线程间通信的几种方式
1 使用synchronized,wait,notify,notifyAll
使用synchronized 等方法来控制共享变量,完成交替打印。
思路:
  1. 在同步方法中先判断信号量,如果不是当前需要的信号使用wait()阻塞线程。
  2. 完成打印之后切换信号变量。再唤醒所有线程。
public class ThreadSignaling2 {
    public static void main(String[] args) {
        NorthPrint print = new NorthPrint(new NorthSignal());
        ThreadA threadA = new ThreadA(print);
        ThreadB threadB = new ThreadB(print);
        threadA.start();
        threadB.start();
public static class ThreadA extends Thread {
    private NorthPrint print;
    public ThreadA(NorthPrint print) {
        this.print = print;
    @Override
    public void run() {
        print.printNumber();
public static class ThreadB extends Thread {
    public ThreadB(NorthPrint print) {
        this.print = print;
    @Override
    public void run() {
        print.printChar();
public class NorthSignal {
    protected boolean hasDataToProcess = false;
    public synchronized boolean hasDataToProcess(){
        return this.hasDataToProcess;
    public synchronized void setHasDataToProcess(boolean hasData){
        this.hasDataToProcess = hasData;
public class NorthPrint {
    private NorthSignal signal;
    public NorthPrint(NorthSignal signal) {
        this.signal = signal;
    public synchronized void printNumber() {
        try {
            for (int i = 1; i <= 26; ) {
                if (signal.hasDataToProcess()) {
                    wait();
                }else {
                    System.out.print(i * 2 - 1);
                    System.out.print(i * 2);
                    signal.setHasDataToProcess(true);
                    i++;
                    notifyAll();
        } catch (InterruptedException e) {
            e.printStackTrace();
    public synchronized void printChar() {
        try {
            for (int i = 'A'; i <= 'Z'; ) {
                if (!signal.hasDataToProcess()) {
                    wait();
                }else {
                    System.out.print((char)i);
                    signal.setHasDataToProcess(false);
                    i++;
                    notifyAll();
2 Lock,Condition
通过使用Lock,Condition的signal() 和 await()来进行换新阻塞交替打印。
public class ThreadSignalingReentrant {
        Lock lock = new ReentrantLock();
        Condition condition1 = lock.newCondition();
        Condition condition2 = lock.newCondition();
        new Thread(() - > {
            try{
                lock.lock();
                int i = 1;
                while (i <= 26) {
                    i++;
                    condition2.signal();
                    condition1.await();
            } finally {
                lock.unlock();
        }).start();
        new Thread(() - > {
            try{
                lock.lock();
                char i = 'A';
                while (i <= 'Z') {
                    System.out.print(i);
                    i++;
                    condition1.signal();
                    condition2.await();
            } finally {
                lock.unlock();
        }).start();
3 LockSupport
LockSupport 用来创建锁和其他同步类的基本线程阻塞。当调用LockSupport.park时,表示当前线程将会等待,直至获得许可,当调用LockSupport.unpark时,必须把等待获得许可的线程作为参数进行传递,好让此线程继续运行。
其中:
  • park函数,阻塞线程,并且该线程在下列情况发生之前都会被阻塞: ① 调用unpark函数,释放该线程的许可。② 该线程被中断。③ 设置的时间到了。并且,当time为绝对时间时,isAbsolute为true,否则,isAbsolute为false。当time为0时,表示无限等待,直到unpark发生。
  • unpark函数,释放线程的许可,即激活调用park后阻塞的线程。这个函数不是安全的,调用这个函数时要确保线程依旧存活。
public class ThreadSignalingLockSupport {
    private static Thread threadA = null;
    private static Thread threadB = null;
        threadA = new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                LockSupport.unpark(threadB);
                LockSupport.park();
        threadB = new Thread(() - > {
            char i = 'A';
            while (i <= 'Z') {
                LockSupport.park();
                i++;
                LockSupport.unpark(threadA);
        threadA.start();
        threadB.start();
4 volatile
根据volatile修饰的对象在JVM内存中的可见性,完成交替打印
public class ThreadSignalingVolatile {
    enum ThreadRunFlag{PRINT_NUM, PRINT_CHAR}
    private volatile static ThreadRunFlag threadRunFlag = ThreadRunFlag.PRINT_NUM;
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                while(threadRunFlag == ThreadRunFlag.PRINT_CHAR){}
                i++;
                threadRunFlag = ThreadRunFlag.PRINT_CHAR;
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while (threadRunFlag == ThreadRunFlag.PRINT_NUM){}
                i++;
        }).start();
5 AtomicInteger
同样利用了AtomicInteger的并发特性,来完成交替打印。
public class AtomicIntegerSignal {
    private static AtomicInteger threadSignal = new AtomicInteger(1);
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                while(threadSignal.get() == 2){}
                i++;
                threadSignal.set(2);
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while (threadSignal.get() == 1){}
                i++;
                threadSignal.set(1);
        }).start();
6 利用 Piped Stream
使用Stream中的Piped Stream分别控制输出,但是其运行速度极慢。
public class ThreadSignalPipedStream {
    private final PipedInputStream inputStream1;
    private final PipedOutputStream outputStream1;
    private final PipedInputStream inputStream2;
    private final PipedOutputStream outputStream2;
    private final byte[] MSG;
    public ThreadSignalPipedStream() {
        inputStream1 = new PipedInputStream();
        outputStream1 = new PipedOutputStream();
        inputStream2 = new PipedInputStream();
        outputStream2 = new PipedOutputStream();
        MSG = "Go".getBytes();
        try {
            inputStream1.connect(outputStream2);
            inputStream2.connect(outputStream1);
        } catch (IOException e) {
        ThreadSignalPipedStream signal = new ThreadSignalPipedStream();
        signal.threadA().start();
        signal.threadB().start();
    public Thread threadA (){
        final String[] inputArr = new String[2];
        return new Thread() {
            String[] arr = inputArr;
            PipedInputStream in1 = inputStream1;
            PipedOutputStream out1 = outputStream1;
            @Override
            public void run() {
                int i = 1;
                while (i <= 26) {
                    try {
                        out1.write(MSG);
                        byte[] inArr = new byte[2];
                        in1.read(inArr);
                        while(!"Go".equals(new String(inArr))){ }
                        i++;
    public Thread threadB (){
            private String[] arr = inputArr;
            private PipedInputStream in2 = inputStream2;
            private PipedOutputStream out2 = outputStream2;
            @Override
            public void run() {
                char i = 'A';
                while (i <= 'Z'){
                    try {
                        in2.read(inArr);
                        i++;
                        out2.write(MSG);
7 利用BlockingQueue
BlockingQueue 通常用于一个线程生产对象,另外一个线程消费这些对象的场景。
函数
一个线程负责往里面放,另一个线程从里面取一个BlockingQueue。
线程可以持续将新对象插入到队列之中,直到队列达到可容纳的临界点。当队列到达临界点之后,线程生产者会在插入对象是进入阻塞状态,直到有另外一个线程从队列中拿走一个对象。消费线程会不停的从队列中拿出对象。如果消费线程从一个空的队列中获取对象的话,那么消费线程会处阻塞状态,直到一个生产线程把对象丢进队列。
BlockingQueue常用方法如下:
函数
image-20210906230302480
那么我们使用一个LinkedBlockingQueue来完成开始出现的题目
方法中我们使用offer,peek,poll这几个方法来完成。
public class ThreadSignalBlockingQueue {
    private static LinkedBlockingQueue< String > queue = new LinkedBlockingQueue<  >();
    public static void main(String[] args) throws InterruptedException {
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                queue.offer("printChar");
                while(!"printNumber".equals(queue.peek())){}
                queue.poll();
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                while(!"printChar".equals(queue.peek())){}
                queue.poll();
                i++;
                queue.offer("printNumber");
        }).start();
我们也可以使用两个LinkedBlockinQueue来完成,分别使用带阻塞的put,take来完成。代码如下
public class ThreadSignalBlockingQueue2 {
    private static LinkedBlockingQueue< String > queue1 = new LinkedBlockingQueue<  >();
    private static LinkedBlockingQueue< String > queue2 = new LinkedBlockingQueue<  >();
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                i++;
                try {
                    queue2.put("printChar");
                    queue1.take();
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                try {
                    queue2.take();
                    i++;
                    queue1.put("printNumber");
        }).start();
8 使用CyclicBarrier
CyclicBarrier的字面意思就是可循环使用的屏障,它可以让一组线程到达一个阻塞点(屏障)时被阻塞。直到最后一个线程到达阻塞点后,屏障才会开门,然后所有被拦截的线程就可以继续运行。
CyclicBarrier中有一个barrierCommand,主要就是在所有线程到达阻塞点之后执行的一个线程。可以使用构造方法来 CyclicBarrier(int parties, Runnable barrierAction)进行构建。
关于使用CyclicBarrier进行交替打印,先来说一下思路。
  1. 利用await()方法使得每循环一次都阻塞线程。
  2. 将每次循环输出的值放到一个共享的同步list里面。
  3. 然后再使用barrierAction到达阻塞点之后进行输出。由于list里面的值先后顺序有变化,所有先排序然后再打印。
下面我们看一下实操代码:
public class ThreadSignalCyclicBarrier {
    private static List< String > list =  Collections.synchronizedList(new ArrayList<  >());
    public static void main(String[] args) throws Exception {
        CyclicBarrier barrier = new CyclicBarrier(2,barrierRun());
        new Thread(() - > {
            int i = 1;
            while (i <= 26) {
                list.add(String.valueOf(i * 2 - 1));
                list.add(String.valueOf(i * 2));
                i++;
                try {
                    barrier.await();
                } catch (Exception e) {
        }).start();
        new Thread(()- >{
            char i = 'A';
            while (i <= 'Z'){
                try {
                    list.add(String.valueOf(i));
                    i++;
                    barrier.await();
        }).start();
    public static Runnable barrierRun(){
        return new Runnable() {
            @Override
            public void run() {
                Collections.sort(list);
                list.forEach(str- >System.out.print(str));
                list.clear();
