匹配器
2.1 ICP点云精配准
template < typename PointCloudPtr > bool ex_segmentor::icp_registration(PointCloudPtr &input_obj, PointCloudPtr &input_scene, PointCloudPtr &output_obj, Eigen::Matrix4f &result_transform, float &result_error, uint max_iteration, float max_distance, float ransac_th) // icp匹配
{ pcl::IterativeClosestPoint< PointXYZRGB, PointXYZRGB > icp; // icp对象
icp.setInputSource(input_obj); //设置输入源点云
icp.setInputTarget(input_scene); //设置输入目标点云 //
Set the max correspondence distance to 5cm (e.g., correspondences with higher distances will be ignored) icp.setMaxCorrespondenceDistance(max_distance); //设置最大匹配距离 0.05 //
Set the maximum number of iterations (criterion 1) icp.setMaximumIterations(max_iteration); //设置最大迭代次数 50 // Set the transformation epsilon (criterion 2) //
icp.setTransformationEpsilon (1e-5); //1e-8 //
Set the euclidean distance difference epsilon (criterion 3) //
icp.setEuclideanFitnessEpsilon (0.000001); //1
icp.setRANSACOutlierRejectionThreshold(ransac_th); //设置RANSAC阈值
icp.align(*output_obj); // icp匹配 if (icp.hasConverged()) //如果icp匹配成功
{ result_transform = icp.getFinalTransformation(); //获取最终变换矩阵
result_error = icp.getFitnessScore(); //获取最终匹配误差
return true; }
else
{ result_transform = Eigen::Matrix4f::Identity(4, 4); result_error = 1.0; return false; } }/** icp_registration(object_aligned, cluster, Final, icp_result_transform, icp_error);**/
2.2 FPFH点云粗配准
void FPFH_generation(pcl::PointCloud<PointXYZRGB>::Ptr &input, FPFHCloud::Ptr &output) // FPFH特征提取 { // 首先,生成法线
pcl::NormalEstimationOMP<PointNormal, PointNormal> nest; // OMP线程数
pcl::PointCloud<PointNormal>::Ptr temp(new pcl::PointCloud<PointNormal>); //构建暂时点云
pcl::copyPointCloud(*input, *temp); //拷贝点云
nest.setRadiusSearch(0.01); //设置半径搜索范围
nest.setInputCloud(temp); //设置输入点云
nest.compute(*temp); //计算暂时点云 // 然后生成FPFH点云 pcl::FPFHEstimationOMP<PointNormal, PointNormal, FPFH> fest; // OMP线程数
fest.setRadiusSearch(0.01); // 0.025
fest.setInputCloud(temp);
fest.setInputNormals(temp); fest.compute(*output); }
template <typename PointType, typename PointCloudPtr> bool
FPFH_matching(PointCloudPtr &object, FPFHCloud::Ptr &object_feature, PointCloudPtr &scene, FPFHCloud::Ptr &scene_feature, PointCloudPtr &result_cloud, Eigen::Matrix4f &result_transformation) // FPFH粗配准方法
{ pcl::SampleConsensusPrerejective<PointType, PointType, FPFH> align; //采样一致性预排除算法
align.setInputSource(object); //设置输入源点云
align.setSourceFeatures(object_feature); //设置输入源特征点云
align.setInputTarget(scene); //设置输入目标点云
align.setTargetFeatures(scene_feature); //设置输入目标特征点云
align.setMaximumIterations(5000); // 设置最大迭代次数
align.setNumberOfSamples(7); // 设置采样点数
align.setCorrespondenceRandomness(10); // 设置随机匹配点数
align.setSimilarityThreshold(0.5f); // 设置相似度阈值
align.setMaxCorrespondenceDistance(0.01f); // 设置最大匹配距离
align.setInlierFraction(0.05f); // 设置内点比例 align.align(*result_cloud); if (align.hasConverged())
{ result_transformation = align.getFinalTransformation(); //获取最终变换矩阵 // pcl::console::print_info("Inliers: %i/%i , %in", align.getInliers().size(), scene->size(), object->size()); // return (float(align.getInliers().size()) / float(object->size())); return true; } // return 0.0f; return false; }/**
FPFHCloud::Ptr cluster_feature(new FPFHCloud); FPFH_generation(cluster, cluster_feature);
ROS_INFO("cluster_size : %d, feature size : %d", cluster->size(), cluster_feature->size());
bool FPFH_match_success = FPFH_matching<PointXYZRGB>(object_, object_feature_, cluster, cluster_feature, object_aligned, align_result_transform);**/
2.3 PCA点云粗配准
void ex_segmentor::PCA_registration(pcl::PointCloud< PointXYZRGB >::Ptr
