CPK-RA2L1评估板(5)室内空气质量监测系统设计
一、背景
有幸参加RT-Thread的活动,体验RT-Thread Studio 和瑞萨 CPK-RA2L1评估板。本篇结合前面的文章,暂时制作一个空气质量监测系统,主要使用:DHT11、PMS1003, OLED模块, 后续继续扩展甲醛,CO2, IAQ模块
二、模块信息
三、新建工程
这里使用的模块,我们需要提前分配好引脚:UART0 采集PMS1003, DHT11 使用P0208 引脚, OLED I2C1通信 使用P0205 P0206,
配置RT-Thread Settings ,添加u8g2 库,配置i2c,具体信息如下图
RT-Thread
RT-Thread
在 RA Smart Configurator 种添加UART0,配置好引脚和波特率
RT-Thread
在 RA Smart Configurator 种添加I2C1
RT-Thread
四、编写代码
hal_entery.c
  • Copyright (c) 2006-2021, RT-Thread Development Team
  • SPDX-License-Identifier: Apache-2.0
  • Change Logs:
  • Date Author Notes
  • 2021-10-10 Sherman first version
    #include
    #include "hal_data.h"
    #include
    #include "dht11.h"
    #include
    #include "pms1003.h"
    #include
    #include
    #include
    //#define DBG_ENABLE
    //#define DBG_SECTION_NAME "pms_series"
    //#define DBG_LEVEL DBG_LOG
    //#define DBG_COLOR
    #define LED1_PIN "P502" /
    Onboard LED pins /
    #define USER_INPUT "P004"
    ******* DHT11 /
    #define DATA_PIN 0x0208 //P208 dht11
    #define THREAD_PRIORITY 5
    #define THREAD_STACK_SIZE 1024
    #define THREAD_TIMESLICE 10
    static rt_thread_t tid_dht11 = RT_NULL;
    PMS1003 /
    //tx P101 rx P100
    #define PMS_SERIES_UART "uart0"
    #ifdef PMS_SERIES_SAMPLE_USING_DMA
    struct rt_messagequeue pms_mq;
    #else
    struct rt_semaphore pms_sem;
    #endif
    pms_device_t PMS1003;
    struct rx_msg
    rt_device_t dev;
    rt_size_t size;
    OLED /
    static rt_thread_t tid_oled = RT_NULL;
    int temp = 0;
    int humi = 0;
    int PM2_5 = 0;
    int PM10 = 0;
    static void Dht11ThreadEntry(void *parameter)
    dht_device_t sensor = dht_create(DATA_PIN);
    rt_int32_t temp_;
    rt_int32_t humi_;
    while (1)
    if(dht_read(sensor))
    temp_ = dht_get_temperature(sensor) / 10;
    humi_ = dht_get_humidity(sensor) / 10;
    temp = temp_;
    humi = humi_;
    // rt_kprintf("Temp: %d, Humi: %dn", temp, humi);
    else
    // rt_kprintf("Read dht sensor failed.n");
    rt_thread_mdelay(500);
    dht_delete(sensor);
    int dht11_init()
    rt_err_t ret = RT_EOK;
    tid_dht11 = rt_thread_create("dht11",
    Dht11ThreadEntry,
    RT_NULL,
    THREAD_STACK_SIZE,
    THREAD_PRIORITY,
    THREAD_TIMESLICE);
    if (tid_dht11 != RT_NULL)
    rt_thread_startup(tid_dht11);
    else
    ret = RT_ERROR;
    return ret;
    //INIT_APP_EXPORT(dht11_init);
    void pms_series_debug(pms_device_t dev)
    rt_kprintf("begin
    n");
    rt_kprintf("PM1_0_CF1 = %5dtPM2_5_CF1 = %5dtPM10_0_CF1 = %5dn",dev->PM1_0_CF1,dev->PM2_5_CF1,dev->PM10_0_CF1);
    rt_kprintf("PM1_0_amb = %5dtPM2_5_amb = %5dtPM10_0_amb = %5dn",dev->PM1_0_amb,dev->PM2_5_amb,dev->PM10_0_amb);
    rt_kprintf("air_0_3um = %5dtair_0_5um = %5dtair_1_0um = %5dn",dev->air_0_3um,dev->air_0_5um,dev->air_1_0um);
    rt_kprintf("air_2_5um = %5dt",dev->air_2_5um);
    rt_kprintf("version = %5d errorCode = %5dn",dev->version,dev->errorCode);
    rt_kprintf("********************************over
    ****************************n");
    static void serial_thread_entry(void *parameter)
    #ifndef PMS_SERIES_SAMPLE_USING_DMA
    rt_err_t result;
    char ch;
    pms_device_t dev = parameter;
    while (1)
    while (rt_device_read(dev->serial, 0, &ch, 1) == 0)
    rt_sem_control(&pms_sem, RT_IPC_CMD_RESET, RT_NULL);
    rt_sem_take(&pms_sem, RT_WAITING_FOREVER);
    result = pms_get_byte(dev,ch);
    if (result == RT_EOK)
    // pms_series_debug(dev); // for debug
    PM2_5 = dev->PM2_5_CF1;
    PM10 = dev->PM10_0_CF1;
    // rt_kprintf("air_2_5um = %dn",PM2_5);
    #endif
    struct rx_msg msg;
    rt_err_t result;
    rt_uint32_t rx_length;
    static rt_uint8_t rx_buffer[RT_SERIAL_RB_BUFSZ + 1];
    while (1)
    rt_memset(&msg, 0, sizeof(msg));
    result = rt_mq_recv(&pms_mq, &msg, sizeof(msg), RT_WAITING_FOREVER);
    rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size);
    rx_buffer[rx_length] = '�';
    result = frame_check(dev,rx_buffer,rx_length);
    rt_kprintf("rx buff success");
    else
    rt_kprintf("rx buff error");
    #endif
    static rt_err_t uart_input(rt_device_t dev, rt_size_t size)
    RT_ASSERT(dev);
    if (size > 0)
    rt_sem_release(&pms_sem);
    return RT_EOK;
    #endif
    rt_err_t result;
    struct rx_msg msg;
    msg.dev = dev;
    msg.size = size;
    result = rt_mq_send(&pms_mq, &msg, sizeof(msg));
    if ( result == -RT_EFULL)
    rt_kprintf("message queue full!n");
    return result;
    #endif
    int PMS1003Init()
    static pms_device_t dev = NULL;
    dev = pms_init(PMS_SERIES_UART);
    rt_sem_init(&pms_sem, "pms_sem", 0, RT_IPC_FLAG_FIFO);
    rt_device_open(dev->serial, RT_DEVICE_FLAG_INT_RX);
    rt_device_set_rx_indicate(dev->serial, uart_input);
    #endif
    static char msg_pool[256];
    rt_err_t result;
    result = rt_mq_init(&pms_mq, "pms_mq",
    msg_pool,
    sizeof(struct rx_msg),
    sizeof(msg_pool),
    RT_IPC_FLAG_FIFO);
    if (result != RT_EOK)
    rt_kprintf("init message queue failed.n");
    result = rt_device_open(dev->serial, RT_DEVICE_FLAG_DMA_RX);
    rt_kprintf("open device failed.n");
    result = rt_device_set_rx_indicate(dev->serial, uart_input);
    rt_kprintf("set rx indicate failed.n");
    #endif
    rt_thread_t thread = rt_thread_create("pms1003", serial_thread_entry, dev, 1024, 3, 10);
    if (thread != RT_NULL)
    rt_thread_startup(thread);
    else
    ret = RT_ERROR;
    return ret;
    //INIT_APP_EXPORT(PMS1003Init);
    char tmp_buff[18]={'�'};
    char pm_buff[16]={'�'};
    char pm10_buff[16]={'�'};
    static int F_clean = 0;
    static void OledThreadEntry(void *parameter)
    u8g2_t u8g2;
    u8g2_Setup_ssd1306_i2c_128x64_noname_f( &u8g2, U8G2_R0, u8x8_byte_rtthread_hw_i2c, u8x8_gpio_and_delay_rtthread);
    u8g2_InitDisplay(&u8g2);
    u8g2_SetPowerSave(&u8g2, 0);//是否开启省电模式 , 1 表示启用显示器的省电模式,屏幕上看不到任何东西, 0 表示禁用省电模式
    u8g2_ClearBuffer(&u8g2);
    u8g2_SetFont(&u8g2, u8g2_font_unifont_t_arabic); //u8g2_font_ncenB08_tr u8g2_font_unifont_t_symbols
    while (1)
    sprintf(tmp_buff, "Temp:%dt Humi:%dt", temp, humi);
    sprintf(pm_buff, "PM2.5:%d", PM2_5);
    sprintf(pm10_buff, "PM10:%d", PM10);
    rt_thread_mdelay(300);
    if (1 == F_clean)
    else if (50 == F_clean)
    F_clean = 0;
    u8g2_DrawStr(&u8g2, 1, 10, &tmp_buff);
    u8g2_SendBuffer(&u8g2);
    u8g2_DrawStr(&u8g2, 1, 30, &pm_buff);
    u8g2_DrawStr(&u8g2, 1, 50, &pm10_buff);
    rt_kprintf("F_clean:%d n",F_clean++);
    int OLED_Init()
    tid_oled = rt_thread_create("oled",
    OledThreadEntry,
    RT_NULL,
    1024,
    2,
    THREAD_TIMESLICE);
    if (tid_oled != RT_NULL)
    rt_thread_startup(tid_oled);
    else
    ret = RT_ERROR;
    return ret;
    //INIT_APP_EXPORT(OLED_Init);
    void hal_entry(void)
    rt_kprintf("nHello RT-Thread!n");
    rt_uint32_t led1_pin = rt_pin_get(LED1_PIN);
    dht11_init();
    PMS1003Init();
    OLED_Init();
    while (1)
    rt_pin_write(led1_pin, PIN_HIGH);
    rt_pin_write(led1_pin, PIN_LOW);
    void irq_callback_test(void *args)
    rt_kprintf("n IRQ03 triggered n");
    void icu_sample(void)
    /* init */
    rt_uint32_t pin = rt_pin_get(USER_INPUT);
    rt_kprintf("n pin number : 0x%04X n", pin);
    rt_err_t err = rt_pin_attach_irq(pin, PIN_IRQ_MODE_RISING, irq_callback_test, RT_NULL);
    if (RT_EOK != err)
    rt_kprintf("n attach irq failed. n");
    err = rt_pin_irq_enable(pin, PIN_IRQ_ENABLE);
    if (RT_EOK != err)
    rt_kprintf("n enable irq failed. n");
    MSH_CMD_EXPORT(icu_sample, icu sample);
    dht11.c
  • Change Logs:
  • Date Author Notes
  • 2023-03-08 DYC the first version
    #include "dht11.h"
    #include
    #include
    #define DBG_TAG "sensor.asair.dhtxx"
    #ifdef PKG_USING_DHTXX_DEBUG
    #define DBG_LVL DBG_LOG
    #else
    #define DBG_LVL DBG_ERROR
    #endif
    #include
    timing /
    #define DHT1x_BEGIN_TIME 20 /
    ms /
    #define DHT2x_BEGIN_TIME 1 /
    ms /
    #define DHTxx_PULL_TIME 30 /
    us /
    #define DHTxx_REPLY_TIME 100 /
    us /
    #define MEASURE_TIME 40 /
    us /
    RT_WEAK void rt_hw_us_delay(rt_uint32_t us)
    rt_uint32_t delta;
    us = us * (SysTick->LOAD / (1000000 / RT_TICK_PER_SECOND));
    delta = SysTick->VAL;
    while (delta - SysTick->VAL < us) continue;
  • This function will split a number into two part according to times.
  • @param num the number will be split
  • @param integer the integer part
  • @param decimal the decimal part
  • @param times how many times of the real number (you should use 10 in this case)
  • @return 0 if num is positive, 1 if num is negative
    int split_int(const int num, int *integer, int *decimal, const rt_uint32_t times)
    int flag = 0;
    if (num < 0) flag = 1;
    int anum = num<0 ? -num : num;
    integer = anum / times;
    decimal = anum % times;
    return flag;
  • This function will convert temperature in degree Celsius to Kelvin.
  • @param c the temperature indicated by degree Celsius
  • @return the result
    float convert_c2k(float c)
    return c + 273.15;
  • This function will convert temperature in degree Celsius to Fahrenheit.
    float convert_c2f(float c)
    return c * 1.8 + 32;
  • This function will convert temperature in degree Fahrenheit to Celsius.
  • @param f the temperature indicated by degree Fahrenheit
    float convert_f2c(float f)
    return (f - 32) * 0.55555;
  • This function will read a bit from sensor.
  • @param pin the pin of Dout
  • @return the bit value
    static uint8_t dht_read_bit(const rt_base_t pin)
    uint8_t retry = 0;
    while(rt_pin_read(pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1);
    retry = 0;
    while(!rt_pin_read(pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1);
    rt_hw_us_delay(MEASURE_TIME);
    return rt_pin_read(pin);
  • This function will read a byte from sensor.
  • @return the byte
    static uint8_t dht_read_byte(const rt_base_t pin)
    uint8_t i, byte = 0;
    for(i=0; i<8; i++)
    byte <<= 1;
    byte |= dht_read_bit(pin);
    return byte;
  • This function will read and update data array.
  • @param dev the device to be operated
  • @return RT_TRUE if read successfully, otherwise return RT_FALSE.
    rt_bool_t dht_read(dht_device_t dev)
    RT_ASSERT(dev);
    uint8_t i, retry = 0, sum = 0;
    #ifdef PKG_USING_DHTXX_INTERRUPT_DISABLE
    rt_base_t level;
    #endif
    Reset data buffer /
    rt_memset(dev->data, 0, DHT_DATA_SIZE);
    MCU request sampling /
    rt_pin_mode(dev->pin, PIN_MODE_OUTPUT);
    rt_pin_write(dev->pin, PIN_LOW);
    if (dev->type == DHT11) {
    rt_thread_mdelay(DHT1x_BEGIN_TIME); /
    Tbe /
    } else {
    rt_thread_mdelay(DHT2x_BEGIN_TIME);
    level = rt_hw_interrupt_disable();
    #endif
    rt_pin_mode(dev->pin, PIN_MODE_INPUT_PULLUP);
    rt_hw_us_delay(DHTxx_PULL_TIME); /
    Tgo /
    Waiting for sensor reply /
    while (rt_pin_read(dev->pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    rt_hw_us_delay(1); /
    Trel /
    if(retry >= DHTxx_REPLY_TIME) return RT_FALSE;
    retry = 0;
    while (!rt_pin_read(dev->pin) && retry < DHTxx_REPLY_TIME)
    retry++;
    Treh /
    Read data /
    for(i=0; i {
    dev->data[i] = dht_read_byte(dev->pin);
    rt_hw_interrupt_enable(level);
    #endif
    Checksum */
    for(i=0; i {
    sum += dev->data[i];
    if(sum != dev->data[4]) return RT_FALSE;
    return RT_TRUE;
  • This function will get the humidity from dhtxx sensor.
  • @return the humidity value
    rt_int32_t dht_get_humidity(dht_device_t const dev)
    RT_ASSERT(dev);
    rt_int32_t humi = 0;
    switch(dev->type)
    case DHT11:
    humi = dev->data[0] * 10 + dev->data[1];
    break;
    default:
    break;
    return humi;
  • This function will get the temperature from dhtxx sensor.
  • @return the temperature value
    rt_int32_t dht_get_temperature(dht_device_t const dev)
    RT_ASSERT(dev);
    rt_int32_t temp = 0;
    switch(dev->type)
    case DHT11:
    temp = dev->data[2] * 10 + (dev->data[3] & 0x7f);
    if(dev->data[3] & 0x80) {
    temp = -temp;
    break;
    default:
    break;
    return temp;
  • This function will init dhtxx sensor device.
  • @param dev the device to init
  • @return the device handler
    rt_err_t dht_init(struct dht_device *dev, const rt_base_t pin)
    if(dev == NULL)
    return -RT_ERROR;
    dev->type = DHT_TYPE;
    dev->pin = pin;
    return RT_EOK;
    // 1、初始化类型
    dht_device_t dht_create(const rt_base_t pin)
    dht_device_t dev;
    dev = rt_calloc(1, sizeof(struct dht_device));
    if (dev == RT_NULL)
    LOG_E("Can't allocate memory for dhtxx device");
    return RT_NULL;
    dev->pin = pin;
    return dev;
    void dht_delete(dht_device_t dev)
    if (dev)
    rt_free(dev);
    dht11.h
  • Change Logs:
  • Date Author Notes
    #ifndef SRC_DHT11_H_
    #define SRC_DHT11_H_
    #include
    #include
    #include
    #include
    #include
    #define DHTLIB_VERSION "0.9.0"
    #define DHT_DATA_SIZE 5
    sensor model type */
    #define DHT11 0
    #define DHT_TYPE DHT11
    struct dht_device
    rt_base_t pin;
    rt_uint8_t type;
    rt_uint8_t data[DHT_DATA_SIZE];
    rt_mutex_t lock;
    typedef struct dht_device *dht_device_t;
    dht_device_t dht_create(const rt_base_t pin);
    void dht_delete(dht_device_t dev);
    rt_err_t dht_init(struct dht_device *dev, const rt_base_t pin);
    rt_bool_t dht_read(dht_device_t dev);
    rt_int32_t dht_get_humidity(dht_device_t dev);
    rt_int32_t dht_get_temperature(dht_device_t dev);
    float convert_c2k(float c);//将摄氏温度转为开氏温度
    float convert_c2f(float c);//将摄氏温度转为华氏温度
    float convert_f2c(float f);//将华氏温度转为摄氏温度
    rt_int32_t split_int(const rt_int32_t num, rt_int32_t *integer,
    rt_int32_t *decimal, const rt_uint32_t times);
    rt_err_t rt_hw_dht_init(const char *name, struct rt_sensor_config cfg);
    #endif /
    SRC_DHT11_H_ */
    pms1003.c
Change Logs:
Date Author Notes
//#define DBG_COLOR
#include
#include
#define RT_SERIAL_RB_BUFSZ 64
#define COMM_START1 0x42
#define COMM_START2 0x4D
#define FRAME_HEAD1 0x00
#define FRAME_HEAD2 0x01
#define FRAME_LENH 0x02
#define FRAME_LENL 0x03
#define FRAME_RECEIVE 0x04
#define FRAME_CHECK 0x05
rt_err_t frame_check(pms_device_t dev,rt_uint8_t *buf,rt_uint16_t len)
rt_uint16_t sum=0;
RT_ASSERT(dev);
for(uint8_t i=0;i<(len-2);i++)
sum += buf[i];
if((buf[len-1] == (sum&0xFF)) && (buf[len-2] == (sum >> 8)))
dev->PM1_0_CF1 = ((rt_uint16_t)(buf[4])<<8) | buf[5];
dev->PM2_5_CF1 = ((rt_uint16_t)(buf[6])<<8) | buf[7];
dev->PM10_0_CF1 = ((rt_uint16_t)(buf[8])<<8) | buf[9];
dev->PM1_0_amb = ((rt_uint16_t)(buf[10])<<8) | buf[11];
dev->PM2_5_amb = ((rt_uint16_t)(buf[12])<<8) | buf[13];
dev->PM10_0_amb = ((rt_uint16_t)(buf[14])<<8) | buf[15];
dev->air_0_3um = ((rt_uint16_t)(buf[16])<<8) | buf[17];
dev->air_0_5um = ((rt_uint16_t)(buf[18])<<8) | buf[19];
dev->air_1_0um = ((rt_uint16_t)(buf[20])<<8) | buf[21];
dev->air_2_5um = ((rt_uint16_t)(buf[22])<<8) | buf[23];
dev->version = buf[len - 4];
dev->errorCode = buf[len - 3];
return RT_EOK;
return RT_ERROR;
rt_err_t pms_get_byte(pms_device_t dev, char data)
rt_err_t result;
static uint8_t state = FRAME_HEAD1;
static uint8_t cnt = 0;
static rt_uint8_t buf[40] = {0};
RT_ASSERT(dev);
if(state == FRAME_HEAD1 && data == COMM_START1)
buf[cnt++] = data;
state = FRAME_HEAD2;
else if (state == FRAME_HEAD2 && data == COMM_START2)
buf[cnt++] = data;
state = FRAME_LENH;
else if (state == FRAME_LENH)
buf[cnt++] = data;
state = FRAME_LENL;
else if (state == FRAME_LENL)
buf[cnt++] = data;
state = FRAME_RECEIVE;
else if (state == FRAME_RECEIVE)
buf[cnt++] = data;
if(cnt >= COMM_LEN - 1)
state = FRAME_CHECK;
else if (state == FRAME_CHECK)
buf[cnt++] = data;
cnt = 0;
result = frame_check(dev, buf, COMM_LEN);
LOG_D("check success");
return result;
else
LOG_E("check error");
else {}
return result;
pms_device_t pms_init(const char *uart_name)
pms_device_t dev;
RT_ASSERT(uart_name);
dev = rt_calloc(1, sizeof(struct pms_device));
if (dev == RT_NULL)
LOG_E("Can't allocate memory for pms device %s",uart_name);
return RT_NULL;
dev->serial = rt_device_find(uart_name);
if (!dev->serial)
rt_free(dev);
rt_kprintf("find %s failed!n", uart_name);
else
dev->config.baud_rate = BAUD_RATE_9600;
dev->config.data_bits = DATA_BITS_8;
dev->config.stop_bits = STOP_BITS_1;
dev->config.parity = PARITY_NONE;
dev->config.bit_order = BIT_ORDER_LSB;
dev->config.invert = NRZ_NORMAL;
dev->config.rx_bufsz = RT_SERIAL_RB_BUFSZ;
dev->config.reserved = 0;
rt_device_control(dev->serial, RT_DEVICE_CTRL_CONFIG, &dev->config);
return dev;
void pms_deinit(pms_device_t dev)
RT_ASSERT(dev);
rt_free(dev);
pms1003.h
Change Logs:
Date Author Notes
#ifndef SRC_PMS1003_H_
#define SRC_PMS1003_H_
#define DBG_TAG "pms_series"
#define DBG_LVL DBG_INFO
#include
#include
#include
#define COMM_LEN 32
struct pms_device
rt_device_t serial;
struct serial_configure config;
rt_uint16_t len;
rt_uint16_t PM1_0_CF1;
rt_uint16_t PM2_5_CF1;
rt_uint16_t PM10_0_CF1;
rt_uint16_t PM1_0_amb;
rt_uint16_t PM2_5_amb;
rt_uint16_t PM10_0_amb;
rt_uint16_t air_0_3um;
rt_uint16_t air_0_5um;
rt_uint16_t air_1_0um;
rt_uint16_t air_2_5um;
rt_uint16_t air_5_0um;
rt_uint16_t air_10_0um;
rt_uint8_t version;
rt_uint8_t errorCode;
rt_uint16_t checksum;
typedef struct pms_device *pms_device_t;
pms_device_t pms_init(const char *uart_name);
rt_err_t frame_check(pms_device_t dev,rt_uint8_t buf,rt_uint16_t len);
rt_err_t pms_get_byte(pms_device_t dev, char data);
void pms_deinit(pms_device_t dev);
#endif /
SRC_PMS1003_H_ */
五、烧录验证与扩展
基本功能做完了,由于后续买的co2, 甲醛, IAQ模块还在路上,后续到了会继续往该系统中添加,还要与ESP8266 模块通信,完成本地系统数据远程访问,通过blinker实现数据的可视化,随时随地查看室内空气质量。
RT-Thread
RT-Thread
RT-Thread
