CS5203设计资料|无HDCP功能HDMI转VGA方案
消耗积分:0 | 格式:pdf | 大小:5.84 MB | 2023-11-02
深圳市安格瑞科技有限公司
  • 94内容
  • 11w+阅读
  • 245粉丝
The Capstone CS5203 HDMI to VGA converter combines a HDMI input interface and an analog RGB DAC output. With support and on-chip Audio DAC, it saves cost and optimizes board space. The embedded MCU is based on an industrial standard 8051 core.
The CS5203 is suitable for multiple market segment and display applications such as
 motherboard, desktop, dongle, and docking system.
General
HDMI1.4 compliant receiver
VGA output interface ,DAC speed up to 200-MHz Pixel rate ,8-bit
Video resolution support up to 1920*1200@60and 1920*1080@60Hz
Embedded oscillator and there is no need for external crystal
Embedded linear dropout regultator (LDO)
Embedded MCU
Embedded EDID(CS5203 will response EDID if terminal does not have it )
Support EEPROM Free mode by using the internal pre-blew ROM
VGA Connection detection supported
Internal power-on-reset(POR)
Daul Channel 16-bit resolution sigma-delta DAC
Suppport Audio Sampling Frequently (Fs): up to 48Khz
I2C Slave interface and HDMI DDC interface are available for debug
QFN34 4*4 Package
HDMI Digital Input
HDMI1.4 compliant
Built-in high-performance adaptive equalizer
Support Hot Plug Detection
VGA Output Interface
Triple 8-bit DAC Digital-to-Analog Converter with clock up to 200-MHZ
Embedded V-sync/H-sync 5V buffer
VESA VSIS V1R2 compliant
Embedded MCU
Industrial standard 8051core
Support I2C Master and Slave up to 400-Khz
Power & Technology
评论(0)
发评论
下载排行榜
