目前已支持的PMU 为:AXP2585。
该PMU 主要用于电池管理以及充电管理,主要有以下功能:
sys_config.fex
配置说明[pmu]
pmu_irq_pin = port:PA14< 14 >< 0 >< default >< default >
pmu_irq_wakeup = 2
pmu_hot_shutdown = 1
pmu_bat_unused = 0
pmu_usbad_vol = 4600
pmu_usbad_cur = 1500
pmu_usbpc_vol = 4600
pmu_usbpc_cur = 500
pmu_chg_ic_temp = 0
pmu_battery_rdc = 100
pmu_battery_cap = 3568
pmu_runtime_chgcur = 900
pmu_suspend_chgcur = 1200
pmu_shutdown_chgcur = 1200
pmu_init_chgvol = 4200
pmu_init_chg_pretime = 50
pmu_init_chg_csttime = 1200
pmu_chgled_type = 0
pmu_init_bc_en = 1
pmu_bat_temp_enable = 0
pmu_bat_charge_ltf = 2261
pmu_bat_charge_htf = 388
pmu_bat_shutdown_ltf = 3200
pmu_bat_shutdown_htf = 237
pmu_bat_para[0] = 0
pmu_bat_para[1] = 0
pmu_bat_para[2] = 0
pmu_bat_para[3] = 0
pmu_bat_para[4] = 0
pmu_bat_para[5] = 0
pmu_bat_para[6] = 1
pmu_bat_para[7] = 1
pmu_bat_para[8] = 2
pmu_bat_para[9] = 4
pmu_bat_para[10] = 5
pmu_bat_para[11] = 12
pmu_bat_para[12] = 19
pmu_bat_para[13] = 32
pmu_bat_para[14] = 41
pmu_bat_para[15] = 45
pmu_bat_para[16] = 48
pmu_bat_para[17] = 51
pmu_bat_para[18] = 54
pmu_bat_para[19] = 59
pmu_bat_para[20] = 63
pmu_bat_para[21] = 68
pmu_bat_para[22] = 71
pmu_bat_para[23] = 74
pmu_bat_para[24] = 78
pmu_bat_para[25] = 81
pmu_bat_para[26] = 82
pmu_bat_para[27] = 84
pmu_bat_para[28] = 88
pmu_bat_para[29] = 92
pmu_bat_para[30] = 96
pmu_bat_para[31] = 100
pmu_bat_temp_para[0] = 7466
pmu_bat_temp_para[1] = 4480
pmu_bat_temp_para[2] = 3518
pmu_bat_temp_para[3] = 2786
pmu_bat_temp_para[4] = 2223
pmu_bat_temp_para[5] = 1788
pmu_bat_temp_para[6] = 1448
pmu_bat_temp_para[7] = 969
pmu_bat_temp_para[8] = 664
pmu_bat_temp_para[9] = 466
pmu_bat_temp_para[10] = 393
pmu_bat_temp_para[11] = 333
pmu_bat_temp_para[12] = 283
pmu_bat_temp_para[13] = 242
pmu_bat_temp_para[14] = 179
pmu_bat_temp_para[15] = 134
配置含义:
pmu_irq_pin
AXP芯片IRQ引脚连接的IO,用于触发中断
pmu_irq_wakeup
Press irq wakeup or not when sleep or power down.
0: not wakeup
1: wakeup
pmu_hot_shutdown
when PMU over temperature protect or not.
0: disable
1: enable
pmu_bat_unused
unused bat
0: disable
1: enable
pmu_usbpc_vol < u32 >
usb pc输入电压限制值,单位为mV
pmu_usbpc_cur < u32 >
usb pc输入电流限制值,单位为mA
pmu_usbad_vol < u32 >
usb adaptor输入电压限制值(vimdpm),单位为mV
pmu_usbad_cur < u32 >
usb adaptor输入电流限制值,单位为mA
pmu_chg_ic_temp < u32 >
1: TS current source always on
0: TS current source off
pmu_battery_rdc < u32 >
电池内阻,单位为mΩ
pmu_battery_cap < u32 >
电池容量,单位为mAh
pmu_runtime_chgcur < u32 >
运行时constant充电电流限制,单位为mA
pmu_suspend_chgcur < u32 >
休眠时constant充电电流限制,单位为mA
pmu_shutdown_chgcur < u32 >
关机时constant充电电流限制,单位为mA
pmu_terminal_chgcur < u32 >
截止电流,停止充电的标志位之一,单位为mA
pmu_init_chgvol < u32 >
电池满充电压,单位为mV
pmu_init_chg_pretime < u32 >
当电池电压低于REG 0x8C[1]时,属于pre charge阶段。
如果此阶段时间超过pmu_init_chg_pretime,视为超时,停止充电。
pmu_init_chg_csttime < u32 >
当电池电压高于REG 0x8C[1]且低于截止电压(REG 0X8C[7:2])时,属于恒流充电阶段。
如果此阶段时间超过pmu_init_chg_csttime,视为超时,停止充电。
pmu_chgled_type < bool >
0: Enable CHGLED pin funciton
1: Disable CHGLED pin funciton
pmu_init_bc_en < bool >
0: Enable BC1.2
1: Disable BC1.2
pmu_bat_temp_enable < u32 >
设置电池温度检测、ntc是否使能
pmu_bat_charge_ltf < u32 >
触发电池低温停充的TS pin电压阈值,单位:mV
默认:1105mV
范围:0‑8160mV
pmu_bat_charge_htf < u32 >
触发电池高温停充的TS pin电压阈值,单位:mV
默认:121mV
范围:0‑510mV
pmu_bat_shutdown_ltf < u32 >
非充电模式下,触发电池低温中断的TS pin电压阈值,单位:mV
默认:1381mV
pmu_bat_shutdown_htf < u32 >
默认:89mV
范围:0‑510mV
pmu_bat_para1 < u32 >
pmu_bat_para2 < u32 >
pmu_bat_para32 < u32 >
电池曲线参数
电池参数根据使用的电池不同,通过仪器测量出来
pmu_bat_temp_para1 < u32 >
电池包‑25度对应的TS pin电压,单位:mV
pmu_bat_temp_para2 < u32 >
电池包‑15度对应的TS pin电压,单位:mV
pmu_bat_temp_para3 < u32 >
电池包‑10度对应的TS pin电压,单位:mV
pmu_bat_temp_para4 < u32 >
电池包‑5度对应的TS pin电压,单位:mV
pmu_bat_temp_para5 < u32 >
电池包0度对应的TS pin电压,单位:mV
pmu_bat_temp_para6 < u32 >
电池包5度对应的TS pin电压,单位:mV
pmu_bat_temp_para7 < u32 >
电池包10度对应的TS pin电压,单位:mV
pmu_bat_temp_para8 < u32 >
电池包20度对应的TS pin电压,单位:mV
pmu_bat_temp_para9 < u32 >
电池包30度对应的TS pin电压,单位:mV
pmu_bat_temp_para10 < u32 >
电池包40度对应的TS pin电压,单位:mV
pmu_bat_temp_para11 < u32 >
电池包45度对应的TS pin电压,单位:mV
pmu_bat_temp_para12 < u32 >
电池包50度对应的TS pin电压,单位:mV
pmu_bat_temp_para13 < u32 >
电池包55度对应的TS pin电压,单位:mV
pmu_bat_temp_para14 < u32 >
电池包60度对应的TS pin电压,单位:mV
pmu_bat_temp_para15 < u32 >
电池包70度对应的TS pin电压,单位:mV
pmu_bat_temp_para16 < u32 >
电池包80度对应的TS pin电压,单位:mV
不同电池包的温敏电阻特性不一样,根据电池包的TS温敏电阻手册,找到pmu_bat_temp_para[1‑16]对应温度点的电阻阻值,将阻值除以20得到的电压数值(单位:mV),将电压数值填进pmu_bat_temp_para[1‑16]的节点中即可
AXP 是依赖于I2C 进行通过的,所以首先就需要确认I2C 驱动是已经被选上的。
‑ > Drivers Options
‑ > soc related device drivers
‑ > TWI Devices
[*] enable twi driver
‑ > Drivers Options
[*] POWER Devices
‑ > Drivers Options
‑ > POWER Devices
[*] enable power driver
lichee/rtos‑hal/hal/source/power/
├── axp2585.c
├── axp2585.h
├── axp.c
├── axp_twi.c
├── ffs.h
├── Kconfig
├── Makefile
├── sun20iw2p1
│ ├── core.c
└── type.h
若 mrtos_menuconfig
中已经选上了该设备,并且 sys_config.fex
中也配置完成,那么系统加载时就已经自动将 PMU 驱动加载完成,无需软件工程师再进行初始化。
初始化成功的 log 可如下所示:
axp2585 chip version C !
axp2585 chip id detect 0x49 !
current limit not set: usb adapter type
axp2585 init finished !
若是没有打印上述的打印 log 信息,可能是 PMU 驱动加载失败了,可以从 sys_config.fex
配置中确认是否有配置漏配置了,或者是从 I2C 方向去排查,确认I2C 通信是正常的。
PMU 驱动有一个统一的驱动入口,初始化和一些功能接口,都是由AXP 驱动统一管理的。具体请参照 [PMU]章节的说明。
healthd 是一个电源管理的应用,主要功能为:检测电池电量、设置充电电流、电量变低警报、电压过低关机、电池温度过高过度保护等等。
应用配置方法:
‑ > System components
‑ > aw components
[*] healthd for axp
应用源码路径为:
lichee/rtos/components/aw/healthd/healthd.c
应用在默认SDK 中并不会启动,在系统启动之后,需要手动输入:
healthd
然后就开启了电池管理应用了。开启了之后,就会启动了电量变低警报、电压过低关机、电池温度过高过度保护的功能。
运行命令:
healthd_get_capacity
运行命令:
healthd_set_chgcur 1500
命令的后缀为充电电流大小,单位为mA,范围为0~3072mA。
