XR806开发板进行ST7789LCD屏幕测试步骤
XR806开发板ST7789LCD屏幕测试
1
屏幕硬件
连接
本文使用的LCD屏幕的原理图如下,可以确定LCD屏幕的控制引脚接线。
GPIO
XR806与LCD屏幕的控制引脚分布如下
GPIO
实际的连接效果如图所示
GPIO
2
驱动编写
ST7789的驱动使用中景园的LCD驱动库,驱动文件包括:
lcd.c
lcd.h
lcd_init.c
lcd_init.h
lcd_font.h
在XR806的示例程序中GPIO工程的基础上进行移植。在gpio示例文件夹中添加lcd的驱动代码。
GPIO
移植时要实现对LCD引脚的控制,在lcd_init.h中添加以下代码
#include "driver/chip/hal_gpio.h"
#include "kernel/os/os.h"
#define LCD_SCLK_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_LOW)
#define LCD_SCLK_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_7, GPIO_PIN_HIGH)
#define LCD_MOSI_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_LOW)
#define LCD_MOSI_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_4, GPIO_PIN_HIGH)
#define LCD_RES_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_LOW)
#define LCD_RES_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_5, GPIO_PIN_HIGH)
#define LCD_DC_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_LOW)
#define LCD_DC_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_3, GPIO_PIN_HIGH)
#define LCD_CS_Clr() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_LOW)
#define LCD_CS_Set() HAL_GPIO_WritePin(GPIO_PORT_B, GPIO_PIN_6, GPIO_PIN_HIGH)
//硬件上没有给出控制接口,这里不做定义
#define LCD_BLK_Clr()
#define LCD_BLK_Set()
在lcd_init.c中添加引脚的初始化函数,并替换延时函数为OS_MSleep,相关的代码如下:
#include "lcd_init.h"
void LCD_GPIO_Init(void)
  GPIO_InitParam param;
  param.driving = GPIO_DRIVING_LEVEL_1;
  param.mode = GPIOx_Pn_F1_OUTPUT;
  param.pull = GPIO_PULL_NONE;
  HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_3, ¶m);
  HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_4, ¶m);
  HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_5, ¶m);
  HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_6, ¶m);
  HAL_GPIO_Init(GPIO_PORT_B, GPIO_PIN_7, ¶m);
void LCD_Init(void)
  LCD_GPIO_Init();
  LCD_RES_Clr();
  OS_MSleep(100);//替换延时函数
  LCD_RES_Set();
  OS_MSleep(100);
    //以下代码忽略
在main.c中添加以下代码
int main(void)
  LCD_Init();
  OS_MSleep(100);
  LCD_Fill(0, 0, LCD_W, LCD_H, RED);
  // LCD_ShowString(4, 0, "XR806 LCD Test", RED, CYAN, 16, 0);
  LCD_DrawRectangle(0, 0, LCD_W - 1, LCD_H - 1, MAGENTA);
  LCD_DrawRectangle(1, 1, LCD_W - 2, LCD_H - 2, MAGENTA);
  while (1)
    OS_MSleep(1000);
    LCD_Fill(0, 0, LCD_W, LCD_H, BLUE);
    OS_MSleep(1000);
    LCD_Fill(0, 0, LCD_W, LCD_H, GREEN);
    OS_MSleep(1000);
    LCD_Fill(0, 0, LCD_W, LCD_H, YELLOW);
    OS_MSleep(1000);
    LCD_Fill(0, 0, LCD_W, LCD_H, LIGHTGREEN);
    printf("XR806 LCD Test
  return 0;
3
屏幕驱动
效果
编译下载后,可以看到屏幕的颜色切换以及串口的数据输出
GPIO
GPIO
审核编辑:刘清
