香蕉派 BPI-M5单板计算机采用Amlogic S905x3 芯片设计,4G内存和16G eMMC存储
智能硬件
Banana Pi BPI-M5是新一代单板计算机设计,采用Amlogic S905X3四核Cortex-A55 (2.0xxGHz)处理器。MP2 GPU(650Mhz)。支持4GB LPDDR4和16G eMMC板载存储。它有4个USB 3.0端口,1个千兆网口。 905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持4K视频解码和4K视频输出,运行开放的安卓9.0系统和Linux系统。
硬件接口示意图:
智能硬件
硬件规格:
香蕉派BPI-M5 硬件规格表
CPUAmlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz)
GPUMali-G31 MP2 GPU with 4 x Execution Engines (650Mhz)
Memory4 GB LPDDR4
StorageMicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB
Network10/100/1000 Mbit/s Ethernet
Video Output(s)1 x HDMI 2.0 (up to 4K@60Hz with HDR, CEC, EDID)
Audio Output(s)3.5mm jack and 1 x HDMI digital output
USB portsUSB 3.0 PORT (x4)
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
SwitchesReset, Power and U-boot
LEDPower Status and Activity status
Power Source5 volt @3A via Micro USB (TYPE C)
Size & Weight92x60mm, 48g
OSAndroid and Linux
BPI-M2 Pro ,BPI-M5 , Odroid C4 , 树莓派4 规格比较表
BPI-M2 Pro VS BPI-M5 VS Odroid C4 VS RPI 4
香蕉派 BPI-M2 Pro
香蕉派 BPI-M5
Odroid C4树莓派 4
ProcessorAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzBroadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
GPUMali-G31 MP2 GPUMali-G31 MP2 GPUMali-G31 MP2 GPUBroadcom VideoCore VI
RAM2GB LPDDR44GB LPDDR4DDR4 4GiB with 32-bit bus width2GB, 4GB or 8GB LPDDR4-3200 SDRAM
Storagemicro SD card slot & 16GB eMMC flash on boardmicro SD card slot & 16GB eMMC flash on boardmicro SD card slot , eMMC connector for optionmicro SD card slot, non EMMC
Network1 GbE ,WiFi&BT5.0 onbardGbE ,Optional WiFi USB dongleGbEGbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
Video Output1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)2 × micro-HDMI 2.0
Audio Output1 x HDMI digital output3.5mm jack and 1 x HDMI digital outputOptional SPDIF optical output3.5 mm analogue audio-video jack
DSIN/AN/AN/A2-lane MIPI DSI display port
CSIN/AN/AN/A2-lane MIPI CSI camera port
USBUSB 3.0 x 2 1 Micro USB 2.0USB 3.0 x 4 TYPE CUSB 3.0 x 4, 1 x Micro USB 2.0 port (OTG)2 USB 3.0 ports; 2 USB 2.0 ports;
Power5 volt @3A via DC power5 volt @3A via Micro USB (TYPE C)1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm)5V DC via USB-C connector (minimum 3A*)
IRYesYesYesN/A
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND).40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND).40 x GPIO pins40-pin GPIO header, populated
ButtonReset, user and U-bootReset, user and U-bootN/AN/A
LEDPower Status and Activity statusPower Status and Activity statusPower Status and Activity statusPower Status and Activity status
Dimensions & weight65mm x 65mm,58g85mm x 56mm, 48g85mm x 56mm 59g88 mm × 58 mm, 46 g
System SupportLinux & AndroidLinux & AndroidLinux & AndroidLinux & Android
