RT-Thread中Lan8720和lwip协议栈的使用
开发环境:野火的stm32f407,rt-thread studio版本是版本: 2.2.6,stm32f4的资源包为0.2.2,Agile Modbus软件包版本为v1.1.2。新建选择芯片工程。
修改工程使用外部晶振,可参考第一篇文章 rt-thread studio新建stm32f407工程 。
查看野火工程的资料,可知道芯片的使用引脚为:
PG11 : RMII_TX_EN;
PG13 : RMII_TXD0;
PG14 : RMII_TXD1;
PC5 : RMII_RXD1;
PC4 : RMII_RXD0;
PA7 : RMII_CRSDV;
PA1 : RMII_REF_CLK;
PC1 : RMII_MDC;
PA2 : RMII_MDIO;
复位脚 :NRST脚。
接线方式: 笔记本连接路由器,野火开发板也连接路由器。
根据文档需要做的步骤如下:
/*if you want to use eth you can use the following instructions.
  • STEP 1, define macro related to the eth
  • such as    BSP_USING_ETH
  • STEP 2, copy your eth init function from stm32xxxx_hal_msp.c generated by stm32cubemx to the end if board.c file
  • such as     void HAL_ETH_MspInit(ETH_HandleTypeDef* heth)
  • STEP 3, modify your stm32xxxx_hal_config.h file to support eth peripherals. define macro related to the peripherals
  • such as     #define HAL_ETH_MODULE_ENABLED
  • STEP 4, config your phy type
  • such as     #define PHY_USING_LAN8720A
  • #define PHY_USING_DM9161CEP
  • #define PHY_USING_DP83848C
  • STEP 5, implement your phy reset function in the end of board.c file
  • void phy_reset(void)
STEP 6, config your lwip or other network stack
按照要求修改即可,主要讲STEP2和STEP6的修改。STEP2 中的代码使用cubmx生成,生成的代码如下:
void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(ethHandle->Instance==ETH)
/* USER CODE BEGIN ETH_MspInit 0 /
USER CODE END ETH_MspInit 0 /
ETH clock enable */
__HAL_RCC_ETH_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
/**ETH GPIO Configuration
PC1 ------> ETH_MDC
PA1 ------> ETH_REF_CLK
PA2 ------> ETH_MDIO
PA7 ------> ETH_CRS_DV
PC4 ------> ETH_RXD0
PC5 ------> ETH_RXD1
PG11 ------> ETH_TX_EN
PG13 ------> ETH_TXD0
PG14 ------> ETH_TXD1
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_13|GPIO_PIN_14;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
USER CODE BEGIN ETH_MspInit 1 /
USER CODE END ETH_MspInit 1 */
STEP6 中是能lwip的协议栈,双击工程下的RT—Thread Settings,选择组件,选择lwIP。右键lwIP选择配置项进行配置,选择版本等参数。选择的是v2.0.2。保存配置,等待下载即可。
STM32F407
对程序进行编译,编译正常下载,查看打印信息。
在中断,可看到打印信息 lwIP-2.0.2 initialized! 。使用ping指令ping 笔记本ip,可正常ping通。
STM32F407
