【RA2L1开发实践】- 温湿度检测平台
主要驱动代码
dht11.c
  • Copyright (c) 2006-2021, RT-Thread Development Team
  • SPDX-License-Identifier: Apache-2.0
  • Change Logs:
  • Date Author Notes
  • 2023-03-15 XiaoDai the first version
    #ifndef SRC_DHT11_C_
    #define SRC_DHT11_C_
    #include "dht11.h"
    #include
    #include "hal_data.h"
    #include
    #define DBG_TAG "sensor.asair.dhtxx"
    #ifdef PKG_USING_DHTXX_DEBUG
    #define DBG_LVL DBG_LOG
    #else
    #define DBG_LVL DBG_ERROR
    #endif
    #include
    timing /
    #define DHT1x_BEGIN_TIME 20 /
    ms /
    #define DHT2x_BEGIN_TIME 1 /
    ms /
    #define DHTxx_PULL_TIME 30 /
    us /
    #define DHTxx_REPLY_TIME 100 /
    us /
    #define MEASURE_TIME 40 /
    us /
    RT_WEAK void rt_hw_us_delay(rt_uint32_t us)
    rt_uint32_t delta;
    us = us * (SysTick->LOAD / (1000000 / RT_TICK_PER_SECOND));
    delta = SysTick->VAL;
    while (delta - SysTick->VAL < us) continue;
  • This function will split a number into two part according to times.
  • @param num the number will be split
  • @param integer the integer part
  • @param decimal the decimal part
  • @param times how many times of the real number (you should use 10 in this case)
  • @return 0 if num is positive, 1 if num is negative
    int split_int(const int num, int *integer, int *decimal, const rt_uint32_t times)
    int flag = 0;
    if (num < 0) flag = 1;
    int anum = num<0 ? -num : num;
    integer = anum / times;
    decimal = anum % times;
    return flag;
  • This function will convert temperature in degree Celsius to Kelvin.
  • @param c the temperature indicated by degree Celsius
  • @return the result
    float convert_c2k(float c)
    return c + 273.15;
  • This function will convert temperature in degree Celsius to Fahrenheit.
    float convert_c2f(float c)
    return c * 1.8 + 32;
  • This function will convert temperature in degree Fahrenheit to Celsius.
  • @param f the temperature indicated by degree Fahrenheit
    float convert_f2c(float f)
    return (f - 32) * 0.55555;
  • This function will read a bit from sensor.
  • @param pin the pin of Dout
  • @return the bit value
    static uint8_t dht_read_bit(const rt_base_t pin)
    uint8_t retry = 0;
    while(rt_pin_read(pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1);
    retry = 0;
    while(!rt_pin_read(pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1);
    rt_hw_us_delay(MEASURE_TIME);
    return rt_pin_read(pin);
  • This function will read a byte from sensor.
  • @return the byte
    static uint8_t dht_read_byte(const rt_base_t pin)
    uint8_t i, byte = 0;
    for(i=0; i<8; i++)
    byte <<= 1;
    byte |= dht_read_bit(pin);
    return byte;
  • This function will read and update data array.
  • @param dev the device to be operated
  • @return RT_TRUE if read successfully, otherwise return RT_FALSE.
    rt_bool_t dht_read(dht_device_t dev)
    RT_ASSERT(dev);
    uint8_t i, retry = 0, sum = 0;
    #ifdef PKG_USING_DHTXX_INTERRUPT_DISABLE
    rt_base_t level;
    #endif
    Reset data buffer /
    rt_memset(dev->data, 0, DHT_DATA_SIZE);
    MCU request sampling /
    rt_pin_mode(dev->pin, PIN_MODE_OUTPUT);
    rt_pin_write(dev->pin, PIN_LOW);
    if (dev->type == DHT11) {
    rt_thread_mdelay(DHT1x_BEGIN_TIME); /
    Tbe /
    } else {
    rt_thread_mdelay(DHT2x_BEGIN_TIME);
    level = rt_hw_interrupt_disable();
    #endif
    rt_pin_mode(dev->pin, PIN_MODE_INPUT_PULLUP);
    rt_hw_us_delay(DHTxx_PULL_TIME); /
    Tgo /
    Waiting for sensor reply /
    while (rt_pin_read(dev->pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1); /
    Trel /
    if(retry >= DHTxx_REPLY_TIME) return RT_FALSE;
    retry = 0;
    while (!rt_pin_read(dev->pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    Treh /
    Read data /
    for(i=0; i {
    dev->data[i] = dht_read_byte(dev->pin);
    rt_hw_interrupt_enable(level);
    #endif
    Checksum */
    for(i=0; i {
    sum += dev->data[i];
    if(sum != dev->data[4]) return RT_FALSE;
    return RT_TRUE;
  • This function will get the humidity from dhtxx sensor.
  • @return the humidity value
    rt_int32_t dht_get_humidity(dht_device_t const dev)
    RT_ASSERT(dev);
    rt_int32_t humi = 0;
    switch(dev->type)
    case DHT11:
    humi = dev->data[0] * 10 + dev->data[1];
    break;
    default:
    break;
    return humi;
  • This function will get the temperature from dhtxx sensor.
  • @return the temperature value
    rt_int32_t dht_get_temperature(dht_device_t const dev)
    RT_ASSERT(dev);
    rt_int32_t temp = 0;
    switch(dev->type)
    case DHT11:
    temp = dev->data[2] * 10 + (dev->data[3] & 0x7f);
    if(dev->data[3] & 0x80) {
    temp = -temp;
    break;
    default:
    break;
    return temp;
  • This function will init dhtxx sensor device.
  • @param dev the device to init
  • @return the device handler
    rt_err_t dht_init(struct dht_device dev, const rt_base_t pin)
    if(dev == NULL)
    return -RT_ERROR;
    dev->type = DHT_TYPE;
    dev->pin = pin;
    return RT_EOK;
    // 1、初始化类型
    dht_device_t dht_create(const rt_base_t pin)
    dht_device_t dev;
    dev = rt_calloc(1, sizeof(struct dht_device));
    if (dev == RT_NULL)
    LOG_E("Can't allocate memory for dhtxx device");
    return RT_NULL;
    dev->pin = pin;
    return dev;
    void dht_delete(dht_device_t dev)
    if (dev)
    rt_free(dev);
    #endif /
    SRC_DHT11_C_ /
  • Change Logs:
  • Date Author Notes
    #ifndef SRC_DHT11_H_
    #define SRC_DHT11_H_
    dht11.h
#include
#include
#include
#include
#include
#define DHTLIB_VERSION "0.9.0"
#define DHT_DATA_SIZE 5
/* sensor model type */
#define DHT11 0
#define DHT_TYPE DHT11
struct dht_device
rt_base_t pin;
rt_uint8_t type;
rt_uint8_t data[DHT_DATA_SIZE];
rt_mutex_t lock;
typedef struct dht_device *dht_device_t;
dht_device_t dht_create(const rt_base_t pin);
void dht_delete(dht_device_t dev);
rt_err_t dht_init(struct dht_device *dev, const rt_base_t pin);
rt_bool_t dht_read(dht_device_t dev);
rt_int32_t dht_get_humidity(dht_device_t dev);
rt_int32_t dht_get_temperature(dht_device_t dev);
float convert_c2k(float c);//将摄氏温度转为开氏温度
float convert_c2f(float c);//将摄氏温度转为华氏温度
float convert_f2c(float f);//将华氏温度转为摄氏温度
rt_int32_t split_int(const rt_int32_t num, rt_int32_t *integer,
rt_int32_t *decimal, const rt_uint32_t times);
rt_err_t rt_hw_dht_init(const char *name, struct rt_sensor_config cfg);
#endif /
SRC_DHT11_H_ */
0.96oled代码
void lcd_thread_handler(void *parameter)
LCD_Init();
LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
lcd_show();
rt_thread_mdelay(1000);
while(1)
lcd_show_pic1();
rt_thread_mdelay(500);
if(key_num ==1)
// u8g2_ClearBuffer(&u8g2);
u8g2_DrawStr(&u8g2, 1, 40, "LED2 is on");
u8g2_SendBuffer(&u8g2);
else {
u8g2_DrawStr(&u8g2, 1, 40, "LED2 is off");
hal_entry.c
Change Logs:
Date Author Notes
2021-10-10 Sherman first version
#include
#include
#define LED1_PIN "P502" /
Onboard LED1 pins /
#define LED2_PIN "P501" /
Onboard LED2 pins */
#define USER_INPUT "P004"
rt_uint32_t pin ;
int key_num ;
void hal_entry(void)
rt_kprintf("nHello RT-Thread!n");
while (1)
if( pin == 1)
rt_kprintf("nUSER_INPUT push !n");
rt_pin_write(LED2,PIN_HIGH);
void irq_callback_test(void args)
static int out ,out2 ;
rt_kprintf("n IRQ03 triggered n");
rt_uint32_t led1_pin = rt_pin_get(LED1_PIN);
rt_uint32_t led2_pin = rt_pin_get(LED2_PIN);
out = rt_pin_read(led1_pin)?PIN_LOW:PIN_HIGH;
out2 = rt_pin_read(led2_pin)?PIN_LOW:PIN_HIGH;
rt_pin_write(led1_pin,out);
rt_pin_write(led2_pin,out2);
key_num++;
if( pin == 0 && key_num ==2)
rt_kprintf("n LED2 is on !n");
else {
rt_kprintf("n LED2 is off !n");
rt_pin_write(LED2,PIN_LOW);
if(key_num ==2 )
key_num =0;
void push_btn(void)
init */
rt_uint32_t pin = rt_pin_get(USER_INPUT);
rt_kprintf("n pin number : 0x%04X n", pin);
rt_err_t err = rt_pin_attach_irq(pin, PIN_IRQ_MODE_RISING, irq_callback_test, RT_NULL);
if (RT_EOK != err)
rt_kprintf("n attach irq failed. n");
err = rt_pin_irq_enable(pin, PIN_IRQ_ENABLE);
if (RT_EOK != err)
rt_kprintf("n enable irq failed. n");
MSH_CMD_EXPORT(push_btn, push_btn);
偶然之中在源代码中发现官方已经帮我们定义好了有些引脚,所以就没必要重复定义了
SRC
