Linux驱动debugfs接口代码实现
实现效果
/sys/kernel/debug/目录下创建一个ion/test文件,通过catecho的方式进行读写操作:
接口
接口
前期准备
内核配置打开debugfs:
CONFIG_DEBUG_FS=y
挂载debugfs文件系统:
mount -t debugfs none /sys/kernel/debug
代码实现
读写变量:
#include < linux/debugfs.h >
#include < linux/module.h >
#include < linux/types.h >
static struct dentry *ion_dir;
static u64 test_u64 = 0;
static int __init debugfs_init(void)
    //创建一个/sys/kernel/debug/ion目录
    ion_dir = debugfs_create_dir("ion", NULL);
    if (!ion_dir) {
        printk("ion_dir is nulln");
        return -1;
    /* 创建/sys/kernel/debug/ion/test_u64文件 */
    debugfs_create_u64("test_u64", 0644,
                        ion_dir, &test_u64);
    return 0;
static void __exit debugfs_exit(void)
    debugfs_remove_recursive(ion_dir);
module_init(debugfs_init);
module_exit(debugfs_exit);
MODULE_LICENSE("GPL");
运行结果:
接口
读写字符串:
#include < linux/fs.h >
#include < linux/uaccess.h >
#include < linux/errno.h >
#include < linux/dcache.h >
static char ion_buf[512] = "hellon";
static int ion_open(struct inode *inode, struct file *filp)
    //printk("ion openn");
    return 0;
ssize_t ion_read(struct file *filp, char __user *buf, size_t count, loff_t *offp)
    int retval = 0;
    if ((*offp + count) > 512)
        count = 512 - *offp;
    if (copy_to_user(buf, ion_buf+*offp, count)) {
        printk("copy to user failed, count:%ldn", count);
        retval = -EFAULT;
        goto out;
    *offp += count;
    retval = count;
out:
    return retval;
ssize_t ion_write(struct file *filp, const char __user *buff, size_t count, loff_t *offp)
    int retval;
    if (*offp > 512)
        return 0;
    if (*offp + count > 512)
    if (copy_from_user(ion_buf+*offp, buff, count)) {
        printk("copy from user failed, count:%ldn", count);
        retval = -EFAULT;
        goto out;
    *offp += count;
    retval = count;
out:
    return retval;
struct file_operations my_fops = {
    .owner = THIS_MODULE,
    .read = ion_read,
    .write = ion_write,
    .open = ion_open,
    printk("INIT MODULEn");
    if (!ion_dir) {
        return -1;
    /* 创建/sys/kernel/debug/ion/test文件 */
    struct dentry *filent = debugfs_create_file("test", 0644, ion_dir, NULL, &my_fops);
    if (!filent) {
        printk("test file is nulln");
        return -1;
    return 0;
运行结果:
接口
