基于CW32L083评估板的简易低功耗功能测试
使用CW32L083的评估板完成简易低功耗例程实验。
功能定义如下:在正常运行模式下,LED1每1s翻转一次。当按下KEY2按键时,LED1灯灭,进入低功耗模式。当再次按下KEY2后,重新回到正常的运行模式,LED1每一秒翻转一次。通过以上方式可以测量,正常运行模式与低功耗模式的功耗。
led
查看CW32L083评估板的原理图,KEY2按键对应的GPIO口为PA05口,当键按下时,PA05读入为低电平。LED1指示灯对应的GPIO口为PC03,当PC03端口输出高电平时,指示灯亮。
配置为引脚输入,并开启下降沿中断,在中断服务函数改变gKeyStatus的值,从而使得MCU在main中进入低功耗休眠模式。
主要程序代码如下
volatile uint8_t gKeyStatus;
volatile uint32_t gFlagWakeUpIrq = 0;
int main(void)
    RCC_HSI_Enable( RCC_HSIOSC_DIV6); //配置系统时钟为HSI 8M
    InitTick(8000000ul); //初始化SysTick
    LED_Init();         //LED初始化
    BSP_PB_Init();  //按键初始化
    while (1)
       gKeyStatus = 0;//在没有进入低功耗模式前,PC03每间隔1s翻转一次状态
       do
       PC03_TOG();         //翻转LED1
       SysTickDelay(1000);   //延迟1s.
       } while (gKeyStatus == 0);
       PC03_SETLOW();         //PC03置低
       DeepSleepModeTest();    //进入深度睡眠模式
//按键初始化,设置PA05沿下降沿触发中断
void BSP_PB_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    //打开GPIOA时钟
    REGBITS_SET(CW_SYSCTRL->AHBEN, SYSCTRL_AHBEN_GPIOA_Msk);
    GPIO_InitStructure.Pins = GPIO_PIN_5;
    GPIO_InitStructure.Mode = GPIO_MODE_INPUT_PULLUP;
    GPIO_InitStructure.IT = GPIO_IT_FALLING;
    GPIO_Init(CW_GPIOA, &GPIO_InitStructure);
    GPIO_ConfigFilter(CW_GPIOA, GPIO_PIN_5, GPIO_FLTCLK_RC10K);
    //设置GPIOA的中断等级为3
    NVIC_SetPriority(GPIOA_IRQn, 0x03);
    GPIOA_INTFLAG_CLR(GPIOx_ICR_PIN5_Msk );
    NVIC_EnableIRQ(GPIOA_IRQn);
//LED I/O初始化
void LED_Init(void)
    //打开GPIO时钟
    REGBITS_SET(CW_SYSCTRL->AHBEN, SYSCTRL_AHBEN_GPIOC_Msk);
    GPIO_InitStructure.Pins = GPIO_PIN_2 | GPIO_PIN_3;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_Init(CW_GPIOC, &GPIO_InitStructure);
PC03_SETLOW();
PC02_SETLOW();
void DeepSleepModeTest(void)
  GPIO_InitTypeDef GPIO_InitStructure = { 0 };
  PWR_InitTypeDef PWR_InitStructure = { 0 };
  //打开GPIO时钟
  REGBITS_SET(CW_SYSCTRL->AHBEN,SYSCTRL_AHBEN_GPIOA_Msk|
  SYSCTRL_AHBEN_GPIOB_Msk |
  SYSCTRL_AHBEN_GPIOC_Msk | SYSCTRL_AHBEN_GPIOF_Msk);
  GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStructure.IT = GPIO_IT_NONE;
  GPIO_InitStructure.Pins = GPIO_PIN_All;
  GPIO_Init(CW_GPIOB, &GPIO_InitStructure);
  GPIO_Init(CW_GPIOF, &GPIO_InitStructure);
  //关闭GPIO时钟
  REGBITS_CLR(CW_SYSCTRL->AHBEN,SYSCTRL_AHBEN_GPIOA_Msk|
  // 唤醒后自动使用内部高速时钟(HSI)
  RCC_WAKEUPCLK_Config(RCC_SYSCTRL_WAKEUPCLKEN);
  PWR_InitStructure.PWR_Sevonpend = PWR_Sevonpend_Disable;
  PWR_InitStructure.PWR_SleepDeep = PWR_SleepDeep_Enable;
  PWR_InitStructure.PWR_SleepOnExit = PWR_SleepOnExit_Disable;
  PWR_Config(&PWR_InitStructure);
  PWR_GotoLpmMode(); //进入休眠
//GPIOA中断服务函数
void GPIOA_IRQHandler(void)
 if(REGBITS_GET(CW_GPIOA->ISR, GPIOx_ISR_PIN5_Msk) > 0)
        gKeyStatus = 1;
        GPIOA_INTFLAG_CLR(GPIOx_ICR_PIN5_Msk);//清除CW_GPIO中断标志
休眠配置寄存器定义如下
led
上述代码运行时的效果:在未进入低功耗模式之前,LED1每1s翻转一次,通过按键KEY2进入低功耗模式后,LED1灯灭,当再次按下KEY2后,重新回到正常的运行模式,LED1每一秒翻转一次。通过测量可以得到,进入到低功耗模式之后,功耗显著降低。
运行结果如下
从外界给L083开发板供3.3V电,使用常见的万用表测试。
运行模式下LED1指示灯灭时的功耗为2.955MA。
led
运行模式下LED1指示灯亮时的功耗为3.849MA。
led
进入超低功耗模式下功耗为0.64uA。
led
这是本期测试的简易低功耗功能测试,下期我们就用UART来控制深度休眠模式的实现。
  审核编辑:汤梓红
