梁山派GD32F450/470-RT-Thread Nano移植(三)
下面是FinSH组件的简介
RT-Thread FinSH 是 RT-Thread 的命令行组件(shell),提供一套供用户在命令行调用的操作接口,主要用于调试或查看系统信息。它可以使用串口 / 以太网 / USB 等与 PC 机进行通信,使用 FinSH 组件基本命令的效果图如下所示:
接收机
老规矩,先给文件
文件信息如下
接收机
移植步骤如下:
1、在keil中添加FinSH源码
打开未移植FinSH的keil工程,按图中将shell勾选上,这会把FinSH组件的源码添加到工程中
接收机
然后在rtconfig.h中将#include “finsh_config.h”的注释释放掉,如下图所示
接收机
2、ringbuffer实现部分
这一部分我也不是很明白,不过也不需要太明白,官方有示例,直接复制过来即可,这个不会因为芯片不同而产生区别,只把它当作一个缓冲区就可以了
移植代码直接粘贴到finsh_port.c文件中即可
接收机
代码如下:
/* 第一部分:ringbuffer 实现部分 */
#include
#include
#define rt_ringbuffer_space_len(rb) ((rb)->buffer_size - rt_ringbuffer_data_len(rb))
struct rt_ringbuffer
rt_uint8_t buffer_ptr;
rt_uint16_t read_mirror : 1;
rt_uint16_t read_index : 15;
rt_uint16_t write_mirror : 1;
rt_uint16_t write_index : 15;
rt_int16_t buffer_size;
enum rt_ringbuffer_state
RT_RINGBUFFER_EMPTY,
RT_RINGBUFFER_FULL,
half full is neither full nor empty /
RT_RINGBUFFER_HALFFULL,
rt_inline enum rt_ringbuffer_state rt_ringbuffer_status(struct rt_ringbuffer rb)
if (rb->read_index == rb->write_index)
if (rb->read_mirror == rb->write_mirror)
return RT_RINGBUFFER_EMPTY;
else
return RT_RINGBUFFER_FULL;
return RT_RINGBUFFER_HALFFULL;
get the size of data in rb
rt_size_t rt_ringbuffer_data_len(struct rt_ringbuffer *rb)
switch (rt_ringbuffer_status(rb))
case RT_RINGBUFFER_EMPTY:
return 0;
case RT_RINGBUFFER_FULL:
return rb->buffer_size;
case RT_RINGBUFFER_HALFFULL:
default:
if (rb->write_index > rb->read_index)
return rb->write_index - rb->read_index;
else
return rb->buffer_size - (rb->read_index - rb->write_index);
void rt_ringbuffer_init(struct rt_ringbuffer rb,
rt_uint8_t pool,
rt_int16_t size)
RT_ASSERT(rb != RT_NULL);
RT_ASSERT(size > 0);
initialize read and write index /
rb->read_mirror = rb->read_index = 0;
rb->write_mirror = rb->write_index = 0;
set buffer pool and size /
rb->buffer_ptr = pool;
rb->buffer_size = RT_ALIGN_DOWN(size, RT_ALIGN_SIZE);
put a character into ring buffer
rt_size_t rt_ringbuffer_putchar(struct rt_ringbuffer rb, const rt_uint8_t ch)
whether has enough space /
if (!rt_ringbuffer_space_len(rb))
return 0;
rb->buffer_ptr[rb->write_index] = ch;
flip mirror /
if (rb->write_index == rb->buffer_size-1)
rb->write_mirror = ~rb->write_mirror;
else
rb->write_index++;
return 1;
get a character from a ringbuffer
rt_size_t rt_ringbuffer_getchar(struct rt_ringbuffer *rb, rt_uint8_t ch)
ringbuffer is empty /
if (!rt_ringbuffer_data_len(rb))
return 0;
put character */
*ch = rb->buffer_ptr[rb->read_index];
if (rb->read_index == rb->buffer_size-1)
rb->read_mirror = ~rb->read_mirror;
rb->read_index = 0;
else
rb->read_index++;
return 1;
3、finsh 移植对接部分
在这一部分我们开始对接finSH组件,对接finSH组件的一个大致流程如下:
当有数据通过串口输入时,进入串口中断,在中断服务函数中将数据存入ringbuffer缓冲区,等数据传输完毕,会触发另一个串口中断并进入中断服务函数,告诉finSH组件数据接收完毕,然后finSH组件开始读取ringbuffer缓冲区中的数据
下面是该部分的移植
3.1 初始化串口中断
在前两篇中,我们已经做好了串口初始化,所以我们在这里直接剪切过来即可,将写图中代码剪切
接收机
粘贴到下图中的位置
接收机
在finsh_port.c文件中引入串口的头文件,如图所示
#include "bsp_usart.h"
接收机
然后我们定义几个需要用到的变量
UART_RX_BUF_LEN是串口接收数据长度宏定义
uart_rx_buf是串口接收缓冲区
uart_rxcb是ringbuffer cb(这个不是很懂,个人理解是用来管理串口接收缓冲区的)
shell_rx_sem是信号量,当串口接收完成后中断函数会释放信号量,而finSH组件会接收该信号量,然后读取接收到的数据
#define UART_RX_BUF_LEN 16
rt_uint8_t uart_rx_buf[UART_RX_BUF_LEN] = {0};
struct rt_ringbuffer uart_rxcb; /* 定义一个 ringbuffer cb /
static struct rt_semaphore shell_rx_sem; /
定义一个静态信号量 */
将他们放到下图中的位置
接收机
在串口初始化函数中初始化ringbuffer cb变量uart_rxcb和信号量shell_rx_sem
/* 初始化串口接收 ringbuffer  */
rt_ringbuffer_init(&uart_rxcb, uart_rx_buf, UART_RX_BUF_LEN);
/* 初始化串口接收数据的信号量 */
rt_sem_init(&(shell_rx_sem), "shell_rx", 0, 0);
将他们放到下图中的位置
接收机
编写串口中断服务函数
/* uart 中断 /
void USART0_IRQHandler(void)
int ch;
enter interrupt /
rt_interrupt_enter(); //在中断中一定要调用这对函数,进入中断
if (usart_interrupt_flag_get(BSP_USART,USART_INT_FLAG_RBNE) == SET) // 接收缓冲区不为空
ch = usart_data_receive(BSP_USART);
if (usart_interrupt_flag_get(BSP_USART,USART_INT_FLAG_IDLE) == SET) // 检测到帧中断
usart_data_receive(BSP_USART); // 必须要读,读出来的值不能要
ch = '�'; // 数据接收完毕,数组结束标志
rt_sem_release(&shell_rx_sem);
读取到数据,将数据存入 ringbuffer /
rt_ringbuffer_putchar(&uart_rxcb, ch);
leave interrupt */
rt_interrupt_leave(); //在中断中一定要调用这对函数,离开中断
将他们放到下图中的位置
接收机
并将bsp_usart文件中的串口中断函数注释掉,如下面图片所示
接收机
3.2 rt_hw_console_getchar函数实现
经过以上的步骤,已成功将官方示例的基础移植完成,这里只需要将官方示例中的rt_hw_console_getchar函数直接复制过来即可
/* 移植 FinSH,实现命令行交互, 需要添加 FinSH 源码,然后再对接 rt_hw_console_getchar /
中断方式 /
char rt_hw_console_getchar(void)
char ch = 0;
从 ringbuffer 中拿出数据 */
while (rt_ringbuffer_getchar(&uart_rxcb, (rt_uint8_t *)&ch) != 1)
rt_sem_take(&shell_rx_sem, RT_WAITING_FOREVER);
return ch;
将上面代码放置到下图中的位置
接收机
以上就实现了在梁山派的Nano上添加FinSH组件(实现命令输入)
这里直接烧录通过串口查看即可(记得注释掉main函数中的rt_kprintf打印函数,实验现象会明显一些)
实验现象如下图:
接收机
