main函数的三个参数
看一道海康威视的笔试题,题目很简单:
题目是多选题。
  我觉得大部分同学看到这个题目的时候,应该觉得它是一个送分题。
  main函数如果提供参数的话,有两个参数,一个是argc,一个是argv,其中,argc表示命令行参数的个数,argv是个指针数组,每个指针指向一个参数。
#include
int main(int argc, char *argv[])
    for (int i = 0; i < argc; i++)
        printf("%s
", argv[i]);
    return 0;
我们经常写这样的代码,把所有命令行参数打印出来。
  结果就是这样的:
root@Turbo:test# ./1 hello world
./1
hello
world
root@Turbo:test#
但是当我们提交答案后,它居然是错的,main函数竟然有三个参数,第三个参数是envp。 代码
这到底是个什么?
于是我找了一份glibc的源码,找到了libc_start_main函数,我们平时写的main函数,就是由它来调用的。
STATIC int
LIBC_START_MAIN (int (*main) (int, char **, char ** MAIN_AUXVEC_DECL),
     int argc, char **argv,
#ifdef LIBC_START_MAIN_AUXVEC_ARG
     ElfW(auxv_t) *auxvec,
#endif
     __typeof (main) init,
     void (*fini) (void),
     void (*rtld_fini) (void), void *stack_end)
  /* Result of the 'main' function.  */
  int result;
  __libc_multiple_libcs = &_dl_starting_up && !_dl_starting_up;
#ifndef SHARED
  _dl_relocate_static_pie ();
  char **ev = &argv[argc + 1];
  __environ = ev;
  /* Store the lowest stack address.  This is done in ld.so if this is
     the code for the DSO.  */
  __libc_stack_end = stack_end;
# ifdef HAVE_AUX_VECTOR
  /* First process the auxiliary vector since we need to find the
     program header to locate an eventually present PT_TLS entry.  */
#  ifndef LIBC_START_MAIN_AUXVEC_ARG
  ElfW(auxv_t) *auxvec;
    char **evp = ev;
    while (*evp++ != NULL)
    auxvec = (ElfW(auxv_t) *) evp;
#  endif
  _dl_aux_init (auxvec);
  if (GL(dl_phdr) == NULL)
# endif
      /* Starting from binutils-2.23, the linker will define the
         magic symbol __ehdr_start to point to our own ELF header
         if it is visible in a segment that also includes the phdrs.
         So we can set up _dl_phdr and _dl_phnum even without any
         information from auxv.  */
      extern const ElfW(Ehdr) __ehdr_start
  __attribute__ ((weak, visibility ("hidden")));
      if (&__ehdr_start != NULL)
          assert (__ehdr_start.e_phentsize == sizeof *GL(dl_phdr));
          GL(dl_phdr) = (const void *) &__ehdr_start + __ehdr_start.e_phoff;
          GL(dl_phnum) = __ehdr_start.e_phnum;
  /* Initialize very early so that tunables can use it.  */
  __libc_init_secure ();
  __tunables_init (__environ);
  ARCH_INIT_CPU_FEATURES ();
  /* Perform IREL{,A} relocations.  */
  ARCH_SETUP_IREL ();
  /* The stack guard goes into the TCB, so initialize it early.  */
  ARCH_SETUP_TLS ();
  /* In some architectures, IREL{,A} relocations happen after TLS setup in
     order to let IFUNC resolvers benefit from TCB information, e.g. powerpc's
     hwcap and platform fields available in the TCB.  */
  ARCH_APPLY_IREL ();
  /* Set up the stack checker's canary.  */
  uintptr_t stack_chk_guard = _dl_setup_stack_chk_guard (_dl_random);
# ifdef THREAD_SET_STACK_GUARD
  THREAD_SET_STACK_GUARD (stack_chk_guard);
# else
  __stack_chk_guard = stack_chk_guard;
# endif
# ifdef DL_SYSDEP_OSCHECK
  if (!__libc_multiple_libcs)
      /* This needs to run to initiliaze _dl_osversion before TLS
   setup might check it.  */
      DL_SYSDEP_OSCHECK (__libc_fatal);
# endif
  /* Initialize libpthread if linked in.  */
  if (__pthread_initialize_minimal != NULL)
    __pthread_initialize_minimal ();
  /* Set up the pointer guard value.  */
  uintptr_t pointer_chk_guard = _dl_setup_pointer_guard (_dl_random,
               stack_chk_guard);
# ifdef THREAD_SET_POINTER_GUARD
  THREAD_SET_POINTER_GUARD (pointer_chk_guard);
# else
  __pointer_chk_guard_local = pointer_chk_guard;
# endif
#endif /* !SHARED  */
  /* Register the destructor of the dynamic linker if there is any.  */
  if (__glibc_likely (rtld_fini != NULL))
    __cxa_atexit ((void (*) (void *)) rtld_fini, NULL, NULL);
#ifndef SHARED
  /* Call the initializer of the libc.  This is only needed here if we
     are compiling for the static library in which case we haven't
     run the constructors in `_dl_start_user'.  */
  __libc_init_first (argc, argv, __environ);
  /* Register the destructor of the program, if any.  */
  if (fini)
    __cxa_atexit ((void (*) (void *)) fini, NULL, NULL);
  /* Some security at this point.  Prevent starting a SUID binary where
     the standard file descriptors are not opened.  We have to do this
     only for statically linked applications since otherwise the dynamic
     loader did the work already.  */
  if (__builtin_expect (__libc_enable_secure, 0))
    __libc_check_standard_fds ();
#endif
  /* Call the initializer of the program, if any.  */
#ifdef SHARED
  if (__builtin_expect (GLRO(dl_debug_mask) & DL_DEBUG_IMPCALLS, 0))
    GLRO(dl_debug_printf) ("
initialize program: %s
", argv[0]);
#endif
  if (init)
    (*init) (argc, argv, __environ MAIN_AUXVEC_PARAM);
#ifdef SHARED
  /* Auditing checkpoint: we have a new object.  */
  if (__glibc_unlikely (GLRO(dl_naudit) > 0))
      struct audit_ifaces *afct = GLRO(dl_audit);
      struct link_map *head = GL(dl_ns)[LM_ID_BASE]._ns_loaded;
      for (unsigned int cnt = 0; cnt < GLRO(dl_naudit); ++cnt)
    if (afct->preinit != NULL)
      afct->preinit (&link_map_audit_state (head, cnt)->cookie);
    afct = afct->next;
#endif
#ifdef SHARED
  if (__glibc_unlikely (GLRO(dl_debug_mask) & DL_DEBUG_IMPCALLS))
transferring control: %s
", argv[0]);
#endif
#ifndef SHARED
  _dl_debug_initialize (0, LM_ID_BASE);
#endif
#ifdef HAVE_CLEANUP_JMP_BUF
  /* Memory for the cancellation buffer.  */
  struct pthread_unwind_buf unwind_buf;
  int not_first_call;
  not_first_call = setjmp ((struct __jmp_buf_tag *) unwind_buf.cancel_jmp_buf);
  if (__glibc_likely (! not_first_call))
      struct pthread *self = THREAD_SELF;
      /* Store old info.  */
      unwind_buf.priv.data.prev = THREAD_GETMEM (self, cleanup_jmp_buf);
      unwind_buf.priv.data.cleanup = THREAD_GETMEM (self, cleanup);
      /* Store the new cleanup handler info.  */
      THREAD_SETMEM (self, cleanup_jmp_buf, &unwind_buf);
      /* Run the program.  */
      result = main (argc, argv, __environ MAIN_AUXVEC_PARAM);
  else
      /* Remove the thread-local data.  */
# ifdef SHARED
      PTHFCT_CALL (ptr__nptl_deallocate_tsd, ());
# else
      extern void __nptl_deallocate_tsd (void) __attribute ((weak));
      __nptl_deallocate_tsd ();
# endif
      /* One less thread.  Decrement the counter.  If it is zero we
   terminate the entire process.  */
      result = 0;
# ifdef SHARED
      unsigned int *ptr = __libc_pthread_functions.ptr_nthreads;
#  ifdef PTR_DEMANGLE
      PTR_DEMANGLE (ptr);
#  endif
# else
      extern unsigned int __nptl_nthreads __attribute ((weak));
      unsigned int *const ptr = &__nptl_nthreads;
# endif
      if (! atomic_decrement_and_test (ptr))
  /* Not much left to do but to exit the thread, not the process.  */
  __exit_thread ();
#else
  /* Nothing fancy, just call the function.  */
#endif
  exit (result);
果然,libc_start_main函数的第一个参数,就是待会要调用的main函数,从声明可以看出,这个函数确实有三个参数,第一个是int类型,后面两个都是char **类型。
STATIC int LIBC_START_MAIN (int (*main) (int, char **, char ** MAIN_AUXVEC_DECL),
而且程序最后调用main函数的时候,也确实是传了三个参数。
第三个参数指向的是环境变量,在代码里面确实有函数对它做初始化。
envp类型和argv一样,都是指针数组,每个指针指向一个环境变量,并且最后以NULL结尾。
代码
要是写代码的话,可以通过循环来输出各个字符串:
#include
int main(int argc, char *argv[], char *envp[])
    int i = 0;
    while (envp[i])
        printf("%s
", envp[i++]);
    return 0;
运行的结果就是这样的。跟我们用env命令看到的基本一样。 代码
  审核编辑:汤梓红
