不同类型的SAN都需要测试哪些射频测试项?
1-H类型测试项
如果对4G/5G基站测试有所了解,那么SAN的测试项也不会陌生,因为完全是按照4G/5G基站的标准作为模板,只是项目有所减少。加之我们已经对5G终端的标准学习了很长的时间,很多测试项的名称和意义是大致相同的。
36.108基于IoT的SAN技术要求的测试项,与38.108基于NR的,除了性能(performance)测试以外完全相同。第6,7,8章为传导测试项,分别为发射机,接收机和性能的传导技术要求。
针对1-H类型的SAN,测试项目如下:
6.2    output power
6.3    Output power dynamics
6.4    (NA)Transmit ON/OFF power
6.5.1  Frequency error
6.5.2  Modulation quality
6.5.3  (NA)Time alignment error
6.6.2  Occupied bandwidth
6.6.3  ACLR
6.6.4  Out-of-band emissions
6.6.5  Transmitter spurious emissions
6.7    (NA)Transmitter intermodulation
7.2    Reference sensitivity level
7.3    Dynamic range
7.4.1  ACS
7.4.2  (NA)In-band blocking
7.5    Out-of-band blocking
7.6    (NA)Receiver spurious emissions
7.7    (NA)Receiver intermodulation
7.8    In-channel selectivity
8      Performance requirements (详见下)
9.2    Radiated transmit power
除9.2 Radiated transmit power(辐射发射功率)外,其余均为传导测试,标注(NA)的表示此项无需测试。反过来说,1-H除了做传导测试,还需要测试一个OTA的测试项。
与4G/5G基站不同的是,SAN不存在共址测试要求。此外,1-H类型的SAN不需要测试的项目还有:发射机开关功率(Transmit ON/OFF power),时间对准误差(Time alignment error),发射机互调(Transmitter intermodulation),以及接收机in-band blocking,接收机杂散,接收机互调。
在性能测试方面,36.108基于IoT的SAN技术要求与38.108基于NR的有所不同。36.108基于IoT的SAN技术要求第8章传导性能(performance)测试项包括:
8.2  PUSCH
  8.2.1  PUSCH supporting coverage enhancement
8.3  PUCCH
  8.3.1  PUCCH performance requirements for coverage enhancement
    8.3.1.1  DTX to ACK performance
    8.3.1.2  ACK missed detection requirements for single user PUCCH format 1a
8.4  PRACH
  8.4.1  PRACH False alarm probability
  8.4.2  PRACH detection requirements
8.5  Narrowband IoT
  8.5.1  NPUSCH format 1
  8.5.2  NPUSCH format 2
    8.5.2.1  DTX to ACK performance
    8.5.2.2  ACK missed detection requirements
  8.5.3  NPRACH
    8.5.3.1  NPRACH False alarm probability
    8.5.3.2  NPRACH detection requirements
38.108基于NR的第8章传导性能(performance)测试项包括:
8.2  PUSCH
  8.2.1  PUSCH with transform precoding disabled
  8.2.2  PUSCH with transform precoding enabled
  8.2.3  UL timing adjustment
  8.2.4  PUSCH repetition Type A
8.3  PUCCH
  8.3.1  DTX to ACK probability
  8.3.2  PUCCH format 0
  8.3.3  PUCCH format 1
    8.3.3.1  NACK to ACK requirements
    8.3.3.2  ACK missed detection requirements
  8.3.4  PUCCH format 2
    8.3.4.1  ACK missed detection requirements
    8.3.4.2  UCI BLER performance requirements
  8.3.5  PUCCH format 3
  8.3.6  PUCCH format 4
  8.3.7  multi-slot PUCCH
    8.3.7.2  multi-slot PUCCH format 1
      8.3.7.2.1  NACK to ACK requirements
      8.3.7.2.2  ACK missed detection requirements
8.4  PRACH
02
1-O类型测试项
第9,10,11章为OTA测试项,分别为发射机,接收机和性能的OTA技术要求。针对1-O类型的SAN,测试项目如下,均为OTA测试,标注NA的表示此项无需测试。
9.3    OTA SAN output power
9.4    OTA output power dynamics
9.5    (NA)OTA transmit ON/OFF power
9.6.1  OTA frequency error
9.6.2  OTA modulation quality
9.6.3  (NA)OTA time alignment error
9.7.2  OTA occupied bandwidth
9.7.3  OTA ACLR
9.7.4  OTA out-of-band emission
9.7.5  OTA transmitter spurious emission
9.8    (NA)OTA transmitter intermodulation
10.2   OTA sensitivity
10.3   OTA reference sensitivity level
10.4   OTA dynamic range
10.5.1 OTA ACS
10.5.2 (NA)OTA in-band blocking
10.6   OTA out-of-band blocking
10.7   (NA)OTA receiver spurious emission
10.8   (NA)OTA receiver intermodulation
10.9   OTA in-channel selectivity
11     Radiated performance requirements (详见下)
1-O不需要测试的项目包括:发射机开关功率(OTA Transmit ON/OFF power),时间对准误差(OTA Time alignment error),发射机互调(OTA Transmitter intermodulation),以及接收机OTA in-band blocking,接收机OTA杂散,接收机OTA互调。
36.108基于E-UTRA的第11章OTA性能(performance)测试项,与上述36.108第8章相同。只是OTA性能要求最多只能针对 2 个解调链路。同样地,38.108基于NR的第11章OTA性能(performance)测试项,也与上述38.108第8章相同。OTA性能要求最多也是只能针对 2 个解调链路。
如果 1-O 型 SAN 使用极化分集,并能保持每个解调分支信号之间的隔离,则最多可对两个解调链路(即 1RX 或 2RX 测试装置)进行OTA性能测试。测试两个解调链路时,每个解调链路映射一个极化。如果 1-O 型 SAN 不使用极化分集,则只能对单个解调链路(即 1RX 测试装置)进行OTA性能测试。
审核编辑:刘清
