linaro@linaro-alip:~$ docker -v Docker version 24.0.2, build cb74dfc linaro@linaro-alip:~$
验证
linaro@linaro-alip:~$ sudo docker run hello-world Unable to find image 'hello-world:latest' locally latest: Pulling from library/hello-world 70f5ac315c5a: Pull complete Digest: sha256:a13ec89cdf897b3e551bd9f89d499db6ff3a7f44c5b9eb8bca40da20eb4ea1fa Status: Downloaded newer image for hello-world:latest [ 1228.015617] docker0: port 1(veth9b45dd3) entered blocking state [ 1228.015735] docker0: port 1(veth9b45dd3) entered disabled state [ 1228.017169] device veth9b45dd3 entered promiscuous mode [ 1228.027619] IPv6: ADDRCONF(NETDEV_UP): veth9b45dd3: link is not ready [ 1228.343879] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation [ 1228.596774] eth0: renamed from vethc46e61e [ 1228.611961] IPv6: ADDRCONF(NETDEV_CHANGE): veth9b45dd3: link becomes ready [ 1228.612131] docker0: port 1(veth9b45dd3) entered blocking state [ 1228.612147] docker0: port 1(veth9b45dd3) entered forwarding state [ 1228.612346] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
Hello from Docker! This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps: 1. The Docker client contacted the Docker daemon. 2. The Docker daemon pulled the "hello-world" image from the Docker Hub. (arm64v8) 3. The Docker daemon created a new container from that image which runs the executable that produces the output you are currently reading. 4. The Docker daemon streamed that output to the Docker client, which sent it to your terminal.
To try something more ambitious, you can run an Ubuntu container with: $ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID: https://hub.docker.com/
For more examples and ideas, visit: https://docs.docker.com/get-starte
