基于Python的地图绘制教程
本文将介绍通过Python绘制地形图的方法,所需第三方Python相关模块包括 rasterio、geopandas、cartopy 等,可通过 pip 等方式安装。
1 示例代码
1.1 导入相关模块
  import rasterio
  import geopandas as gpd
  import numpy as np
  import cartopy.crs as ccrs
  import matplotlib.pyplot as plt
  from matplotlib.colors import LinearSegmentedColormap
1.2 设置地图字体及字号
  plt.rcParams["font.family"] = "Times New Roman"
  plt.rcParams["font.size"] = 14
1.3 绘制地图
  # 设置投影:墨卡托投影
  # cartopy 投影说明:https://www.cnblogs.com/youxiaogang/p/14247184.html
  projection = ccrs.Mercator()
  # 绘制地图
  fig, ax = plt.subplots(figsize=(20, 10), subplot_kw={'projection': projection})
  # 设置地图范围(数值参数为对应投影下的范围坐标)
  ax.set_extent([13530000, 14630000, 4960000, 5850000], crs=projection)
  # 读取矢量文件
  shp = gpd.read_file("Data/Jilin_Mercator.shp")
  shp.plot(ax=ax, transform=projection, edgecolor="black", linewidth=1, facecolor="none")
  # 创建自定义颜色映射
  colors = ["#369121", "#95C769", "#FFFFBF", "#E6865A", "#D14E30", "#BA1414"]
  n_bins = 100 # 定义色带的颜色数量
  cmap_name = "green_brown"
  cm = LinearSegmentedColormap.from_list(cmap_name, colors, N=n_bins)
  # 读取地形栅格数据
  dataset = rasterio.open("Data/DEM_Jilin_Mercator.tif")
  data = dataset.read(1) # 读取第一个波段的数据
  nodata_value = dataset.nodata # 获取NoData值
  # 创建掩膜,去除NoData区域
  data = np.ma.masked_where(data == nodata_value, data)
  # 将地形栅格添加到地图中
  extent = [dataset.bounds.left, dataset.bounds.right,
  dataset.bounds.bottom, dataset.bounds.top]
  im = ax.imshow(data, origin="upper", extent=extent,
  transform=projection, cmap=cm)
  # 绘制网格线并添加标签
  gl = ax.gridlines(draw_labels=True, linestyle="--", color="#4F4F4F")
  gl.xlocator = plt.FixedLocator(range(120, 135, 3))
  gl.ylocator = plt.FixedLocator(range(40, 50, 2))
  # 添加色带,设置色带的缩放比例为 0.4,主图和色带之间的间距为 0.1
  cbar = plt.colorbar(im, ax=ax, orientation="horizontal", shrink=0.4, pad=0.1)
  cbar.set_label("Elevation (m)", labelpad=10) # 设置色带标签与色带的距离为 10 点
  cbar.ax.xaxis.set_label_position("top") # 设置色带标签位置
  plt.savefig("Pic.jpg", dpi=600)
  plt.show()
2 结果图展示
地图绘制
审核编辑:黄飞
