基于瑞萨RA6M5的信号处理工具集设计
七、重定向标准输入输出
以上实现了串口驱动,我们现在来实现串口重定向标准输入输出以方便后面的调试,处于资源和效率考虑,我们这里移植小型的xprintf而不是使用printf。添加xprintf.c xprintf.h到工程src下xprintf.h中使能以下宏
左右滑动查看完整内容
#define XF_USE_OUTPUT        1        /* 1: Enable output functions */
#define        XF_CRLF                        1        /* 1: Convert
 in the output char */
#define        XF_USE_DUMP                1        /* 1: Enable put_dump function */
#define        XF_USE_LLI                1        /* 1: Enable long long integer in size prefix ll */
#define        XF_USE_FP                1        /* 1: Enable support for floating point in type e and f */
#define XF_DPC                        '.'        /* Decimal separator for floating point */
#define XF_USE_INPUT        1        /* 1: Enable input functions */
#define        XF_INPUT_ECHO        1        /* 1: Echo back input chars in xgets function */
  hal_entry.c中
#include "xprintf.h"
设置收发接口
左右滑动查看完整内容
void xprintf_output(int ch)
        uint8_t val = (uint8_t)ch;
        drv_uart_write(&val,1);
int xprintf_input(void)
        uint8_t val;
        while(drv_uart_read(&val,1) <= 0);
        return (int)val;
          xdev_out(xprintf_output);
          xdev_in(xprintf_input);
测试
左右滑动查看完整内容
                     xprintf("%d
", 1234);             /* "1234" */
                        xprintf("%6d,%3d%%
", -200, 5);   /* "  -200,  5%" */
                        xprintf("%-6u
", 100);            /* "100   " */
                        xprintf("%ld
", 12345678);        /* "12345678" */
                        xprintf("%llu
", 0x100000000);    /* "4294967296"    */
                        xprintf("%lld
", -1LL);           /* "-1"            */
                        xprintf("%04x
", 0xA3);           /* "00a3" */
                        xprintf("%08lX
", 0x123ABC);      /* "00123ABC" */
                        xprintf("%016b
", 0x550F);        /* "0101010100001111" */
                        xprintf("%*d
", 6, 100);          /* "   100" */
                        xprintf("%s
", "abcdefg");        /* "abcdefg" */
                        xprintf("%5s
", "abc");           /* "  abc" */
                        xprintf("%-5s
", "abc");          /* "abc  " */
                        xprintf("%.5s
", "abcdefg");      /* "abcde" */
                        xprintf("%-5.2s
", "abcdefg");    /* "ab   " */
                        xprintf("%c
", 'a');              /* "a" */
                        xprintf("%12f
", 10.0);           /* "   10.000000"  */
                        xprintf("%.4E
", 123.45678);      /* "1.2346E+02"    */
                        for(;;)
                                char buffer[64];
                                char* p = buffer;
                                long a;
                                long b;
                                long c;
                                xprintf("please input int a and int b
                                xgets(buffer,sizeof(buffer));
                                xatoi(&p,&a);
                                xatoi(&p,&b);
                                c = a + b;
                                xprintf("%d + %d = %d
",a,b,c);
输入1空格2回车打印1 + 2 = 3
RA6M5
八、命令行实现
以上实现了串口重定向,我们现在实现简单的命令行,以便后面进行交互操作。设计思想是,定义命令字符串和实现函数的对应表,标准输入读一行,搜索对应表和字符串匹配,匹配则执行对应的函数。
RA6M5
实现代码见shell.c shell.h  shell_func.c  shell_func.h测试输入help回车打印如下:
RA6M5
九. ADC采集音频
使用如下麦克风采集模块ADC采集信号。
RA6M5
  参考电压为3.3V
RA6M5
  配置ADC配置P001为ADC的CH1
RA6M5
  添加相关代码
RA6M5
配置属性
RA6M5
RA6M5
RA6M5
  生成工程 RA6M5   添加adc.c和adc.h代码测试
#include "adc.h"
初始化
左右滑动查看完整内容
  adc_init();
  static uint16_t adcbuffer[1024] = {0};
循环调用
左右滑动查看完整内容
adc_read(adcbuffer, 1024);
      for(uint32_t i=0; i<1024; i++)
           {           xprintf("/*%d*/
",adcbuffer);
RA6M5
也可以添加命令行采集Shell_func.h中
void ADCFun(void* param);
Shell_func.c中
左右滑动查看完整内容
#include "adc.h"
  { (const uint8_t*)"adc",         ADCFun,         "adc"},                    /*ADC采集*/
十、ADC可视化(虚拟示波器)
通过串口将采集的数据发送到PC,PC端使用可视化上位机进行可视化,即实现了虚拟示波器的应用。
RA6M5
RA6M5
十一、DSP算法库
添加DSP算法库使用的是CMSIS-DSP的算法库
RA6M5
  添加的代码如下
RA6M5
十二、FFT谐波分析(电能质量分析)
12.1FFT算法
我们可以使用fft算法对原始数据尽心分析,得到谐波,直流量,相位,频率,幅值等信息,以进行电能质量分析,噪声分析等各种应用。
12.2添加命令行
添加命令行参数Shell_func.h中
void FftFun(void* param);
Shell_func.c中
左右滑动查看完整内容
#include "fft.h"
  { (const uint8_t*)"ft",  FftFun,  "fft"},                    /*fft分析*/
        int num;
        if(1 == sscanf(param,"%*s %d",&num))
                while(num--)
                        fft_test();
12.3代码
Fft.c fft.h见git
12.4测试
上位机输入fft 10即进行10次采样分析效果如下
RA6M5
十三、噪声检测与分析
我们也可以将开发板打造为噪声监测分析仪,对于噪声首先关心的就是其大小,我们可以实时采集声音并通过算法检测出极大值,最终换算成相对基准功率的噪声分贝值。同时也可以通过命令行控制何时进行采样分析,和其他功能是独立的,可以单独调用,集成在一起作为工具集供调用。当然也可以进行噪声的谐波等分析,和前面的点那个质量谐波分析等一样。
13.1 极大值检测算法
极大值检测算法参见:
https://www.mdpi.com/1999-4893/5/4/588/htm
13.2 添加命令行
void MaxFun(void* param);
Shell_func.c中
左右滑动查看完整内容
#include "max.h"
  { (const uint8_t*)"max",         MaxFun,         "max"},                    /*极值检测*/
        int num;
                while(num--)
                        max_test();
13.3 代码
Max.c max.h详见git
13.4 测试
上位机输入max 10即进行10次采样分析可视化显示如下,黄色线是极大值检测结果,蓝色线是原始数据。
RA6M5
十四、数字滤波器
14.1 IIR滤波器
DSP算法库中提供了很多滤波算法,我们这里将IIR添加到我们的工具集中进行演示。
14.2 添加命令行
void IirFun(void* param);
Shell_func.c中
左右滑动查看完整内容
#include "iir.h"
  { (const uint8_t*)"iir",         IirFun,         "iir"},                    /*滤波分析*/
        int num;
                while(num--)
                        iir_test();
14.3代码
Iir.c iir.h详见git
14.4测试
上位机输入iir 10即进行10次采样分析可视化显示如下,黄色线滤波结果,蓝色线是原始数据。
RA6M5
十五、相位频率幅值分析(频率计等)
15.1 相位分析
FFT计算结果,幅值最大的横坐标对应信号频率,纵坐标对应幅度。幅值最大的为out[m]=val;则信号频率f0=(Fs/N)m ,信号幅值Vpp=val/(N/2)。N为FFT的点数,Fs为采样频率。相位Pha=atan2(a, b)弧度制,其中ab是输出虚数结果的实部和虚部。
15.2 添加命令行
Void FrqFun(void* param);
Shell_func.c中
左右滑动查看完整内容
#include "frq.h"
  { (const uint8_t*)"frq",         FrqFun,         "frq"},                    /*相位分析*/
void FrqFun(void* param)
        int num;
                while(num--)
                        Frq_test();
15.3 代码
Frq.c frq.h详见git
15.4 测试
上位机输入frq 10即进行10次采样分析
RA6M5
十六、总结
本开发板性能资源比较丰富,特别适合开发和验证等。本文基于该开发板实现了信号处理前端,实现了虚拟示波器、噪声分析仪、电能质量分析仪、数字滤波器等功能的集合,并且可以方便的快速添加更多的应用。可以基于CLI调用方便脚本化使用,可以使用上位机可视化,是一个瑞士军刀类型的工具集。目前支持的CLI命令如下,可以快速扩展更多应用。
RA6M5
审核编辑:汤梓红
