数据集地址
该图像数据集包含8000张图像,两个类别分别是安全帽与人、以其中200多张图像为验证集,其余为训练集。
模型训练
准备好数据集以后,直接按下面的命令行运行即可:
yolo train model=yolov8s.pt data=hat_dataset.yaml epochs=50 imgsz=640 batch=4
导出与测试
模型导出与测试
yolo export model=hat_best.pt format=onnx yolo predict model=hat_best.pt source=./hats
部署推理
转成ONNX格式文件以后,基于OpenVINO-Python部署推理,相关代码如下
# Read IR
model = ie.read_model(model="hat_best.onnx")
compiled_model = ie.compile_model(model=model, device_name="CPU")
output_layer = compiled_model.output(0)
capture = cv.VideoCapture("D:/images/video/hat_test.mp4")
while True:
_, frame = capture.read()
if frame is None:
print("End of stream")
break
bgr = format_yolov8(frame)
img_h, img_w, img_c = bgr.shape
start = time.time()
image = cv.dnn.blobFromImage(bgr, 1 / 255.0, (640, 640), swapRB=True, crop=False)
res = compiled_model([image])[output_layer] # 1x84x8400
rows = np.squeeze(res, 0).T
class_ids = []
confidences = []
boxes = []
x_factor = img_w / 640
y_factor = img_h / 640
for r in range(rows.shape[0]):
row = rows[r]
classes_scores = row[4:]
_, _, _, max_indx = cv.minMaxLoc(classes_scores)
class_id = max_indx[1]
if (classes_scores[class_id] > .25):
confidences.append(classes_scores[class_id])
class_ids.append(class_id)
x, y, w, h = row[0].item(), row[1].item(), row[2].item(), row[3].item()
left = int((x - 0.5 * w) * x_factor)
top = int((y - 0.5 * h) * y_factor)
width = int(w * x_factor)
height = int(h * y_factor)
box = np.array([left, top, width, height])
boxes.append(box)
indexes = cv.dnn.NMSBoxes(boxes, confidences, 0.25, 0.45)
for index in indexes:
box = boxes[index]
color = colors[int(class_ids[index]) % len(colors)]
cv.rectangle(frame, box, color, 2)
cv.rectangle(frame, (box[0], box[1] - 20), (box[0] + box[2], box[1]), color, -1)
cv.putText(frame, class_list[class_ids[index]], (box[0], box[1] - 10), cv.FONT_HERSHEY_SIMPLEX, .5, (0, 0, 0))
end = time.time()
inf_end = end - start
fps = 1 / inf_end
fps_label = "FPS: %.2f" % fps
cv.putText(frame, fps_label, (20, 45), cv.FONT_HERSHEY_SIMPLEX, 1, (0, 0, 255), 2)
cv.imshow("YOLOv8 hat Detection", frame)
cc = cv.waitKey(1)
if cc == 27:
break
cv.destroyAllWindows()
