序是否正常
测量软件24MHz时钟信号是否正常输出
芯片
