std_svc_setup //services/std_svc/std_svc_setup.c
- >psci_setup //lib/psci/psci_setup.c
- >plat_setup_psci_ops //设置平台的psci操作 调用平台的plat_setup_psci_ops函数去设置psci操作 eg:qemu平台
- >*psci_ops = &plat_qemu_psci_pm_ops;
208 static const plat_psci_ops_t plat_qemu_psci_pm_ops = {
209 .cpu_standby = qemu_cpu_standby,
210 .pwr_domain_on = qemu_pwr_domain_on,
211 .pwr_domain_off = qemu_pwr_domain_off,
212 .pwr_domain_suspend = qemu_pwr_domain_suspend,
213 .pwr_domain_on_finish = qemu_pwr_domain_on_finish,
214 .pwr_domain_suspend_finish = qemu_pwr_domain_suspend_finish,
215 .system_off = qemu_system_off,
216 .system_reset = qemu_system_reset,
217 .validate_power_state = qemu_validate_power_state,
218 .validate_ns_entrypoint = qemu_validate_ns_entrypoint
219 };
在遍历每一个注册的运行时服务的时候,会导致std_svc_setup调用,其中会做psci操作集的设置,操作集中我们可以看到对核电源的管理的接口如:核上电,下电,挂起等,我们主要关注上电 .pwr_domain_on = qemu_pwr_domain_on,这个接口当我们主处理器boot从处理器的时候会用到。
smc指令触发进入el3异常向量表:
runtime_exceptions //el3的异常向量表
- >sync_exception_aarch64
- >handle_sync_exception
- >smc_handler64
- > ¦* Populate the parameters for the SMC handler.
¦* We already have x0-x4 in place. x5 will point to a cookie (not used
¦* now). x6 will point to the context structure (SP_EL3) and x7 will
¦* contain flags we need to pass to the handler Hence save x5-x7.
¦* Note: x4 only needs to be preserved for AArch32 callers but we do it
¦* for AArch64 callers as well for convenience
stp x4, x5, [sp, #CTX_GPREGS_OFFSET + CTX_GPREG_X4] //保存x4-x7到栈
stp x6, x7, [sp, #CTX_GPREGS_OFFSET + CTX_GPREG_X6]
/* Save rest of the gpregs and sp_el0*/
save_x18_to_x29_sp_el0
mov x5, xzr //x5清零
mov x6, sp //sp保存在x6
/* Get the unique owning entity number */ //获得唯一的入口编号
ubfx x16, x0, #FUNCID_OEN_SHIFT, #FUNCID_OEN_WIDTH
ubfx x15, x0, #FUNCID_TYPE_SHIFT, #FUNCID_TYPE_WIDTH
orr x16, x16, x15, lsl #FUNCID_OEN_WIDTH
adr x11, (__RT_SVC_DESCS_START__ + RT_SVC_DESC_HANDLE)
/* Load descriptor index from array of indices */
adr x14, rt_svc_descs_indices //获得服务描述 标识数组
ldrb w15, [x14, x16] //根据唯一的入口编号 找到处理函数的 地址
¦* Restore the saved C runtime stack value which will become the new
¦* SP_EL0 i.e. EL3 runtime stack. It was saved in the 'cpu_context'
¦* structure prior to the last ERET from EL3.
ldr x12, [x6, #CTX_EL3STATE_OFFSET + CTX_RUNTIME_SP]
¦* Any index greater than 127 is invalid. Check bit 7 for
¦* a valid index
tbnz w15, 7, smc_unknown
/* Switch to SP_EL0 */
msr spsel, #0
¦* Get the descriptor using the index
¦* x11 = (base + off), x15 = index
¦* handler = (base + off) + (index < < log2(size))
lsl w10, w15, #RT_SVC_SIZE_LOG2
ldr x15, [x11, w10, uxtw]
¦* Save the SPSR_EL3, ELR_EL3, & SCR_EL3 in case there is a world
¦* switch during SMC handling.
¦* TODO: Revisit if all system registers can be saved later.
mrs x16, spsr_el3 //spsr_el3保存在x16
mrs x17, elr_el3 //elr_el3保存在x17
mrs x18, scr_el3 //scr_el3保存在x18
stp x16, x17, [x6, #CTX_EL3STATE_OFFSET + CTX_SPSR_EL3] / x16, x17/保存在栈
str x18, [x6, #CTX_EL3STATE_OFFSET + CTX_SCR_EL3] //x18保存到栈
/* Copy SCR_EL3.NS bit to the flag to indicate caller's security */
bfi x7, x18, #0, #1
mov sp, x12
¦* Call the Secure Monitor Call handler and then drop directly into
¦* el3_exit() which will program any remaining architectural state
¦* prior to issuing the ERET to the desired lower EL.
#if DEBUG
cbz x15, rt_svc_fw_critical_error
#endif
blr x15 //跳转到处理函数
b el3_exit //从el3退出 会eret 回到el1 (后面会讲到)
上面其实主要的是找到服务例程,然后跳转执行 下面是跳转的处理函数:
std_svc_smc_handler //services/std_svc/std_svc_setup.c
- >ret = psci_smc_handler(smc_fid, x1, x2, x3, x4,
¦ cookie, handle, flags)
480 } else {
481 /* 64-bit PSCI function */
482
483 switch (smc_fid) {
484 case PSCI_CPU_SUSPEND_AARCH64:
485 ret = (u_register_t)
486 psci_cpu_suspend((unsigned int)x1, x2, x3);
487 break;
488
489 case PSCI_CPU_ON_AARCH64:
490 ret = (u_register_t)psci_cpu_on(x1, x2, x3);
491 break;
492
