N32L40XCL-STB开发板模块评测任务大挑战之测试CAN
在applicantions文件夹下新建test_can.c,内容如下:
程序清单:这是一个 CAN 设备使用例程
例程导出了 can_sample 命令到控制终端
命令调用格式:can_sample bxcna
命令解释:命令第二个参数是要使用的 CAN 设备名称,为空则使用默认的 CAN 设备
程序功能:通过 CAN 设备发送一帧,并创建一个线程接收数据然后打印输出。
#include "can_dewen.h"
#include
#include "rtdevice.h"
#define CAN_DEV_NAME "bxcan" /
CAN 设备名称 /
static struct rt_semaphore rx_sem; /
用于接收消息的信号量 /
static rt_device_t can_dev; /
CAN 设备句柄 /
接收数据回调函数 /
static rt_err_t can_rx_call(rt_device_t dev, rt_size_t size)
CAN 接收到数据后产生中断,调用此回调函数,然后发送接收信号量 /
rt_sem_release(&rx_sem);
return RT_EOK;
int can_send(rt_uint32_t humi,rt_uint32_t temp)
struct rt_can_msg msg = {0};
rt_err_t res;
rt_size_t size;
msg.id = 0x78; /
ID 为 0x78 /
msg.ide = RT_CAN_STDID; /
标准格式 /
msg.rtr = RT_CAN_DTR; /
数据帧 /
msg.len = 8; /
数据长度为 8 /
待发送的 8 字节数据 /
msg.data[0] = (uint8_t)(temp/100);
msg.data[1] = (uint8_t)(temp%100);
msg.data[2] = (uint8_t)(humi/100);
msg.data[3] = (uint8_t)(humi%100);
msg.data[4] = 0x44;
msg.data[5] = 0x55;
msg.data[6] = 0x66;
msg.data[7] = 0x77;
发送一帧 CAN 数据 /
size = rt_device_write(can_dev, 0, &msg, sizeof(msg));
if (size == 0)
rt_kprintf("can dev write data failed!n");
return res;
static void can_rx_thread(void parameter)
int i;
rt_err_t res;
struct rt_can_msg rxmsg = {0};
设置接收回调函数 /
rt_device_set_rx_indicate(can_dev, can_rx_call);
#ifdef RT_CAN_USING_HDR
struct rt_can_filter_item items[5] =
RT_CAN_FILTER_ITEM_INIT(0x100, 0, 0, 0, 0x700, RT_NULL, RT_NULL), /
std,match ID:0x1000x1ff,hdr 为 - 1,设置默认过滤表 /
RT_CAN_FILTER_ITEM_INIT(0x300, 0, 0, 0, 0x700, RT_NULL, RT_NULL), /
std,match ID:0x300
0x3ff,hdr 为 - 1 /
RT_CAN_FILTER_ITEM_INIT(0x211, 0, 0, 0, 0x7ff, RT_NULL, RT_NULL), /
std,match ID:0x211,hdr 为 - 1 /
RT_CAN_FILTER_STD_INIT(0x486, RT_NULL, RT_NULL), /
std,match ID:0x486,hdr 为 - 1 /
{0x555, 0, 0, 0, 0x7ff, 7,} /
std,match ID:0x555,hdr 为 7,指定设置 7 号过滤表 /
struct rt_can_filter_config cfg = {5, 1, items}; /
一共有 5 个过滤表 /
设置硬件过滤表 /
res = rt_device_control(can_dev, RT_CAN_CMD_SET_FILTER, &cfg);
RT_ASSERT(res == RT_EOK);
#endif
while (1)
hdr 值为 - 1,表示直接从 uselist 链表读取数据 /
rxmsg.hdr = -1;
阻塞等待接收信号量 /
rt_sem_take(&rx_sem, RT_WAITING_FOREVER);
从 CAN 读取一帧数据 /
rt_device_read(can_dev, 0, &rxmsg, sizeof(rxmsg));
打印数据 ID 及内容 /
rt_kprintf("ID:%x", rxmsg.id);
for (i = 0; i < 8; i++)
rt_kprintf("%2x", rxmsg.data[i]);
rt_kprintf("n");
int can_sample(void)
rt_err_t res;
rt_size_t size;
rt_thread_t thread;
char can_name[RT_NAME_MAX];
rt_strncpy(can_name, CAN_DEV_NAME, RT_NAME_MAX);
查找 CAN 设备 /
can_dev = rt_device_find(can_name);
if (!can_dev)
rt_kprintf("find %s failed!n", can_name);
return RT_ERROR;
初始化 CAN 接收信号量 /
rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO);
设置 CAN 通信的波特率为 500kbit/s
res = rt_device_control(can_dev, RT_CAN_CMD_SET_BAUD, (void )CAN500kBaud);
以中断接收及发送方式打开 CAN 设备 /
res = rt_device_open(can_dev, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX);
创建数据接收线程 /
thread = rt_thread_create("can_rx", can_rx_thread, RT_NULL, 1024, 25, 10);
if (thread != RT_NULL)
rt_thread_startup(thread);
else
rt_kprintf("create can_rx thread failed!n");
msg.id = 0x78; /
ID 为 0x78 /
标准格式 /
数据帧 /
msg.len = 8; /
数据长度为 8 /
待发送的 8 字节数据 /
msg.data[0] = 0x00;
msg.data[1] = 0x11;
msg.data[2] = 0x22;
msg.data[3] = 0x33;
msg.data[4] = 0x44;
msg.data[5] = 0x55;
msg.data[6] = 0x66;
msg.data[7] = 0x77;
发送一帧 CAN 数据 /
if (size == 0)
return res;
导出到 msh 命令列表中 */
MSH_CMD_EXPORT(can_sample, can device sample);
然后编译下载到开发板。
硬件准备
CAN分析仪
CAN——TTL模块
调试步骤
硬件接好 TTL——CAN TX ————开发板PB9,TTL——CAN RX————开发板PB8
通过集线器把CAN分析仪CAN——H 与TTL的CAN——H 相接 CAN——L与CAN——L接好。
通过串品终端执行can_sample:
TTL电路
打开CAN分析仪上位机,自动OBD识别,识别到了500K的CAN总,同时也接收到了开发板发送的认证数据。发送数据,在开发板的串口终端也成功接收并打印出来:
TTL电路
【总结】
国民技术在RT-Thread上的生态非常好,可以快速的实现对外设的驱动。
