python中用区域掩模实现车道线检测
1.颜色阈值+ 区域掩模
我们可以仅仅通过设置一些RGB通道阈值,来提取车道线。
以下的代码设置了RGB通道阈值为220,大于220的像素将设置为黑色,这样可以将测试图片中的车道线提取出来
效果如下
检测
我们发现符合阈值的像素既包括了车道线,也包含了其他非车道线部分。
显然,一个成熟的自动驾驶感知算法,是不可能使用这种方法的。仅仅依靠颜色,既不科学也不鲁棒。
有一种改进思路是利用图像掩模的方法
假设拍摄图像的前置摄像头安装在汽车上的固定位置,这样车道线将始终出现在图像的相同区域中。我们将设置了一个区域,认为车道线处于该区域内。
我们设置了一个三角形的区域,原则上你可以使用其他形状
![图
python代码如下
import matplotlib.pyplot as plt
import matplotlib.image as mpimg
import numpy as np
# Read in the image
image = mpimg.imread('test.jpg')
# Grab the x and y sizes and make two copies of the image
# With one copy we'll extract only the pixels that meet our selection,
# then we'll paint those pixels red in the original image to see our selection
# overlaid on the original.
ysize = image.shape[0]
xsize = image.shape[1]
color_select= np.copy(image)
line_image = np.copy(image)
# Define our color criteria
red_threshold = 220
green_threshold = 220
blue_threshold = 220
rgb_threshold = [red_threshold, green_threshold, blue_threshold]
# Define a triangle region of interest (Note: if you run this code,
left_bottom = [0, ysize-1]
right_bottom = [xsize-1, ysize-1]
apex = [650, 400]
fit_left = np.polyfit((left_bottom[0], apex[0]), (left_bottom[1], apex[1]), 1)
fit_right = np.polyfit((right_bottom[0], apex[0]), (right_bottom[1], apex[1]), 1)
fit_bottom = np.polyfit((left_bottom[0], right_bottom[0]), (left_bottom[1], right_bottom[1]), 1)
# Mask pixels below the threshold
color_thresholds = (image[:,:,0] < rgb_threshold[0]) |
                    (image[:,:,1] < rgb_threshold[1]) |
                    (image[:,:,2] < rgb_threshold[2])
# Find the region inside the lines
XX, YY = np.meshgrid(np.arange(0, xsize), np.arange(0, ysize))
region_thresholds = (YY > (XX*fit_left[0] + fit_left[1])) &
                    (YY  > (XX*fit_right[0] + fit_right[1])) &
                    (YY < (XX*fit_bottom[0] + fit_bottom[1]))
# Mask color selection
color_select[color_thresholds] = [0,0,0]
# Find where image is both colored right and in the region
line_image[~color_thresholds & region_thresholds] = [255,0,0]
# Display our two output images
plt.imshow(color_select)
plt.imshow(line_image)
# uncomment if plot does not display
plt.show()
