samgr组件是OpenHarmony的核心组件,提供OpenHarmony系统服务启动、注册、查询等功能。
图 1 系统服务管理系统架构图
/foundation/systemabilitymgr
├── samgr
│ ├── bundle.json # 部件描述及编译文件
│ ├── frameworks # 框架实现存在目录
│ ├── interfaces # 接口目录
│ ├── services # 组件服务端目录
│ ├── test # 测试代码存放目录
│ ├── utils # 工具类目录
samgr服务接收到sa框架层发送的注册消息,会在本地缓存中存入系统服务相关信息。
int32_t SystemAbilityManager::AddSystemAbility(int32_t systemAbilityId, const sptr< IRemoteObject >& ability,
const SAExtraProp& extraProp)
if (!CheckInputSysAbilityId(systemAbilityId) || ability == nullptr) {
HILOGE("AddSystemAbilityExtra input params is invalid.");
return ERR_INVALID_VALUE;
unique_lock< shared_mutex > writeLock(abilityMapLock_);
auto saSize = abilityMap_.size();
if (saSize >= MAX_SERVICES) {
HILOGE("map size error, (Has been greater than %zu)", saSize);
SAInfo saInfo;
saInfo.remoteObj = ability;
saInfo.isDistributed = extraProp.isDistributed;
saInfo.capability = extraProp.capability;
saInfo.permission = Str16ToStr8(extraProp.permission);
abilityMap_[systemAbilityId] = std::move(saInfo);
HILOGI("insert %{public}d. size : %{public}zu", systemAbilityId, abilityMap_.size());
RemoveCheckLoadedMsg(systemAbilityId);
if (abilityDeath_ != nullptr) {
ability- >AddDeathRecipient(abilityDeath_);
u16string strName = Str8ToStr16(to_string(systemAbilityId));
if (extraProp.isDistributed && dBinderService_ != nullptr) {
dBinderService_- >RegisterRemoteProxy(strName, systemAbilityId);
HILOGD("AddSystemAbility RegisterRemoteProxy, serviceId is %{public}d", systemAbilityId);
if (systemAbilityId == SOFTBUS_SERVER_SA_ID && !isDbinderStart_) {
if (dBinderService_ != nullptr && rpcCallbackImp_ != nullptr) {
bool ret = dBinderService_- >StartDBinderService(rpcCallbackImp_);
HILOGI("start result is %{public}s", ret ? "succeed" : "fail");
isDbinderStart_ = true;
SendSystemAbilityAddedMsg(systemAbilityId, ability);
return ERR_OK;
对于本地服务而言,samgr服务接收到sa框架层发送的获取消息,会通过服务id,查找到对应服务的代理对象,然后返回给sa框架。
sptr< IRemoteObject > SystemAbilityManager::CheckSystemAbility(int32_t systemAbilityId)
if (!CheckInputSysAbilityId(systemAbilityId)) {
HILOGW("CheckSystemAbility CheckSystemAbility invalid!");
return nullptr;
shared_lock< shared_mutex > readLock(abilityMapLock_);
auto iter = abilityMap_.find(systemAbilityId);
if (iter != abilityMap_.end()) {
HILOGI("found service : %{public}d.", systemAbilityId);
return iter- >second.remoteObj;
HILOGI("NOT found service : %{public}d", systemAbilityId);
return nullptr;
动态加载系统服务进程及SystemAbility, 系统进程无需开机启动,而是在SystemAbility被访问的时候按需拉起,并加载指定SystemAbility。
3.1 继承SystemAbilityLoadCallbackStub类,并覆写OnLoadSystemAbilitySuccess(int32_t systemAbilityId, const sptr& remoteObject)、OnLoadSystemAbilityFail(int32_t systemAbilityId)方法。
class OnDemandLoadCallback : public SystemAbilityLoadCallbackStub {
public:
void OnLoadSystemAbilitySuccess(int32_t systemAbilityId, const sptr< IRemoteObject >& remoteObject) override;
void OnLoadSystemAbilityFail(int32_t systemAbilityId) override;
void OnDemandLoadCallback::OnLoadSystemAbilitySuccess(int32_t systemAbilityId,
const sptr< IRemoteObject >& remoteObject) // systemAbilityId为指定加载的SAID,remoteObject为指定systemAbility的代理对象
cout < < "OnLoadSystemAbilitySuccess systemAbilityId:" < < systemAbilityId < < " IRemoteObject result:" < <
((remoteObject != nullptr) ? "succeed" : "failed") < < endl;
void OnDemandLoadCallback::OnLoadSystemAbilityFail(int32_t systemAbilityId) // systemAbilityId为指定加载的SAID
cout < < "OnLoadSystemAbilityFail systemAbilityId:" < < systemAbilityId < < endl;
3.2 调用samgr提供的动态加载接口LoadSystemAbility(int32_t systemAbilityId, const sptr& callback)。
// 构造步骤1的SystemAbilityLoadCallbackStub子类的实例
sptr< OnDemandLoadCallback > loadCallback_ = new OnDemandLoadCallback();
// 调用LoadSystemAbility方法
sptr< ISystemAbilityManager > sm = SystemAbilityManagerClient::GetInstance().GetSystemAbilityManager();
if (sm == nullptr) {
cout < < "GetSystemAbilityManager samgr object null!" < < endl;
return;
int32_t result = sm- >LoadSystemAbility(systemAbilityId, loadCallback_);
if (result != ERR_OK) {
cout < < "systemAbilityId:" < < systemAbilityId < < " load failed, result code:" < < result < < endl;
return;
说明:
1.LoadSystemAbility方法调用成功后,指定SystemAbility加载成功后会触发回调OnLoadSystemAbilitySuccess,加载失败触发回调OnLoadSystemAbilityFail。
2.动态加载的进程cfg文件不能配置为开机启动,需指定"ondemand" : true, 示例如下:
> "services" : [{
> "name" : "listen_test",
> "path" : ["/system/bin/sa_main", "/system/profile/listen_test.json"],
> "ondemand" : true,
> "uid" : "system",
> "gid" : ["system", "shell"]
3.LoadSystemAbility方法适用于动态加载场景,其他获取SystemAbility场景建议使用CheckSystemAbility方法。
4.cfg里进程名称需要与SA的配置json文件里进程名保持一致
