nuere-简单小巧快速的字符串解析库
neure是一个简单小巧的字符串解析库, 我在开发aopt时为了优化编译时间而开发的替代regex的库. 目前代码架构非常简单, 性能上比regex更快, 和nom的速度不相上下. 设计上参考了regex. Readme有一个和regex比较的代码,可以尝试一下.
https://github.com/araraloren/neure
补充一个和nom例子比较的代码,开启lto=fat时性能不相上下
use neure::*;
use nom::{
    bytes::{tag, take_while_m_n},
    combinator::map_res,
    sequence::tuple,
    IResult,
#[derive(Debug, PartialEq)]
pub struct Color {
    pub red: u8,
    pub green: u8,
    pub blue: u8,
fn from_hex(input: &str) -> Result {
    u8::from_str_radix(input, 16)
fn is_hex_digit(c: char) -> bool {
    c.is_digit(16)
fn hex_primary(input: &str) -> IResult<&str, u8> {
    map_res(take_while_m_n(2, 2, is_hex_digit), from_hex)(input)
fn hex_color(input: &str) -> IResult<&str, Color> {
    let (input, _) = tag("#")(input)?;
    let (input, (red, green, blue)) = tuple((hex_primary, hex_primary, hex_primary))(input)?;
    Ok((input, Color { red, green, blue }))
fn main() -> Result<(), Box> {
    let mut storer = SpanStorer::new(1);
    let color_str = "#2F14DF";
    let parser = |storer: &mut SpanStorer, str: &str| -> Result<(), neure::Error> {
        let pound = neure!('#');
        let hex = neure!(['0' - '9' 'A' - 'F']{2});
        let mut ctx = CharsCtx::default().with_str(str);
        ctx.reset();
        ctx.try_mat(£)?;
        ctx.try_cap(0, storer, &hex)?;
        Ok(())
    measure(100000, 100000, || {
        if parser(storer.reset(), color_str).is_ok() {
            let mut strs = storer.substrs(color_str, 0).unwrap();
            assert_eq!(
                Color {
                    red: u8::from_str_radix(strs.next().unwrap(), 16).unwrap(),
                    green: u8::from_str_radix(strs.next().unwrap(), 16).unwrap(),
                    blue: u8::from_str_radix(strs.next().unwrap(), 16).unwrap(),
                Color {
                    red: 47,
                    green: 20,
                    blue: 223,
            1
        } else {
        if hex_color("#2F14DF").unwrap()
                Color {
                    red: 47,
                    green: 20,
                    blue: 223,
            1
        } else {
    Ok(())
pub fn measure(n: usize, size: usize, mut f: impl FnMut() -> i32) {
    use std::Instant;
    let start = Instant::now();
    let mut sum = 0;
    for _ in 0..n {
        sum += f();
    let time = start.elapsed();
    println!(
        "Size = {size}, Cost time {} with test {} times: {} --> {}",
        time.as_secs_f64(),
        n,
        time.as_secs_f64() / n as f64,
        sum,
 审核编辑:汤梓红
