STM32库函数开发&按键库函数开发源码篇
LED流水灯
led.h
#ifndef __LED_H
#define __LED_H
#include "stm32f4xx.h"
void Led_Init(void);
void Led1_Init(void);
void Led2_Init(void);
void Led3_Init(void);
void Led4_Init(void);
#endif
typedef struct
  uint32_t GPIO_Pin;              /* 指定要配置的GPIO引脚 */
  GPIOMode_TypeDef GPIO_Mode;     /* 指定选定接点的操作模式。*/
  GPIOSpeed_TypeDef GPIO_Speed;   /* 指定选定接点的速度。*/
  GPIOOType_TypeDef GPIO_OType;   /* 指定选定接点的操作输出类型。*/
  GPIOPuPd_TypeDef GPIO_PuPd;     /* 指定选定接点的操作上拉/下拉。*/
}GPIO_InitTypeDef;
led.c
#include "led.h"
// init 4 pin
void Led_Init(void)
  GPIO_InitTypeDef  GPIO_InitStruct;
  //使能GPIOE组时钟
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
  //使能GPIOF组时钟
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);
  // GPIOF pin9 pin10
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_9|GPIO_Pin_10;    //引脚9/10
  GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_OUT;  //输出模式
  GPIO_InitStruct.GPIO_OType  = GPIO_OType_PP;  //推挽输出
  GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;    //上拉
  GPIO_InitStruct.GPIO_Speed  = GPIO_Speed_50MHz; //速度
  GPIO_Init(GPIOF, &GPIO_InitStruct);
  // GPIOE pin9 pin10
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_13|GPIO_Pin_14;    //引脚13/14
  GPIO_Init(GPIOE, &GPIO_InitStruct);
引脚说明:
LED0 -- PF9
  //使能GPIOF组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_9;    //引脚9
引脚说明:
LED2 -- PF10
  //使能GPIOF组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_10;    //引脚10
引脚说明:
LED3 -- PE13
  //使能GPIOE组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_13;    //引脚13
引脚说明:
LED4 -- PE14
  //使能GPIOE组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_14;    //引脚14
main.c
#include "led.h"
// 延时
void delay(int n)
  int i,j;
  for(i=0; i< n; i++)
    for(j=0; j< 30000; j++);
int main(void)
//  Led1_Init();
//  Led2_Init();
//  Led3_Init();
//  Led4_Init();
  Led_Init();
  while(1)
    //输出0  LED0灯亮
    GPIO_ResetBits(GPIOF, GPIO_Pin_9);
    delay(1000);
    //输出1  LED0灯灭
    GPIO_SetBits(GPIOF, GPIO_Pin_9);
    //输出0  LED1灯亮
    GPIO_ResetBits(GPIOF, GPIO_Pin_10);
    delay(1000);
    //输出1  LED1灯灭
    GPIO_SetBits(GPIOF, GPIO_Pin_10);
    //输出0  LED2灯亮
    GPIO_ResetBits(GPIOE, GPIO_Pin_13);
    delay(1000);
    //输出1  LED2灯灭
    GPIO_SetBits(GPIOE, GPIO_Pin_13);
    //输出0  LED3灯亮
    GPIO_ResetBits(GPIOE, GPIO_Pin_14);
    delay(1000);
    //输出1  LED3灯灭
    GPIO_SetBits(GPIOE, GPIO_Pin_14);
  return 0;
按键控制灯
#ifndef __LED_H
#define __LED_H
#define LED0_ON    GPIO_ResetBits(GPIOF, GPIO_Pin_9)
#define LED0_OFF  GPIO_SetBits(GPIOF, GPIO_Pin_9)
#endif
#include "led.h"
引脚说明:
LED0 -- PF9
LED1 -- PF10
LED2 -- PE13
LED3 -- PE14
void Led_Init(void)
  //使能GPIOE组时钟
  //使能GPIOF组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_9|GPIO_Pin_10;    //引脚9 10
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_13|GPIO_Pin_14;    //引脚13 14
#ifndef __KEY_H
#define __KEY_H
void Key_Init(void);
#endif
#include "key.h"
引脚说明:
KEY0--PA0
void Key_Init(void)
  //使能GPIOA组时钟
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_0;    //引脚0
  GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_IN;    //输入模式
  GPIO_Init(GPIOA, &GPIO_InitStruct);
main.c
#include "led.h"
#include "key.h"
void delay(int n)
  int i,j;
  for(i=0; i< n; i++)
int main(void)
  unsigned char count = 0;
  Key_Init();
  Led_Init();
  while(1)
    //应用场景1
    //判断按键是否按下 按下为低电平
    if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0) == Bit_RESET)
      //大约延时20ms 起到消抖作用
      delay(20);
      //判断按键是否按下 按下为低电平
        //灯状态变更
        GPIO_ToggleBits(GPIOF, GPIO_Pin_9);
        count++;
    //根据按键时长实现不同的功能
    if(count == 50)
    //应用场景2  比如输入银行密码
    //判断按键是否按下 按下为低电平
      //大约延时15ms 起到消抖作用
      delay(15);
      //判断按键是否按下 按下为低电平
        //等待按键松开
        while(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0) == Bit_RESET);
        //灯状态变更
  return 0;
按键中断
#ifndef __EXTI_H
#define __EXTI_H
void Exti_PA0_Init(void);
#endif
#include "exti.h"
引脚说明:
KEY0--PA0(选择下降沿触发)
  EXTI_InitTypeDef  EXTI_InitStruct;
  NVIC_InitTypeDef  NVIC_InitStruct;
  //使能SYSCFG及GPIOA时钟:
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  //使能GPIOA组时钟
  //初始化IO口为输入。
  //设置IO口与中断线的映射关系。
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0);
  EXTI_InitStruct.EXTI_Line  = EXTI_Line0;      //中断线0
  EXTI_InitStruct.EXTI_Mode  = EXTI_Mode_Interrupt;  //中断模式
  EXTI_InitStruct.EXTI_Trigger= EXTI_Trigger_Falling;  //下降触发
  EXTI_InitStruct.EXTI_LineCmd= ENABLE;        //中断使能
  //初始化线上中断,设置触发条件等。
  EXTI_Init(&EXTI_InitStruct);
  NVIC_InitStruct.NVIC_IRQChannel            = EXTI0_IRQn;     //中断通道,可在stm32f4xx.h文件当中查找
  NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority  = 1;        //抢占优先级
  NVIC_InitStruct.NVIC_IRQChannelSubPriority      = 1;        //响应优先级
  NVIC_InitStruct.NVIC_IRQChannelCmd          = ENABLE;      //通道使能
  //配置中断分组(NVIC),并使能中断。
  NVIC_Init(&NVIC_InitStruct);
void delays(int n)
  int i,j;
  for(i=0; i< n; i++)
1、中断服务函数是满足条件后,CPU自行执行的函数不需要主动调用
2、中断服务函数是不能传递值与返回值
3、STM32的中断服务函数名可在startup_stm32f40_41xxx.s中查找
//编写中断服务函数
void EXTI0_IRQHandler(void)
  //判断标志位是否1
  if(EXTI_GetITStatus(EXTI_Line0) == SET)
      //延时一段时间
      delays(15);
  //清空中断线0
  EXTI_ClearITPendingBit(EXTI_Line0);
main.c
#include "led.h"
#include "key.h"
void delay(int n)
  int i,j;
  for(i=0; i< n; i++)
int main(void)
  Key_Init();
  Led_Init();
  while(1)
    //判断按键1是否按下 按下为低电平
      //大约延时15ms 起到消抖作用
      delay(15);
      //判断按键1是否按下 按下为低电平
        //等待按键1松开
        //灯1状态变更
    //判断按键2是否按下 按下为低电平
    if(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_2) == Bit_RESET)
      //大约延时15ms 起到消抖作用
      delay(15);
      //判断按键2是否按下 按下为低电平
        //等待按键2松开
        while(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_2) == Bit_RESET);
        //灯2状态变更
        GPIO_ToggleBits(GPIOF, GPIO_Pin_10);
    //判断按键3是否按下 按下为低电平
    if(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_3) == Bit_RESET)
      //大约延时15ms 起到消抖作用
      delay(15);
      //判断按键3是否按下 按下为低电平
        //等待按键3松开
        while(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_3) == Bit_RESET);
        //灯3状态变更
        GPIO_ToggleBits(GPIOE, GPIO_Pin_13);
    //判断按键4是否按下 按下为低电平
    if(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_4) == Bit_RESET)
      //大约延时15ms 起到消抖作用
      delay(15);
      //判断按键4是否按下 按下为低电平
        //等待按键4松开
        while(GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_4) == Bit_RESET);
        //灯4状态变更
        GPIO_ToggleBits(GPIOE, GPIO_Pin_14);
  return 0;
作业
#ifndef __BEEP_H
#define __BEEP_H
void Beep_Init(void);
#endif
#include "beep.h"
引脚说明
Beep -- PF8
void Beep_Init()
  //使能GPIOF组时钟
  GPIO_InitStruct.GPIO_Pin  = GPIO_Pin_8;    //引脚8
  GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_DOWN;    //xia la
  GPIO_InitStruct.GPIO_Speed  = GPIO_Speed_100MHz; //速度
#include "beep.h"
void delay(int n)
  int i,j;
  for(i=0; i< n; i++)
int main(void)
  Beep_Init();
  while(1)
    GPIO_ResetBits(GPIOF, GPIO_Pin_8);
    delay(1000);
    GPIO_SetBits(GPIOF, GPIO_Pin_8);
    delay(1000);
  return 0;
