双核单片机红外遥控码代码
控制/MCU
1890人已加入
一个用应广双核单片机做的红外遮挡开光(反射式)全部代码。
IR_SW equ pb.1
IR_INPUT equ pa.0
IR_OUTPUT equ pa.6
byte ir_new
byte ir_old
byte ir_enable
byte i
byte ir_new1
byte ir_new2
byte ir_new3
  goto main0
goto main1
//----------------FPPA0-------------------
main0:
.ADJUST_OTP_IHRCR 8MIPS  // IHRC/2 = 8MIPS, WatchDog Disable, RAM 0,1 temporary be used
sp = 0x30
disgint
inten = 0
mov a,0b000_11_111 //disable timer
mov t16m,a
set1 pbc.1
set0 IR_SW
set0 pac.0
set1 pac.6
set0 IR_OUTPUT
delay 200
ir_new = 0
ir_old = 0
ir_enable = 0
mov a,0
mov intrq,a
set1 fppen.1 //eanble FPPA1
ir_enable = 1
i = 20
while(i)
  delay 200
  i--
if(IR_INPUT)
  ir_old = 1
else
  ir_old = 0
ir_enable = 0
i = 5
while(i)
  delay 200
  i--
clkmd.1 = 1 //enable watch dog
main0_loop:
wdreset
call check_ir
if(ir_new != ir_old)
  if(ir_new != 1)
   tog IR_SW
  ir_old = ir_new
i = 100
while(i)
  delay 200
  i--
goto main0_loop
check_ir:
ir_enable = 1
i = 20
while(i)
  delay 200
  i--
if(IR_INPUT)
  ir_new1 = 1
else
  ir_new1 = 0
i = 5
while(i)
  delay 200
  i--
if(IR_INPUT)
  ir_new2 = 1
else
  ir_new2 = 0
i = 5
while(i)
  delay 200
  i--
if(IR_INPUT)
  ir_new3 = 1
else
  ir_new3 = 0
if((ir_new1 == ir_new2) && (ir_new2 == ir_new3))
  ir_new = ir_new1
else
  ir_new = ir_old
ir_enable = 0
i = 20
while(i)
  delay 200
  i--
ret
//----------------FPPA1-------------------
main1:
sp = 0x38
delay 200
main1_loop: //output 38k IR signal
if(ir_enable)
  set1 IR_OUTPUT
  delay 33
  set0 IR_OUTPUT
  delay 67
else
  set0 IR_OUTPUT
  delay 10
goto main1_loop
