SD NAND 可靠性验证测试
可获得潜在客户线索数量 10+
SD NAND 可靠性验证测试的重要性
SD NAND可靠性验证测试至关重要。通过检验数据完整性、设备寿命、性能稳定性,确保产品符合标准,可提高产品的可信度、提高品牌声誉,减少维修成本,确保产品质量和市场竞争力。
MK-米客方德是一家做存储的公司,是SD NAND技术的引领者,工业应用的领导品牌。其公司SD NAND产品都有可靠性验证测试报告,
SD NAND 可靠性验证测试报告
以MK-米客方德工业级SD NAND的MKDN064GCL-ZA型号为例,下面是可靠性验证测试的具体项目。
『Test Summary』
No
Test Item
Description
Result
1
Card Density Check
90%
Pass
2
Performance Test
HDBench/CrystalDiskMark/H2test
3
Compliance Test
TestMetrix VTE3100/VTE4100
Pass
4
Speed Class Test
Pass
5
Full Size Copy/Compare
H2test
Pass
6
Burn-in Test
BIT @-25~ 85’C
Pass
7
NPOR Test
Normal power cycle test when card is stand by
Pass
8
SPOR Test
Sudden power cycle test when card is busy
Pass
9
Read Only Test
H2test
Pass
10
IR-Reflow
260 ’C, check SLC data
Pass
11
Power consumption
Write & Read current measurement
Test Item
  1. Card Density Check
Test Tool & Environment
  1. SD Formatter
  2. Win7 OS
Sample Quantity
1ea
Result
7374MB, 90%
  1. Performance Test
    1. HDBench / CrystalDiskMark / IOMeter / H2test
  1. HDBench Ver3.40 / CrystalDiskMark 6.0 / IO meter / H2 test
  2. Card Reader : Transcend TS-RDP5K (GL834)
  3. Win7 OS
    1. IO Meter
Test Criteria
Depends on customer criteria
Sample Quantity
2ea
Result
Pass (see 2.4 performance data)
1. IO Meter 2006.07.27
  1. Card Reader : Transcend TS-RDP5K (GL834)
  2. Win7 OS
    1. TestMetrix
Test Criteria
Sample Quantity
2ea
Result
1. TestMetrix VTE3100/VTE4100
Test Criteria
Sample Quantity
3ea
Result
  1. Performance Data
Test Item
Test Mode
Result
HDBench (100MB)
Sequential Read (MB/s)
46.2
Sequential Write (MB/s)
24.2
CrystalDiskMark (100MB)
47.5
26
IOMeter (100MB)
Random Write (IOPS)
572.6
Random Read (IOPS)
1119.5
TestMetrix
24.4
10
H2test
40.6
10
  1. Compliance Test
Test Criteria
Test done without error
Sample Quantity
3ea
Result
Pass
  1. Speed Class Test
Test Criteria
Pass class 6 condition
Sample Quantity
3ea
Result
Pass
Speed Class
Test Mode
Result
Class6
Pw (MB/s)
8.5
Pr (MB/s)
9.6
  1. Full Size Copy/Compare
  1. H2test v1.4
  3. Win7 OS
Test Criteria
Test done without no error
Sample Quantity
2ea
Result
Pass
  1. Burn-in Test
BIT v8.0
  1. BurnInTest v8.0
  3. Win7 OS
Test Criteria
168hours without error @25/85/-25’C
Sample Quantity
Total 6ea
Result
Pass
  1. NPOR Test
1. MK NPOR Tool
Test Criteria
Pass 10K cycles
Sample Quantityv
2ea
Result
Pass
  1. SPOR
    1. SPOR Test1
1. MK SPOR Tool – 5%/95% non-file system
Test Criteria
Pass 10K cycles
Sample Quantity
2ea
Result
Pass
  1. SPOR Test2
1. Specific SPOR Tool – small/large file system based
Test Criteria
Pass 10K cycles
Sample Quantity
2ea
Result
Pass
  1. Read Only Test
  1. H2test
  3. Win7 OS
Test Criteria
72hours without error
Sample Quantity
4ea
Result
Pass
  1. IR-reflow
IR-reflow 260 ‘C
Test Criteria
3 times test and check all data without error
Sample Quantity
10ea
Result
pass
  1. Powerconsumption
  1. CrystalDiskMark 6.0
  3. Win7 OS
  4. Agilent U1252B
Item
Standby
current(uA)
Operating
current (mA)
Throughput (MB/s)
#1
210
Read
96
47.6
Write
81
26.6
#2
211
Read
95
47
Write
83
26.8
#3
210
Read
96
48
Write
81
27
