鸿蒙实战开发:【浏览器制作】
浏览器
介绍
本示例使用[@ohos.systemparameter]接口和[Web组件]展示了一个浏览器的基本功能,展示网页,根据页面历史栈前进回退等。
效果预览
浏览器
使用说明:
  1. 连接Wifi,启动应用,展示默认页面内容;
  2. 点击默认页面的图标跳转到对应网页,或者在输入框输入网址,点击右侧跳转按钮跳转到对应网页;
  3. 点击输入框左侧向右向左按钮进行页面的前进后退;
  4. 点击主页图标回到主页,点击加号按钮新建一个页面。
工程目录
entry/src/main/ets/
|---Application
|   |---AbilityStage.ets                        // 入口
|---pages
|   |---Index.ets                               // 首页
|---common
|   |---PhoneLayout.ets                         // 窗口管理工具
|   |---TitleBar.ets                            // 导航栏
|---model
|   |---Logger.ts                               // 日志工具
|   |---Browser.ets                             // 浏览器实例
具体实现
  • Web展示与历史栈操作功能在Browser中,源码参考[Browser.ets]
 * Copyright (c) 2022 Huawei Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
import Logger from './Logger'
import prompt from '@ohos.prompt';
export class WebObject {
  controller: WebController;
  isRegistered: boolean;
  constructor(controller: WebController, isRegistered: boolean) {
    this.controller = controller
    this.isRegistered = isRegistered
@Observed
class WebKey {
  key: number;
  timestamp: number;
  constructor(key: number, timestamp: number) {
    this.key = key
    this.timestamp = timestamp
export enum LoadingStatus {
  LOADING,
  END
const TAG: string = '[browser]'
export class Browser {
  inputValue: string = ""
  tabArrayIndex: number = 0
  progress: number = 0
  hideProgress: boolean = true
  loadingStatus: LoadingStatus = LoadingStatus.END
  webArray: Array< WebKey > = [new WebKey(0, new Date().getTime())]
  tabsController: TabsController = new TabsController()
  webControllerArray: Array< WebObject > = [new WebObject(new WebController(), false)]
  deleteTab(index: number) {
    Logger.info(TAG, `delete before tab index= ${index} controller length ${this.webControllerArray.length} tabArrayIndex= ${this.tabArrayIndex}`)
    this.webArray.splice(index, 1)
    this.webControllerArray.splice(index, 1)
    if (this.tabArrayIndex > index || this.tabArrayIndex === this.webArray.length) {
      this.tabArrayIndex -= 1
    for (let i = index;i < this.webArray.length; ++i) {
      this.webArray[i].key -= 1
    for (let i = 0;i < this.webArray.length; ++i) {
      Logger.info(TAG, `key ${this.webArray[i].key}, time=${this.webArray[i].timestamp}`)
    Logger.info(`delete after tab index=${index}, controller length=${this.webControllerArray.length}, tabArrayIndex=${this.tabArrayIndex}`)
    this.tabsController.changeIndex(this.tabArrayIndex)
  getWebArray() {
    return this.webArray
  addTab() {
    if (this.webArray.length > 10) {
      prompt.showToast({
        message: '页签数量已满'
      return;
    let webController: WebController = new WebController();
    let object = new WebObject(webController, false)
    this.webControllerArray.push(object)
    this.webArray.push(new WebKey(this.webArray.length, new Date().getTime()))
    this.tabArrayIndex = this.webArray.length - 1
    Logger.info(TAG, `add tab index= ${this.tabArrayIndex}`)
    setTimeout(() = > {
    }, 50)
  setTabArrayIndex(tabArrayIndex: number) {
    this.tabArrayIndex = tabArrayIndex
  getTabArrayIndex() {
    return this.tabArrayIndex
  setInputVal(inputValue: string) {
    this.inputValue = inputValue
  getInputVal() {
    return this.inputValue
  loadUrl(addr: string) {
    addr = "https://" + addr;
    this.webControllerArray[this.tabArrayIndex].controller.loadUrl({ url: addr })
  Back() {
    if (this.webControllerArray[this.tabArrayIndex].controller.accessBackward()) {
      this.webControllerArray[this.tabArrayIndex].controller.backward()
  Forward() {
    if (this.webControllerArray[this.tabArrayIndex].controller.accessForward()) {
      this.webControllerArray[this.tabArrayIndex].controller.forward()
  Refresh() {
    this.webControllerArray[this.tabArrayIndex].controller.refresh()
-   加载网页及刷新:使用WebController提供的loadUrl可以加载目标网址内容,使用refresh方法刷新页面;
-   页面前进后退功能:页面在前进或者后退前使用accessForward/accessBackward查询是否有历史记录,然后调用forward/backward进行前进/后退操作。
依赖
不涉及。
约束与限制
  1. 本示例仅支持标准系统上运行;
  2. 本示例需外接鼠标进行验证;
  3. 本示例已适配API version 9版本SDK,版本号:3.2.11.9。
  4. 本示例不支持点击tab页签,切换网页并刷新页面;
  5. 本示例涉及使用系统接口:[@ohos.systemparameter],需要手动替换Full SDK才能编译通过。
  6. 本示例需要使用DevEco Studio 3.1 Beta2 (Build Version: 3.1.0.400, built on April 7, 2023)及以上版本才可编译运行。
下载
如需单独下载本工程,执行如下命令:
git init
git config core.sparsecheckout true
echo code/BasicFeature/Web/Browser/ > .git/info/sparse-checkout
git remote add origin https://gitee.com/openharmony/applications_app_samples.git
git pull origin master
