STM32串口中断接收不定长报文介绍
功能实现背景介绍
本项目中,需要使用STM32的USART6串口与FPGA板(下位机)通信,需要发送和接收数据,有报文应答机制。
使用的报文规则如表格所示
FPGA
板间报文的通信协议,校验使用的是和校验
U8 TX_CheckSum(U8 *buf, U8 len) //buf为数组,len为数组长度
    U8 i, ret = 0;
    for(i=0; i< len; i++)
        ret += *(buf++);
     ret = ~ret;
    return ret;
U8 RX_CheckSum(U8 *buf, U8 len) //buf为数组,len为数组长度
    U8 i, ret = 0;
        ret += *(buf++);
    ret = ret;
    return ret+1;
发送和接收的报文要满足不定长
HAL库的中断接收函数
如果要直接使用HAL库的中断接收函数,也就是HAL_UART_Receive_IT()函数
HAL_UART_Receive_IT(&huart6,UART6_RxBuffer,5);              //下位机FPGA
在使用时,选择串口,选择接收的缓冲区,选择接收长度。
  * @brief  Receives an amount of data in non blocking mode.
  * @note   When UART parity is not enabled (PCE = 0), and Word Length is configured to 9 bits (M1-M0 = 01),
  *         the received data is handled as a set of u16. In this case, Size must indicate the number
  *         of u16 available through pData.
  * @param  huart Pointer to a UART_HandleTypeDef structure that contains
  *               the configuration information for the specified UART module.
  * @param  pData Pointer to data buffer (u8 or u16 data elements).
  * @param  Size  Amount of data elements (u8 or u16) to be received.
  * @retval HAL status
HAL_StatusTypeDef HAL_UART_Receive_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
  /* Check that a Rx process is not already ongoing */
  if (huart- >RxState == HAL_UART_STATE_READY)
    if ((pData == NULL) || (Size == 0U))
      return HAL_ERROR;
    /* Process Locked */
    __HAL_LOCK(huart);
    huart- >pRxBuffPtr = pData;
    huart- >RxXferSize = Size;
    huart- >RxXferCount = Size;
    huart- >ErrorCode = HAL_UART_ERROR_NONE;
    huart- >RxState = HAL_UART_STATE_BUSY_RX;
    /* Process Unlocked */
    __HAL_UNLOCK(huart);
    /* Enable the UART Parity Error Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_PE);
    /* Enable the UART Error Interrupt: (Frame error, noise error, overrun error) */
    __HAL_UART_ENABLE_IT(huart, UART_IT_ERR);
    /* Enable the UART Data Register not empty Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_RXNE);
    return HAL_OK;
  else
    return HAL_BUSY;
这个函数本质上其实不是中断接收函数,只是配置函数,配置开启中断的信息,并且接收多少定长的数据结束本数据接收,串口的中断接收还是在中断中进行。
我们本次的长度虽然也是定长,但是有两种长度数据的接收,所以还是从设计接收不定长的数据为最终效果。
状态机的运用
对于不定长数据的接收,使用了状态机,分两次中断来接收数据
FPGA
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
	if(huart- >Instance == USART6)	                                 // 判断是由哪个串口触发的中断
		if(StateMachine_USART6)                                      //状态机为1,都接收完毕,准备校验
      if(re_flag6 == 1)
				UART6_RxCounter = 6;
				re_flag6 = 0;
      else
				len_counter6 = 2+5+UART6_RxBuffer[2]+(UART6_RxBuffer[3]< < 8);
			  if(UART6_RxBuffer[len_counter6 - 1] == 0x55 && UART6_RxBuffer[0] == 0xAA)
				  UART6_RxCounter = len_counter6;
        else
				  memset(UART6_RxBuffer,0,0x400);
					UART6_RxCounter = 0;
			StateMachine_USART6 = 0;                                   //状态机为0
      len_counter6 = 0;
		else                                                         //状态机为0,只接受到了前五个字节,继续接收后面的字节
			if(UART6_RxBuffer[0] == 0xAA)
				StateMachine_USART6 = 1;
				UART6_RxCounter = 5;
				if(UART6_RxBuffer[2] == 0 && UART6_RxBuffer[3] == 0)
				  HAL_UART_Receive_IT(&huart6,(uint8_t*)&UART6_RxBuffer[5], 1);
					re_flag6 = 1;
			  else
			    HAL_UART_Receive_IT(&huart6,(uint8_t*)&UART6_RxBuffer[5], 2 + UART6_RxBuffer[2] + (UART6_RxBuffer[3] < < 8));
			else
核心思想就是先接收报文的头,根据头来判断后面的长度,把应答报文和音量数据报文区分开,不合格的报文直接舍去同时开启新的接收。
