VCS ICO的主要功能有哪些呢?
ico是vcs提供的用于优化覆盖率的feature;一般用户通过dist solver bofore等约束了变量的随机概率,而ico会在用户约束的基础上,做一些自动“修正”,以此来优化随机激励,提高随机多样性,加速覆盖率收敛,缩短 turn-around time TAT。主要功能包含如下几部分:
1. Prognosis: 用于查看当前平台是否适用ico,对于都是直接用例测试,没有随机策略的平台,ico并不适用;
2. Auto Bias:利用设定策略,ico会改变原有constraint solver的行为,施加一定 bias 修正随机值;
3. RCA: root cause trace, 用于诊断变量未随机到的bins,是否存在过约束等;
4. Delta-debug: 提供replay复现功能,对比两次结果间的差异;
5. AutoPurge: 当前回归得到的ico database可以用于下一次回归,多次迭代;
ico最主要的功能就是Auto Bias,宣称使用了AI,机器学习ML,增强学习EL等手段,在回归过程中,利用共享case之间的ico database,提高随机多样性;通过一个简单例子演示下:
covergroup cg_data with function sample (input logic valid, logic [7:0] data);
   cpt_value: coverpoint data iff (valid){
      bins zero = {0};
      bins others[] ={[1:31]};
      illegal_bins invalid = {[32:255]};
endgroup
class tr extends uvm_transaction;
   rand logic [7:0] data;
   constraint c_tr { data inside {[0:31]};
                     data dist {0:=1,[1:31]:=100};
endclass
如上,对data的约束中,data=0这一条件的概率很低;
PRJ := $(shell echo $(CURDIR) | sed -r 's|/ico_test/.*|/ico_test|')
export PRJ
all: comp run
all_ico: comp run_ico
SEED := ${SEED}
regress_ico: clean
    mkdir -p ${PRJ}/comp_src;
    cd ${PRJ}/comp_src;
    cp ${PRJ}/Makefile ${PRJ}/comp_src;
    make comp;
    for i in 1 2; do
    mkdir -p ${PRJ}/test_$${i};
    cp ${PRJ}/Makefile ${PRJ}/test_$${i};
    cd ${PRJ}/test_$${i};
    ln -s ${PRJ}/comp_src/simv.daidir simv.daidir;
    ln -s ${PRJ}/comp_src/csrc csrc;
    ln -s ${PRJ}/comp_src/simv simv;
    make run_ico SEED=$${i};
    done
    make cov_merge;
    make crg_report;
regress: clean
    cd ${PRJ}/comp_src;
    make comp;
    for i in 1 2; do
    make run SEED=$${i};
    done
    make cov_merge;
comp:
    vcs -full64
    -kdb -lca
    -debug_access+all
    -ntb_opts uvm
    -sverilog
    -timescale=1ns/1ns
    ${PRJ}/dut.sv
    ${PRJ}/top_tb.sv
    +incdir+${PRJ}
    -l comp.log
run_ico:
    ./simv -l sim.log +ntb_random_seed=${SEED}
    +ntb_solver_bias_mode_auto_config=2
    +ntb_solver_bias_shared_record=${PRJ}/shared_record
    +ntb_solver_bias_wdir=ico_work
    +ntb_solver_bias_test_type=uvm
    +ntb_solver_bias_diag=3
crg_report:
    crg -dir ${PRJ}/shared_record -report rpt-auto -format both -merge merged_db -zip 1 -illegal_group -illegal_attr
run:
verdi:
    verdi  -ssf top_tb.fsdb &
cov_open:
    verdi  -cov -covdir simv_merge.vdb &
cov_merge:
    urg -dir ${PRJ}/test_1/simv.vdb -dir ${PRJ}/test_2/simv.vdb -dbname ${PRJ}/simv_merge.vdb
clean:
    -rm -rf shared_record/ simv* test_* WORK/ *log urgReport/ vdCovLog/ rpt-auto/ merged_db/ comp_src/ novas.*
make regress跑了两个case,第一个case seed=1,第二个caseseed=2; 通过verdi查看覆盖率报告:跑了两次的回归merge结果: 87.5%
机器学习
make regress_ico是使能icofeature,结果: 100%
机器学习
+ntb_solver_bias_diag使能debug信息,默认debug log放在+ntb_solver_bias_wdir指定的ico database下:随机32次,ico影响constrain solver,bias了29次的随机结果;所以对于data=0这样的小概率事件,也随机到了;
机器学习
因为ico会影响constrain solver的随机结果,所以复现时,不仅要保证seed一样,还需要额外指定ico database,这样才能正确复现随机结果。生成当前回归所有用例的merge report: html report会罗列所有随机变量:DIVERSITY通过shannon entropy 香农熵衡量变量的“多样性”;
机器学习在这里插入图片描述
每个变量,ico会自动的划分bins,显示随机详细结果;
ico支持同一个case内多次randomize之间相互影响,也支持一次回归不同case之间相互影响,也可以将本次回归的database作用于下一次回归;
对于ico加速覆盖率收敛的实际效果,博主使用一个block tb亲测效果不太显著;从他人的presentation上看,大概有10%-15%的提升;但是ico对于随机多样性确实是有一定效果的,+ntb_solver_bias_mode_auto可以指定ico对随机的bias力度。
机器学习
 机器学习
如果ico可以通过AI,EL等对功能覆盖率进行反推,缩减重复随机值,那将会大大提高覆盖率收敛,期待后续EDA进一步的"进化”吧。
审核编辑:刘清
