香蕉派 BPI-W2 Nas 开源路由开发板采用Realtek RTD1296设计
banana pi
Banana PI BPI-W2是一个高度集成的多媒体网络路由器,可用于高无线性能、Nas路由,家庭娱乐、家庭自动化等…
BPI-W2集成了一个四核ARM cortex- a53 MPcore,运行到1.5 ghz,路由器还包括各种外设,包括HDMI RX/ TX,Mini DP,PCIe2.0,pcie1.1 & sdio,M.2接口、USB2.0 USB3.0端口,SATA端口,2 Gbps端口千兆以太网端口,也支持802.11 ac / n WLAN连接通过PCI-e接口连接,BPI-W2可以运行Android6.0。它还可以运行OpenWRT,Debian linux,Ubuntu linux,Raspbian和其他操作系统。它还可以运行OpenWRT,Debian linux,Ubuntu linux,Raspbian和其他操作系统。
BPI-W2的大小与BPI-R2的尺寸大小相同,它可以很容易的运行它支持1080P高清视频输出,GPIO与Raspberry PI 3 兼容。
硬件接口示意图:
banana pi
硬件规格:
香蕉派 BPI-W2 硬件规格表
Soc芯片Realtek RTD1296 quad-core ARM A53
GPUMali T820 MP3 GPU
SDRAM2GB DDR4 (shared with GPU)
供电12V @ 2A via DC power 5.0mmx2.0mm jack
Low-level peripherals40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
有线网口2x 10/100/1000Mbps Ethernet
Wifi无线/Bluetooth蓝牙**Option** ,not support onboard WIFI & BT
RGMII1 RGMII interface with PIN
存储MicroSD (TF) card; 2 native SATA 3 6Gbps ;eMMC;SIM card slot
显示HDMI (Type A) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP
Video decoder/encodeThe Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on.
Aideo decodingAudio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing
Audiosupport two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in
HDMI 输入/输出1* HDMI 2.0a out port and 1* HDMI 2.0a In port
Audio outputs/InputsHDMI, I2S audio,Audio micro out, Audio out/in with PIN define
M.2 KEY E:PCIE 2.0/USB 2.01 pcie 2.0 interface
M.2 KEY E:PCIe 1.1 / SDIO / USB 2.01 pcie 1.1 and SDIO interface
USB 3.01x USB 3.0 host
USB 2.02x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN
M.2 KEY B1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot
Mini DP1* Mini DP
TYPE C1 type C interface
RTC 实时时钟供电RTC battery power interface
按键Reset button, Power button, U-boot button
Led灯Red, Green, Blue
红外IR 红外遥控接收
尺寸148 mm × 100.5mm
重量100g
