RK3568开发平台Android 11强制所有应用横屏展示
1、打开
frameworks/base/core/java/android/content/pm/parsing/component/ParsedActivityUtils.java
文件,定位到
parseActivityOrReceiver
方法的
int screenOrientation = sa.getInt(R.styleable.AndroidManifestActivity_screenOrientation, SCREEN_ORIENTATION_UNSPECIFIED);
这一行,注释掉该行并添加如下代码:// int screenOrientation = sa.getInt(R.styleable.AndroidManifestActivity_screenOrientation, SCREEN_ORIENTATION_UNSPECIFIED);
// Edit by jgduan
int screenOrientation;
if(pkg.getSharedUserId() == null){
    screenOrientation = 0;
} else {
// End
2、
打开
frameworks/base/core/java/android/app/Activity.java
文件,对
setRequestedOrientation
方法进行如下修改:
     * Change the desired orientation of this activity.  If the activity
     * is currently in the foreground or otherwise impacting the screen
     * orientation, the screen will immediately be changed (possibly causing
     * the activity to be restarted). Otherwise, this will be used the next
     * time the activity is visible.
     * @param requestedOrientation An orientation constant as used in
     * {@link ActivityInfo#screenOrientation ActivityInfo.screenOrientation}.
    public void setRequestedOrientation(@ActivityInfo.ScreenOrientation int requestedOrientation) {
        if (mParent == null) {
            try {
                // Edit by jgduan
                //ActivityTaskManager.getService().setRequestedOrientation(
                //        mToken, requestedOrientation);
                if(mApplication != null && mApplication.getApplicationInfo() != null
                    && mApplication.getApplicationInfo().uid > 10000){
                            mToken, ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE);
                } else {
                // End
            } catch (RemoteException e) {
                // Empty
        } else {
            // Edit by jgduan
            // mParent.setRequestedOrientation(requestedOrientation);
                mParent.setRequestedOrientation(ActivityInfo.SCREEN_ORIENTATION_LANDSCAPE);
            }else{
            // End
