一个注解搞定SpringBoot接口防刷
 一,技术要点:springboot的基本知识,redis基本操作,
首先是写一个注解类:
import java.lang.annotation.Retention;
import java.lang.annotation.Target;
import static java.lang.annotation.ElementType.METHOD;
import static java.lang.annotation.RetentionPolicy.RUNTIME;
 * @author yhq
 * @date 2018/9/10 15:52
@Retention(RUNTIME)
@Target(METHOD)
public @interface AccessLimit {
    int seconds();
    int maxCount();
    boolean needLogin()default true;
拦截器中实现:
import com.alibaba.fastjson.JSON;
import com.example.demo.action.AccessLimit;
import com.example.demo.redis.RedisService;
import com.example.demo.result.CodeMsg;
import com.example.demo.result.Result;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Component;
import org.springframework.web.method.HandlerMethod;
import org.springframework.web.servlet.handler.HandlerInterceptorAdapter;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.io.OutputStream;
 * @author yhq
 * @date 2018/9/10 16:05
@Component
public class FangshuaInterceptor extends HandlerInterceptorAdapter {
    @Autowired
    private RedisService redisService;
    @Override
    public boolean preHandle(HttpServletRequest request, HttpServletResponse response, Object handler) throws Exception {
        //判断请求是否属于方法的请求
        if(handler instanceof HandlerMethod){
            HandlerMethod hm = (HandlerMethod) handler;
            //获取方法中的注解,看是否有该注解
            AccessLimit accessLimit = hm.getMethodAnnotation(AccessLimit.class);
            if(accessLimit == null){
                return true;
            int seconds = accessLimit.seconds();
            int maxCount = accessLimit.maxCount();
            boolean login = accessLimit.needLogin();
            String key = request.getRequestURI();
            //如果需要登录
            if(login){
                //获取登录的session进行判断
                key+=""+"1";  //这里假设用户是1,项目中是动态获取的userId
            //从redis中获取用户访问的次数
            AccessKey ak = AccessKey.withExpire(seconds);
            Integer count = redisService.get(ak,key,Integer.class);
            if(count == null){
                //第一次访问
                redisService.set(ak,key,1);
            }else if(count < maxCount){
                //加1
                redisService.incr(ak,key);
            }else{
                //超出访问次数
                render(response,CodeMsg.ACCESS_LIMIT_REACHED); //这里的CodeMsg是一个返回参数
                return false;
        return true;
    private void render(HttpServletResponse response, CodeMsg cm)throws Exception {
        response.setContentType("application/json;charset=UTF-8");
        OutputStream out = response.getOutputStream();
        String str  = JSON.toJSONString(Result.error(cm));
        out.write(str.getBytes("UTF-8"));
        out.flush();
        out.close();
注册到springboot中
import com.example.demo.ExceptionHander.FangshuaInterceptor;
import org.springframework.context.annotation.Configuration;
import org.springframework.web.servlet.config.annotation.InterceptorRegistry;
import org.springframework.web.servlet.config.annotation.WebMvcConfigurerAdapter;
 * @author yhq
 * @date 2018/9/10 15:58
@Configuration
public class WebConfig extends WebMvcConfigurerAdapter {
    @Autowired
    private FangshuaInterceptor interceptor;
    @Override
    public void addInterceptors(InterceptorRegistry registry) {
        registry.addInterceptor(interceptor);
在Controller中加入注解
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.ResponseBody;
 * @author yhq
 * @date 2018/9/10 15:49
@Controller
public class FangshuaController {
    @AccessLimit(seconds=5, maxCount=5, needLogin=true)
    @RequestMapping("/fangshua")
    @ResponseBody
    public Result fangshua(){
        return Result.success("请求成功");
审核编辑:刘清
