机器人最优控制的程序实现
程序实现:
在MATLAB中可采用的语法为:
[K,S,P] = lqr(sys,Q,R,N)
[K,S,P] = lqr(A,B,Q,R,N)
也就是说,目的是计算最佳增益矩阵K
下面以一个例子实现LQR的解法;
M = 85.5; %input 1
m = 8.5; %input 2
b = 0.6;
I = 0.008;
g = 9.8;
l = 0.5;
x0 = [0.2 0 0 0];
a1 = 1;
a2 = 2;
Q = 20;
R=10;
%states = {'x' 'x_dot' 'phi' 'phi_dot'};
p = I*(M+m)+M*m*l^2; %denominator for the A and B matrices
A = [0      1              0           0;
     0 -(I+a2*l^2)*b/p  (a2^2*g*l^2)/p   0;
    0      0              0           1;
    0 -(a2*l*b)/p       a2*g*l*(a1+a2)/p  0];
B = [     0;
    (I+a2*l^2)/p;
        0;
        a2*l/p];
[K,S,P] = lqr(A,B,Q,R)
运行可以得到:
K =
   -1.4142  -62.4810   67.4838  187.5249
S =
   1.0e+05 *
    0.0088    0.1913   -0.0265   -0.1230
    0.1913    7.3677   -1.0374   -4.8827
   -0.0265   -1.0374    0.5767    1.7582
   -0.1230   -4.8827    1.7582    5.9016
P =
  -0.0262 + 0.0258i
  -0.0262 - 0.0258i
  -0.4016 + 0.0093i
  -0.4016 - 0.0093i
程序可视化:
sys = ss(A,B,eye(4),[0;0;0;0]);
sysclosed = ss(A-B*K,[0;0;0;0],eye(4),[0;0;0;0]);
figure(15)
[ycl,tcl,xcl] = initial(sysclosed,x0);
plot(tcl,ycl(:,1),tcl,ycl(:,2),tcl,ycl(:,3),tcl,ycl(:,4))
title('LQR ')
xlabel('时间')
ylabel('输出')
legend('x','x_dot','phi','phi_dot')
最优控制
LQR 启发式作为基于样本的运动规划算法(例如 RRT 或 RRT*)的扩展,可以是相对低成本的距离度量,并在具有复杂或欠驱动动态的域中找到最佳计划。
%            LQR Steer
function x_new = LQRSteer( x_nearest, x_rand, K_rand )
% This function contains system's explicit dynamics
global model;
m   = model.phy.m;
l   = model.phy.l;
b   = model.phy.b;
g   = model.phy.g;
h   = model.h;
u       = -K_rand*( x_nearest - x_rand )';
x_dot   = [ x_nearest(2), ( u - b*x_nearest(2) - m*g*l*sin(x_nearest(1)) ) ];
x_new   = x_nearest + x_dot*h;
end
此MATLAB function可以从来执行系统动力学描述;
%            LQR Near
function X_near_ids = LQRNear( x_new, S_new, id_nearest )
global GNodes nun;
% Define Neighborhood Radius
gamma   = 1;  d   = 2;
ner     = gamma*( log(nun+1)/nun )^(1/d);
% Allocate and Assign to Output
X_near_ids  = id_nearest;
  for i = 1 : nun
    x    = GNodes( i, 1:2 );
    cost = (x-x_new)*S_new*(x-x_new)';
    if cost < ner
        X_near_ids(end+1)    = i;
    end
  end
X_near_ids  = unique(X_near_ids);
end
输入期望的初始参数,根据定义算法的逻辑可实现期望数值的求解;
线性二次高斯(LQG)优化控制设计方法,它是线性二次估计器(LQE)(即卡尔曼滤波器)和线性二次调节器(LQR)的组合。
对于逆最优问题,建议读者阅读 Zhifei 和 Joo的文章。最优控制理论的逆问题通过二次逼近 (BOBYQA) 技术 的边界优化来适应和解决。
人工操作任务的成本函数是从给定的演示中建模的,同时考虑与环境的接触。引入逆Karush-Kuhn-Tucker(KKT)逆最优控制算法来学习具有接触约束的操纵任务的成本函数。
最优控制理论的主要关注点是找出在满足某些最优标准的同时将给定系统推向所需状态的控制信号。
线性二次调节器 (LQR) 是优化控制的一种变体,其中系统动力学由一组线性微分方程建模。此外,最优标准由包含系统状态和输入的二次函数描述。
考虑智能体之间的关系,也可以用LQR来求解出最优解;
寻找规定机器人阻抗模型的最佳参数的问题被转化为线性二次调节器 (LQR) 问题,该问题最大限度地减少了人力并优化了 HRI 系统针对给定任务的闭环行为。
为了避免对人体模型知识的要求,可以使用积分强化学习来解决给定的 LQR 问题。
