香蕉派 BPI-M2+ 物联网开发板采用全志H3芯片设计,1GB DDR3 RAM ,8GB eMMC
Banana PI BPI-M2+ 是一款四核高性能单板计算机,采用全志H3处理器。Banana PI BPI-M2+兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 .
Banana PI BPI-M2+硬件:全志H3四 核处理器,1GB DDR3内存,千兆以太网口,板载无线与蓝牙,板载8G EMMC flash,2 USB 接口 流畅运行Android4.4。Banana PI BPI-M2+体积精小 仅为65*65mm,轻松运行《雷神之锤三:竞技场》这样的游戏,支持4K高清视频输出,GPIO兼容Raspberry PiB+并能运行其ROM Image。
Hardware interface:
全志H3
Hardware spec:
香蕉派 BPI-M2+( BPI-M2 Plus)硬件规格
CPUH3 Quad-core Cortex-A7 H.265/HEVC 4K
GPUMali400MP2 GPU @600 MHz,Supports OpenGL ES 2.0
Memory1GB DDR3 (shared with GPU)
Flash8GB eMMC flash onboard
Network10/100/1000 Ethernet
WIFI&BTSDIO AP6212 for Wifi &BT 4.0(option AP6181 AP6335)
Video InputA CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL, 3 Supports SM pixel camera sensor, 4 Supports video capture solution up to 1080p@30fps
Video OutputsSupports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function, Integrated CVBS, Supports simultaneous output of HDMI and CVBS
Audio OutputsHDMI
Power5V/2A DC input can supply power, but USB OTG input don’t supply power
USB 2.0 portstwo USB 2.0 HOST, one USB 2.0 OTG
GPIO40 Pins Header,compatible with Raspberry Pi B+
LEDPower led & Status led
IRIR input on board
OSAndroid, Ubuntu, Debian, Raspberry Pi Image
全志H3
BPI-M2+外壳设计:
全志H3
